few read error and privecy lock in error @jayDi need to check log1 Brand : Spice ProdName : Mi-535 ProdModel : Spice Mi-535 Device : Mi-535 AndroidVer: 4.2.1 MTKxCPU : MT6589 MTKxPRJ : SPICE_Mi-535_IND_VER13.0_130609 [Read Ok] : preloader_ckt89_we_jb2.bin [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : EBR2 #24576 : Data CRC Error : 33C3 , 0000 Error while reading block! Something went wrong :( log-2 Wait for phone... Phone found! [ 34 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 150100513758534142016FB9C86E81B5 DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BASX7 [eMMC] : FLASH_CID : 150100513758534142016FB9C86E81B5 [eMMC] : FLASH_EXT : 00400000/00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... Brand : TECNO ProdName : TECNO H6 ProdModel : TECNO H6 Device : g325_a1_tecno_custom AndroidVer: 4.4.2 MTKxCPU : MT6582 MTKxPRJ : H6-G325-20140923 [Read Ok] : preloader_ratech82_cwet_rlk_kk.bi [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : EBR2 #19458 : Data CRC Error : 73CA , 51A9 Error while reading block! Something went wrong :( Read error :( Operation Failed Elapsed: 00:04:58 Reconnect Power/Cable! log-3 privacy lock with safe data error ait for phone... Phone found! [ 34 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 150100513758534142016FB9C86E81B5 DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BASX7 [eMMC] : FLASH_CID : 150100513758534142016FB9C86E81B5 [eMMC] : FLASH_EXT : 00400000/00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Checking data ... Processing with "Safe UserData" mode SafeDetect : Done! Will reset now! Can not reset PL on step #1, something went wrong :( Operation Failed Elapsed: 00:00:18 Reconnect Power/Cable! |
Hello. You have problem on your PC - some SW, drivers and e.t.c. , check from drivers first, then close all sw, which can use ports. then try. |
boss its win 10 , iam using in xp also rtied, same issue any how i will try in my laptop too |
