Old 06-27-2015, 13:20   #1 (permalink)
ranagaurav's Avatar
Member: 907098
Sonork: 100.1601140
Thanks Meter: 705
xolo q700s dead after flash
phone show xolo logo
i formate both condetion but same condetion i flash with og file
set dead log
Operation : Flash [ v1.21 ]
======= Flash
Wait for phone...
Phone found! [ 82 ]
Sync...
Inital regs read done
Boot Info :
BB_CPU_ID : 6582
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0001
BB_CPU_NM : [MediaTek] MT6582_S00
Processing BROM stage
SecCfgVal : 0x00000000
BromVersion : 0xFF
BLVersion : 0x01
Preloader Status : Alive
Processing DA stage
DA Select done , sending
NAND_ID : 00000000000000000000000000000000
eMMC_ID : 1501004B3557564D4201E653430A90B9
DA Stat : v4.2 on BBID : 0x87
DA Sent. Configure setting now ...
DA started successuflly
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0015 , OEM : 0100
[eMMC] : FLASH_INF : BMVW5
[eMMC] : FLASH_CID : 1501004B3557564D4201E653430A90B9
[eMMC] : FLASH_LEN : 0x00000000E9000000
INT RAM : 0x00020000
EXT RAM : 0x40000000
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6582 , Project : j505_xolo , Storage : EMMC
Setting : AFF verify : Enabled
BL : Check HW compatibility
BL : Check eMMC compatibility
BL : Flash Pre-Erase
Total blocks to Erase : 2
Erase : 0x0000000000000000-0x0000000000100000
Erase : 0x0000000001D00000-0x0000000075A80000
Flash Pre-Erase Done, time used : 00:00:07
SecCfg Passed , 1799
BMT remark not need. Will skip
Sending Preloader ...
Use : preloader_j505_xolo.bin
Preloader Sent , Init passed
PartCount : 0014
Processing : Flash Write
Flash now : MBR
Image Flash Ok
Flash now : EBR1
Image Flash Ok
Flash now : UBOOT
Image Flash Ok
Flash now : BOOTIMG
Image Flash Ok
Flash now : RECOVERY
Image Flash Ok
Flash now : SEC_RO
Image Flash Ok
Flash now : LOGO
Image Flash Ok
Flash now : EBR2
Image Flash Ok
Flash now : ANDROID
Image Flash Ok
Flash now : CACHE
Image Flash Ok
Flash now : USRDATA
Image Flash Ok
Flash Write Done, time used : 00:01:51
Processing : Verify
Verify Passed : MBR
Verify Passed : EBR1
Verify Passed : UBOOT
Verify Passed : BOOTIMG
Verify Passed : RECOVERY
Verify Passed : SEC_RO
Verify Passed : LOGO
Verify Passed : EBR2
Sparse Image , re-calculate checksum to : 0x6F0D
Verify Passed : ANDROID
Sparse Image , re-calculate checksum to : 0x2D35
Verify Passed : CACHE
Sparse Image , re-calculate checksum to : 0xD1F7
Verify Passed : USRDATA
Data Verify Done, time used : 00:00:01
Update RomInfo done
Done!
Elapsed: 00:02:13
Reconnect Power/Cable!
Old 06-27-2015, 13:31   #2 (permalink)
rehmani's Avatar
Member: 333199
Sonork: may i help u just pm me
Thanks Meter: 2,405
set dead log
use original sp flash tool karbon (mt6582)phone cant flash with original flash file with cm2
Old 06-27-2015, 13:48   #3 (permalink)
rehmani's Avatar
Member: 333199
Thanks Meter: 2,405
set dead log
my mistake karbon,xolo and so many other
Old 06-27-2015, 13:54   #4 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
I've found some bugs in Factory FW flashing, in next version, hope, they will start working as should.
Old 06-27-2015, 14:08   #5 (permalink)
Yashbanswara's Avatar
Member: 1147254
Sonork: 100.1620677
Thanks Meter: 639
Yes Bug In CM2 MTK Because when i Read flash by cm2 in factory format (Scatter) & write flash flash working Well But When Write Original Factory Format Flash File Only Show this.
Unsupported Yet( or bad ) file selected!
Why
Thanks & Regards
Gopal Parmar
Old 06-27-2015, 14:30   #6 (permalink)
JayDi's Avatar
Member: 462970
Why
Thanks & Regards
Gopal Parmar
Really? Did you even seen what about your thread and what about your post???
Old 06-27-2015, 14:40   #7 (permalink)
sneha's Avatar
Member: 327043
Sonork: 100.1587811
Thanks Meter: 1,514
Why
Thanks & Regards
Gopal Parmar
its not bug because u try to write nand and at this time nand not suprte for write flash
Old 06-27-2015, 14:50   #8 (permalink)
Member: 1147254
Sonork: 100.1620677
Thanks Meter: 639
You Mean At This Time MTK Nand Not Support For Write Flash In CM2 MTK
Sorry Sir
Old 06-27-2015, 15:14   #9 (permalink)
sneha's Avatar
Member: 327043
Sonork: 100.1587811
Thanks Meter: 1,514
Sorry Sir
yes u understand very fast .. wait some day for upcoming update
Old 09-22-2015, 16:05   #10 (permalink)
Member: 2461973
my xolo q700s is stuck on logo.
i am flash many files but not done any file.
so give the solution.
thanks
Old 09-22-2015, 16:10   #11 (permalink)
JayDi's Avatar
Member: 462970
thanks
Send it to service center. They will fix it.
The Following User Says Thank You to JayDi For This Useful Post:
Old 09-27-2015, 12:38   #12 (permalink)
Member: 2461973
i send service center flash phone software but issue not fixed. other phone flash succesfully.
Old 09-27-2015, 13:23   #13 (permalink)
Member: 459784
Sonork: +91-9179403087
Thanks Meter: 1,543
send another service center may be he don't have new pba
Old 09-27-2015, 13:32   #14 (permalink)
Member: 2461973
whats is pba please tell me
thanks
Old 09-27-2015, 14:22   #15 (permalink)
Member: 459784
Thanks Meter: 1,543
thanks
means - we can't help - send reset any dealer or service center
Page generated in 0.24463 seconds with 8 queries
