04-27-2009, 10:50 | #1 (permalink) |
No Life Poster Join Date: Feb 2004 Age: 49
Member: 53198 Status: Offline Sonork: 100.1589499 Thanks Meter: 819 | Final Hidden languages in MT62xx phones problem solve with Infinity Box Final Hidden languages in MT62xx phones problem solve with Infinity Box Last time we have got several test reports about strange situation with some MT62xx models. Situation is: . initially phone has several languages in menu . after format phone has only English language in menu: other languages become lost, it is impossible to select other languages via menu ,via keyboard codes or only select language via keyboard codes Today i want to share for everryone how to fix this problem after many test This kind of phone have three method fix this proplem Method 1 (Flash) Write full flash or eeprom read from good phone Method 2 Write backup eeprom before formart phone Method 3 (By code) 1.Read full flash phone with ChineseMircle 2.Start Informer 1.01 3. We have all code from phone and Exclude some code Here all code select language manual we will ignore it 4. Some other code we will ignore it *#66*# : Set Factory mode *#06# = Imel *#0000# = S/W Vertion *#3646633# = Engineer mode *#87# *#523# = LCD Contrast *#876# *#900# = Bluetooth On/Off *#902# *#3366*# *#035670766*001# = Ctrl buffer =0 *#035670766*002# = Task dpg mask =197632 *#837500# = Version Info Summary *#33778# = Serial number .......... 5.we enter the remaining codes until you find the correct code phone will enter Menu select language Select language you want and press save. Press *#6810# phone will disable Menu select language (If you want reselect language format the phone and enter code select language again) Here I Found Some code Enter Menu Select Language (In some phone) Tested *#013# *#23*# *#0000# *#1230000# After select language enter this code*#6810# phone will locked Menu Select language and other All Language you select Will Display in Menu\Setting\Language B.R Star75 |
The Following 5 Users Say Thank You to Star75 For This Useful Post: |
Easiest way to repair IMEI in china phones with Infinity box- | PASSIONATE_BOYS | Infinity-Box | 1 | 03-14-2010 17:18 |
f3 blinking problem solve with mss box | Wasim007 | MSS Box II | 0 | 11-16-2009 13:01 |
Hidden languages in MT62xx phones | InfinitySupport | Infinity-Box | 26 | 05-04-2009 15:12 |
Probleme Solved Withe Polar Box | ..:::: SOFT KILLER ::::.. | PolarBox 3 | 3 | 05-07-2008 20:08 |
As I can activate hidden languages in a V66? | Andyx | Motorola P2k | 0 | 09-23-2001 17:54 |
