Old 04-23-2005, 17:00   #1 (permalink)
Member: 128745
Thanks Meter: 16,936
FAQ & User Guide to unlock Panasonic X70
FAQ & User Guide to unlock Panasonic X70 will be covered in this thread
any questions and problems are welcome here
Old 04-23-2005, 17:04   #2 (permalink)
needi's Avatar
Member: 18303
Thanks Meter: 3
well i need to know the steps to flash x70 properly....i have this problem...while flashing it stops at Parameters Exchange....Signalling...how to solve this problem.
BR>
Old 04-23-2005, 17:11   #3 (permalink)
Member: 128745
@ Needi
Keep the phone with you ,
this problem will be solved Monday morning
You can remove battery if you want , phone is safe
Best Regards
Infinity-Box Team
Old 04-23-2005, 17:47   #4 (permalink)
Member: 130995
Thanks Meter: 35,227
===> 1. IMPORTANT !
a. Use fully charged battery. If battery will be empty during unlock then your phone will be dead
b. Be sure that your PC will not power-off during unlock process
c. Don't run other applications during unlock process to avoid PC crash/freez
===> 2. Supported Hardware/Software Versions (23 APR 2005):
a. AMD FLASH: all Software Versions
b. INTEL FLASH: SW-Ver: A28, A30, A31, A34, A35, A36, A39
c. INTEL FLASH: rest SW-Ver theoretically supported, but some Bugs detected.
See below for details !
===> 3. Unsupported Hardware/Software Versions:
a. INTEL FLASH type: SW-Ver: not listed above
===> 4. Our X70 software releases:
a. v1.02: first public release. Support only AMD flash type.
Some problems was detected in this version for AMD flashes.
UPGRADE to newest version: IMMEDIATELY
b. v1.03: Support all HW/SW ver listed in 2.
Problems was detected with INTEL flash and SW-Ver A32.
A32 ver phones that was made with this release can be repaired in nearest future
c. v1.04: Support all HW/SW-Ver listed in 2.
To avoid possible problems with A32 (INTEL) SW-Ver in future, we removed possibility to make Unlock for unknown SW-Ver.
In this version supported only SW-Ver (INTEL): A28, A30, A31, A34, A35, A36, A39
===> 5. How can I unlock X70 with SW-Ver not listed in 2.a/2.b ?
You have to flash phone with winmodo to any SW-Ver, listed in 2.b and then use our SW to make Unlock
===> 6. Where can I get new X70 flash files ?
Just go to our support-area.
More flash files will be uploaded ASAP
===> 7. I used software v1.03 and made all steps right, but finally can't flash phone with winmodo after end of Unlock process.
Phone small LCD show: "ADB error"
Flasher show: "ERROR [F1]> ???"
Remove battery from phone, close flasher and make small relax.
We are working about this solution. Please, be patient. We have to check this situation very clear.
===> 8. I have problem that was not listed here. What to do ?
a. Don't remove battery from phone
b. Contact to Support ASAP
c. Send to Support detailed information about problem
d. Include in your bug-report file Log_X70.txt (this file located in software folder)
e. Include in your bug-report information about our software version (you will see it in software title)
Old 04-24-2005, 06:16   #5 (permalink)
s4sajii's Avatar
Member: 6919
Thanks Meter: 12
now iam relax..
br
Old 04-29-2005, 19:43   #6 (permalink)
Cheater -Don't Deal with him-
khawar's Avatar
Member: 51218
Thanks Meter: 77
Originally Posted by s4sajii
now iam relax..
br
do'nt relax dear, I have received mine infinity box today .
Old 05-16-2005, 14:54   #7 (permalink)
hema's Avatar
Member: 19267
Thanks Meter: 101
helllooooooo could not unlock pana x70 lots brought in now having error on connection and am using com 12 on my device manager
this is the error
Checking data, wait...
Device have to be SWITCHED OFF
Press Power button now...
Err: can't enter TestMode
Finished
got this error after clicking on stop
Old 05-16-2005, 15:46   #8 (permalink)
Member: 128745
@ hema
there seems to be no connection between phone and software
1) Select COM12 in the software too
2) On the Uni box both switch should face up upwards
3) Use fully charged battery
Please test and give me results
Best Regards
Infinity-Box Team
Old 05-16-2005, 17:05   #9 (permalink)
hema's Avatar
Member: 19267
Thanks Meter: 101
in my other post u said communication error thats its the cable how do I get another cable to work it out had this same error some few days ago with nec e101
Old 05-16-2005, 18:40   #10 (permalink)
Member: 130995
Hello !
Yes, it's some kind of communication error. If X70 can't enetr in TEST-MODE, then it's problem with cable/COM-port.
Please, make this:
1. check COM-port selection.
2. Set both box switches to upper position.
3. If still no results, pls, open your X70 connector and check all wires.
4. Check phone bottom connector. It can be that connector pins is dirty.
B.R.
InfinitySupport
P.S.
Please, next time when you describe your problem, use some commas and dots.
Really, I speak English not so good and for me not so easy to understand text w/o and commas and dots.
Thank you !
Old 05-24-2005, 14:33   #11 (permalink)
Member: 61620
Thanks Meter: 5
BR>
Did you solve this problem? What did you do?
Thanks
Old 05-24-2005, 19:04   #12 (permalink)
Member: 90382
hey...just a question, which software versions require flashing with winmodo? and which ones dont?
regards
Old 05-24-2005, 19:48   #13 (permalink)
Member: 130995
regards
Hello !
It depends not only firmware version, but it depends on hardware too.
Supported w/o flashing (not depends on hardware): A28, A30, A31, A32, A34, A35, A36, A39.
B.R.
InfinitySupport
Old 08-27-2005, 18:31   #14 (permalink)
damabib's Avatar
Member: 106026
Sonork: 100.77890
Thanks Meter: 127
x70 comunicatin error cause by inproper driver installation setup.i used infinity with universal box and work fine 4 me
Old 11-16-2006, 13:45   #15 (permalink)
Registered User
Member: 185010
Sonork: alias-albertino
Thanks Meter: 170
pls ineed your help ijust reset phone code for my x70 and every done reset to 0000 & ask me to remove battary & fix it back. but the phone did not power it only blink the keypad light.i do the oparation with full charge battery.
INFINITY TEAM need help how to unlock panasonic X70 jermaineyork Infinity-Box 1 11-22-2009 11:35
how to unlock panasonic x70 fraz12345 Infinity-Box 9 06-11-2009 03:02
Hacking FAQ/Guide to the Panasonic GD87 mster Panasonic 5 09-11-2005 17:13
arabic user manual to unlock x70 fonec Infinity-Box 2 07-28-2005 10:25
how to use griffin box unlock panasonic x70 e_mobile Panasonic 15 08-07-2004 00:34
Page generated in 0.67458 seconds with 9 queries
