01-11-2009, 08:34 | #1 (permalink) |
Freak Poster Join Date: Oct 2008 Location: Jakarta, Indonesia
Member: 878992 Status: Offline Thanks Meter: 34 | File flash for Hitech H-39 it is the first time for me flashing with Infinity box. i've read full flash. The serial is : U26_06B_PCB01_GPRS_MT6226_S01.UPU25U26V04B27.BIN in support area I find hitech H-39 file flash with serial : U26_06B_PCB01_GPRS_MT6226_S01.UPU25U26V03B59__HiTe ch-H39_16m_En_Id_Cn.B0M.bin. Can I use this file?? Cause I can't find UPU25U26V04B27_Hitech-H39. Thanks. |
The Following User Says Thank You to Jocell_2 For This Useful Post: |
01-11-2009, 09:34 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, You can use files with version similar to U26_06B_PCB01_GPRS_MT6226_S01.UPU25U26V04B27 |
01-13-2009, 09:58 | #3 (permalink) |
Member: 878992 Status: Offline Thanks Meter: 34 | hello MR, i have flashed the phone, but it's still dead. Here is the log: COM10 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: write NOR flash "smart write" active write: Firmware skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:C19C:5E7C high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: EC257E25082501:2AEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:2AEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 921600 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: EC257E25082501:2AEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:2AEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area (code #1) is Ok security area (code #1) backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.2B24C6C7.[U26_06B_PCB01_GPRS_MT6226_S01.UPU25U26V04B27.BIN_C 21F7895].rpl ==================== New firmware detected: U26_06B_PCB01_GPRS_MT6226_S01.UPU25U26V04B27.BIN - make "Read full flash" operation - send "system_log_..." file to support: [email protected] - send flash backup file(s) to support: [email protected] - include in your e-mail full text from phone back label (phone name etc.) ==================== identification#1 detection finished device-id: 2B24C6C7 identification#1 protocol ver: 04 ver. sw1: U26_06B_PCB01_GPRS_MT6226_S01.UPU25U26V04B27.BIN ver. sw2: UPU25U26V04B27, 6A87E03D ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00E00000 flash: EC257E25082501:2AEA0000000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading: eeprom[U26_06B_PCB01_GPRS_MT6226_S01.UPU25U26V04B27.BIN]... file saved: C:\Program Files\InfinityBox\ChineseMiracle\eeprom[U26_06B_PCB01_GPRS_MT6226_S01.UPU25U26V04B27.BIN]_20090113-154907.B0E.bin flash: EC257E25082501:2AEA0000000000 Backup required data Done Patch required data... Patch required data Done Special operation... Special operation Done Write... detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished security area (code #1) calculation... done detecting security area (code #2)... security area (code #2) is absent file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\s ystem_log_2B24C6C7_U26_06B_PCB01_GPRS_MT6226_S01.U PU25U26V04B27.BIN_C21F7895_20090113-154934.B0X.bin Area: Firmware flash: EC257E25082501:2AEA0000000000 Write: Firmware detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished Write Done Finalization... Finalization Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\s ystem_log_2B24C6C7_U26_06B_PCB01_GPRS_MT6226_S01.U PU25U26V04B27.BIN_C21F7895_20090113-155513.B0X.bin Finished, time used: 513 sec Remove/Install battery now ! Need help please. Thanks |
01-13-2009, 17:29 | #4 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! there can be only two reasons for this: either this firmware is not suitable for your phone or this phone has damaged hardware |
file flash for motorola c261 | dj_t0t4l | Infinity-Box | 1 | 08-06-2007 05:26 |
i need file flash for nokia 7250 | jone6wilson | Twisterflasher | 0 | 01-03-2006 14:34 |
File flash for motorola c350 | vant | Motorola P2k | 0 | 12-10-2005 15:57 |
need file flash for a60 | dey_it | E-Gold Based Phones | 6 | 10-21-2004 08:28 |
file flash for E715 | abdoulaye | Trident/AGERE Platform | 3 | 04-24-2004 11:25 |
