07-01-2016, 14:31 | #1 (permalink) |
No Life Poster Join Date: Sep 2006 Location: ---> Hope
Member: 355782 Status: Offline Thanks Meter: 1,265 | Feature Phone IMEI Repairing Issue. Qmobile W200 hang on after format phone just working fine but IMEI became invalid. tried all available options with CM2MTK for IMEI repairing. but result (Invalid IMEI) read info: Code: Operation : Check / Read Info [ v1.51 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 5 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0000 BB_CPU_SN : 1E4460CCC7D2362A6116C28219BB6BE3 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : C200 2500 3800 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00EF , [MXIC] MX25U12835FZNI_10G [0] : FLASH_DIE : 00C2 0025 0038 0000 [0] : FLASH_LEN : 0x01000000 INT_RAM : 0x0000D000 EXT_RAM : 0x00800000 SDS_INFO : 0x00FFE000 , 0x00002000 Done! Elapsed: 00:00:07 Reconnect Power/Cable! Code: Operation : Format FileSystem [ v1.51 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 5 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0000 BB_CPU_SN : 1E4460CCC7D2362A6116C28219BB6BE3 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : C200 2500 3800 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00EF , [MXIC] MX25U12835FZNI_10G [0] : FLASH_DIE : 00C2 0025 0038 0000 [0] : FLASH_LEN : 0x01000000 INT_RAM : 0x0000D000 EXT_RAM : 0x00800000 SDS_INFO : 0x00FFE000 , 0x00002000 Backup done Executing FFS FORMAT now... FAT_RANGE : 0x00D90000-0x00FEFFFF , LEN : 0x00260000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Done! Elapsed: 00:00:54 Reconnect Power/Cable! Code: Operation : Repair Security [ v1.51 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 5 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0000 BB_CPU_SN : 1E4460CCC7D2362A6116C28219BB6BE3 BROM Protocol Version : 05 Setting Service Mode ... Init Service mode failed, something went wrong :( Reconnect Power/Cable! Code: Operation : Repair Security [ v1.51 ] 1. Phone must be powered ON and WITHOUT SIM! 2. Insert USB cable. Select "COM PORT" or "MODEM" mode! Wait for phone... Phone found! [ 5 ] Sync... Init Ok, waiting for phone ... Sync Failed! Done! Elapsed: 00:00:27 Reconnect Power/Cable! Code: Operation : Repair Security [ v1.51 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 5 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0000 BB_CPU_SN : 1E4460CCC7D2362A6116C28219BB6BE3 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : C200 2500 3800 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00EF , [MXIC] MX25U12835FZNI_10G [0] : FLASH_DIE : 00C2 0025 0038 0000 [0] : FLASH_LEN : 0x01000000 INT_RAM : 0x0000D000 EXT_RAM : 0x00800000 SDS_INFO : 0x00FFE000 , 0x00002000 Read Security data ... Verify Security data ... Set IMEI [0] : 35325705004XXXX Set IMEI [1] : 35325705036XXXX Repair Repair done! [Info] : Make "Format/Reset Settings" procedure before start phone! Done! Elapsed: 00:00:08 Reconnect Power/Cable! Format / Reset Settings: Code: Operation : Format FileSystem [ v1.51 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 5 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0000 BB_CPU_SN : 1E4460CCC7D2362A6116C28219BB6BE3 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : C200 2500 3800 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00EF , [MXIC] MX25U12835FZNI_10G [0] : FLASH_DIE : 00C2 0025 0038 0000 [0] : FLASH_LEN : 0x01000000 INT_RAM : 0x0000D000 EXT_RAM : 0x00800000 SDS_INFO : 0x00FFE000 , 0x00002000 Backup done Executing FFS FORMAT now... FAT_RANGE : 0x00D90000-0x00FEFFFF , LEN : 0x00260000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Done! Elapsed: 00:00:46 Reconnect Power/Cable! |
07-03-2016, 11:45 | #6 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Phone have SDS, but it don't use it Chinese makers not stop impress me. Next update will bring some fixes for that. |
The Following 3 Users Say Thank You to JayDi For This Useful Post: |
