10-22-2018, 06:35 | #1 (permalink) |
No Life Poster Join Date: Nov 2008 Location: pakistan
Member: 898041 Status: Offline Sonork: 100.1593459 Thanks Meter: 549 | Fake Acm Interface (COM8) when i conect upmodel huwai phone with pc then not show usb,camera photos,and phone storage. when i check drivers in device manage then show Fake Acm Interface (COM8)what's problem? if drivers issue then share me tested drivers plz |
10-24-2018, 14:55 | #3 (permalink) | |
No Life Poster Join Date: Feb 2005 Location: GSM WORLD
Member: 118520 Status: Offline Thanks Meter: 3,551 | Quote:
Power on the Set Int the Call input *#*#2846579#*#* into ProjectMenu select BackGround Settings--USB Port Settings Disable "Manufacture Mode" Install Driver your problem will sloved GOOD LUCK | |
10-28-2018, 07:16 | #4 (permalink) |
Member: 898041 Status: Offline Sonork: 100.1593459 Thanks Meter: 549 | i try with this code disable manufacture mode, but when i reconnect phone with PC again i chek with code phone again in manufacture mode how permanent disable manufacture mode? |
The Following User Says Thank You to shamshad quresh For This Useful Post: |
10-28-2018, 07:25 | #5 (permalink) |
Member: 898041 Status: Offline Sonork: 100.1593459 Thanks Meter: 549 | here is device manager pic, https://pasteboard.co/HKvabOl.jpg |
10-29-2018, 13:41 | #6 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Bogotá Colombia Age: 43
Member: 150844 Status: Offline Thanks Meter: 309 | Try disabling manufacture mode whitout disconnect phone from pc. You have installed factory Huawei drivers , ( maybe for frp bypass whit another tool), go to control panel and remove Huawei drivers and restart pc, then install hisuite from Huawei oficial page . |
The Following 2 Users Say Thank You to bananin For This Useful Post: |
