01-03-2017, 07:37 | #1 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Dera Ismail Khan (KPK) Pak
Member: 613449 Status: Offline Sonork: 100.1614074 Thanks Meter: 634 | MT6572__samsung__GT-I9082__serrano3g__4.4.2__U866_0818 need needed |
The Following User Says Thank You to rahihimkhan For This Useful Post: |
01-03-2017, 08:31 | #2 (permalink) |
No Life Poster Join Date: Apr 2014 Location: Charsadda kpk Age: 41
Member: 2166444 Status: Offline Thanks Meter: 298 | Operation : Check / Read Info [ v1.51 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 76 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1620.10.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 90014A2058494E594812A1A89AD19FE5 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , HYNIX [eMMC] : FLASH_CID : 90014A2058494E594812A1A89AD19FE5 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00200000 [eMMC] : FLASH_LEN : 0x00000000E7000000 [eMMC] : FLASH_UCP : 3696 MiB [eMMC 4 GiB] DEV RID : 0xB663B864E03E7C1F66334C63F2F8931F INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : samsung ProdName : serrano3g ProdModel : GT-I9082 Device : serrano3g AndroidVer: 4.4.2 MTKxCPU : MT6572 MTKxPRJ : U866_0818 SECURITY : IMEI_SW [1] : 355886058062996 IMEI_SW [2] : 355887058062994 BTMAC Addr : 9EC146657205 WiFi MAC : 000000000000 EXTRA : LCD [0] : hx8369_dsi LCD [1] : #hx8379c_fwvga_dsi_vdo_hsd LCD [2] : #ili9806e_fwvga_dsi_vdo_hsd LCD [3] : #hx8379c_fwvga_dsi_vdo_hsd LCD [4] : #otm8009a_fwvga_dsi_cmd LCD [5] : #nt35510s_fwvga_dsi_cmd_boe LCD [6] : rm68180_fwvga_dsi_cmd_cmo LCD [7] : otm8018b_fwvga_dsi_vdo_cmo LCD [8] : nt35512_fwvga_dsi_vdo_boe LCD [9] : rm68171_fwvga_dsi_vdo_cmi LCD Res : 800x480 TOUCH [0] : ICN85XX TOUCH [1] : ft6306_gs TOUCH [2] : #msg2133a CAM [0] : s5k4ecgx_mipi_yuv CAM [1] : gc2145mipi_yuv CAM [2] : ov2655_mipi_yuv CAM [3] : gc0328_yuv CAM [4] : sp2529_yuv CAM [5] : ov5645_mipi_yuv CAM [6] : bf3a03_yuv CAM [7] : hi704_yuv CAM [8] : gc0309_yuv MODEM : mtk72_wet_jb3_hspa LOCALE : en_US ru_RU es_ES pt_BR fr_FR de_DE tr_TR it_IT in_ID ms_MY vi_VN hr_HR th_TH pt_PT nl_NL my_MM ar_EG fa_IR hdpi -sw600dp -sw720dp Done! |
The Following User Says Thank You to GSM KPK For This Useful Post: |
01-05-2017, 08:04 | #3 (permalink) | |
Member: 613449 Status: Offline Sonork: 100.1614074 Thanks Meter: 634 | Quote:
Give me any body flash file link | |
01-08-2017, 13:38 | #4 (permalink) | |
No Life Poster Join Date: Aug 2010 Location: Pakistan Age: 32
Member: 1378233 Status: Offline Sonork: 100.1594197 Thanks Meter: 195 | Quote:
01-13-2017, 19:45 | #6 (permalink) |
No Life Poster Join Date: Oct 2011 Location: Nigeria
Member: 1677653 Status: Offline Thanks Meter: 2,769 | PLEASE I ALSO NEED FILE Wait for phone... Phone found! [ 9 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 1501004E35575A4D42018477CD00B081 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMZW5 [eMMC] : FLASH_CID : 1501004E35575A4D42018477CD00B081 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0xDEC55C378882DD82CFB1E570972F3050 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : samsung ProdName : baffinzt ProdModel : GT-I9082 Device : baffin AndroidVer: 4.2.2 MTKxCPU : MT6572 MTKxPRJ : ALPS.JB3.MP.V1.33 MODEM : BaseBand : MT6572_S00_MOLY_WR8_W1315_MD_WG_MP_V10_1_wg_n EXTRA : LCD [0] : hx8369b_wvga_dsi_vdo LCD [1] : nt35516_qhd_dsi_cmd_ipsboe LCD Res : 800x480 TOUCH [0] : ICN83XX CAM [0] : ov5645_mipi_yuv CAM [1] : gc2035_yuv CAM [2] : s5k4ecgx_mipi_yuv CAM [3] : gc0329_yuv CAM [4] : gc0328c_yuv MODEM : s8852 LOCALE : en_US es_ES ru_RU pt_BR fr_FR de_DE tr_TR it_IT in_ID ms_MY vi_VN ar_EG th_TH pt_PT nl_NL el_GR hu_HU tl_PH ro_RO cs_CZ iw_IL my_MM km_KH fa_IR hdpi -sw600dp -sw720dp Done! Elapsed: 00:00:14 Reconnect Power/Cable! |
01-13-2017, 20:03 | #7 (permalink) |
Member: 1677653 Status: Offline Thanks Meter: 2,769 | Definition Applied 1. Power Off Phone , Remove Battery, Insert Battery Back 2. Insert USB cable. In some cases Required Hold BootKey 3. Use Miracle Boot Key In cases Boot key not Find 4. Battery Should be Charged more then 50% Waiting for USB Port... Set MTK USB Port (COM12) Please Hold "ON" to connect with the phone... Connected to Phone. CPU: MT6572 SW:0000 Ver: CA01 Downloading Boot8 ... EMMC Size: 0x00E9000000 Flash Type: EMMC INT/EXT RAM Size: 0x20000/0x20000000 Reading infr(EMMC)... id:ALPS.JB3.MP.V1 version:4.1.2 model:GT-I9082 brand:samsung manufacturer:GT-I9082 PRELOADER BaseAddr:0x0 Size:0x600000 MBR BaseAddr:0x600000 Size:0x80000 EBR1 BaseAddr:0x680000 Size:0x80000 PRO_INFO BaseAddr:0x700000 Size:0x300000 NVRAM BaseAddr:0xA00000 Size:0x500000 PROTECT_F BaseAddr:0xF00000 Size:0xA00000 PROTECT_S BaseAddr:0x1900000 Size:0xA00000 SECCFG BaseAddr:0x2300000 Size:0x20000 UBOOT BaseAddr:0x2320000 Size:0x60000 BOOTIMG BaseAddr:0x2380000 Size:0x600000 RECOVERY BaseAddr:0x2980000 Size:0x600000 SEC_RO BaseAddr:0x2F80000 Size:0x40000 MISC BaseAddr:0x2FC0000 Size:0x80000 LOGO BaseAddr:0x3040000 Size:0x300000 EXPDB BaseAddr:0x3340000 Size:0xA00000 ANDROID BaseAddr:0x3D40000 Size:0x1E000000 CACHE BaseAddr:0x21D40000 Size:0x1B00000 USRDATA BaseAddr:0x23840000 Size:0x19000000 FAT BaseAddr:0x3C840000 Size:0xAB740000 BMTPOOL BaseAddr:0xFFFF0000 Size:0x1500000 BaseAddr:0x0 Size:0x0 >>Done. |
