Old 10-10-2008, 22:32   #1 (permalink)
Member: 193967
Thanks Meter: 26
fake infinity pinfinder
may i know fello brothers if there are fake pinfinder on the market
i am asking this because i just bought my infinity box and the pinfinder the infinity box is ok but cannot detect the pinfinder if connected to the box
i collected one from a frend and it connected fine but my own does not connect what might be the problem with it can you good one ple help me out
Old 10-10-2008, 22:35   #2 (permalink)
Member: 105817
Thanks Meter: 129
i collected one from a frend and it connected fine but my own does not connect what might be the problem with it can you good one ple help me out :d:d:d
hello please read pin finder manual..
Pin finder the best solution
Old 10-11-2008, 04:02   #3 (permalink)
3stanGsm's Avatar
Member: 331390
Thanks Meter: 433
@ kingsley baafoe
I think there's no clone PIN FINDER.
the reason U can't connect your pin finder to your infinity box is because U have to upgrade your box to pin finder module.
just search on this forum about that matter.
Old 10-11-2008, 04:53   #4 (permalink)
ryumahon's Avatar
Member: 4021
Thanks Meter: 781
there is no such thing a clone or fake pinfinder... but there is alot of defective pinfinders ( a batch of it ) i myself have encountered it... 2 boxes both non-working but can be paired with infinity box... if it is clone then it cannot or NEVER be paired with you infinity box...
Old 10-11-2008, 15:06   #5 (permalink)
Member: 193967
Thanks Meter: 26
Originally Posted by 3stanGsm View Post
@ kingsley baafoe
it was a hardware problem now this is what i get if itry to open infinity software
Locating server...
Server#1 address found.
Connecting to server#1...
Server connection successfully established.
S/N: xxxxxx, Firmware: 0111.02
Authenticating on server...
Authentication successfull.
Checking DongleManager version...
Your DongleManager is up-to-date.
Checking Dongle Identification...
Dongle Identification checked.
Activating module...
Module-04 S/N: 000000000000000000000000000000
Module check error: Server reported error:[0044] Module S/N is already registered.
help
Old 10-11-2008, 15:11   #6 (permalink)
Member: 193967
Thanks Meter: 26
@ kingsley baafoe
Locating server...
help
Old 10-11-2008, 19:11   #7 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,071
Hello,
I suggest you to contact to [email protected] and make very detailed explanation of problem.
What was the problem.
What you have tried to do.
What is the results.
VERY detiailed !
The Following User Says Thank You to InfinitySupport For This Useful Post:
Old 10-13-2008, 21:43   #8 (permalink)
Member: 193967
Thanks Meter: 26
Originally Posted by InfinitySupport View Post
Hello,
VERY detiailed !
this is what i get if i try to Check PinFinder Activation result this is what i get
Dongle serial No (S/N): xxxxxxxx
Firmware version: 0111.02
Smart-card status: activated
"UK edition" status: Off
Last launched application: 0023 v.0134
Support area: http://www.infinity-box.com
- Username: xxxxxxx
- Password: xxxxxxx
Dongle parameters checksum: 566xx0
- If you can't login into support area: contact to [email protected]
- If you have problems during start software at first time: upgrade Dongle firmware.
pls is this normal fellow brothers
Old 10-13-2008, 23:04   #9 (permalink)
Member: 130995
Please, DO NOT ignore my advices, read message #7 in current thread and follow my instruction.
Do you see the difference in my advice and your activity ?
Old 10-14-2008, 06:34   #10 (permalink)
Member: 127269
Sonork: 100.1605945
Thanks Meter: 64
PIN FINDER ALWAYS WORKS ON THAT PERTICULAR INFINITY BOX ON WHICH IT WAS ACTIVATED.BORROWING AN ACTIVATED PIN FINDER WILL NOT SERVE YOUR PURPOSE.CONTACT NEAREST RESELLER AS THIS IS 100 % WORKING SOLUTION FOR CHINESE PHONES.
Old 10-14-2008, 21:39   #11 (permalink)
Member: 193967
Thanks Meter: 26
i have done exactly what you told me and they replied the problem was solved so i should update again i did it and this is what i get if i open the software
Old 10-14-2008, 21:43   #12 (permalink)
Member: 130995
Dear Friend,
I gave you contact details, you have a person who can help you to solve any possible problem.
What is the reason now to post pictures here instead of talk with high-qualified person about your problem ?
Old 10-14-2008, 22:15   #13 (permalink)
Member: 148515
Thanks Meter: 13,684
hello!
if you sent email to [email protected] then tell me what was your address.
cant find your email
Old 10-14-2008, 22:18   #14 (permalink)
Member: 130995
Dear Friend,
It looks like you are trying to make strange game.
Please, explain me what you are trying to do ?
What was the reason to ignore my advice given in message #7 ?
Please, read messge #7 and follow it, in other case please, stop to write in forum strange messages.
If you want to get good answer, please, prepare good explanation.
Old 10-14-2008, 22:19   #15 (permalink)
yasminato's Avatar
Member: 558412
Thanks Meter: 117
at first pinfiner is professional solution at second and for all who foud problem with it contact support directly.read more before use because any skipped detail can cause problems.by the way i never foud a problem since last june
spiderman or infinity pinfinder which is best pinfinder rk_grover77 Chinese Models & Cloned Phones 115 03-31-2010 17:05
Infinity PinFinder - USB Pinout Detection for SPREADTRUM phones needed ! MasterJey Infinity-Box 6 04-04-2009 22:07
Infinity Pinfinder can't Detect Need Help From Infinity Aazib jhon Infinity-Box 11 07-14-2008 12:02
can not power on by infinity pinfinder surayya Infinity-Box 2 04-15-2008 21:31
can infinity pinfinder rx/tx find any mobile?? kabirhossain Infinity-Box 8 03-23-2008 15:19
Page generated in 0.52882 seconds with 9 queries
