Old 09-08-2008, 06:41   #1 (permalink)
Member: 294245
Sonork: 100.1602405
Thanks Meter: 115
Firmware damage
COM23 [Serial2] selected
Device: Autodetect 6205-6227 NOR
Checking data, wait...
eeprom backup enabled, it may takes several minutes !
Action: read/check detailed information
Boot...
19200 fixed
Connecting, wait...
Initializing[6225:8A03:8A00]...
CPU: MT6225
high speed boot enabled
chip: 0001:5403:0001
boot step size: 0400
Release Power button now !
Boot Done
Initialize...
flash: 01227E22022201:FFFFFF00000000
flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
Set baud...
115200
Set baud Done
Initialize bootcode...
Initialize bootcode Done
Check firmware integrity...
device parameters autodetection in progress..
Warning: probably flash chip empty, erased, incorrectly flashed or damaged.
What to do:
1. go to software "Settings" page
2. set "Advanced chip detection method" box UN-CHECKED !
3. make flash write operation
If still no luck: send mail to support ([email protected]) with detailed description of problem,
attach the next files in your e-mail:
1. C:\Program Files\InfinityBox\ChineseMiracle\operation.log
2. C:\Program Files\InfinityBox\ChineseMiracle\cfi_xxxx_xxxx.bin
it's time to stop: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
total flash region size: 00800000
detect device identification#1...
detection phase #1...
detection phase #2...
warning: identification#1 information not found, possible reasons:
.old firmware type w/o identification#1 data
.damaged firmware
.damaged hardware
if phone works fine just ignore this warning
detect device identification#1 finished
detect device identification#2...
warning: optional information is not found,
if phone works well just ignore this warning
detect device identification#2 finished
detecting eeprom/ffs area in 1 chip(s)...
standard eeprom/ffs offset assigned: 00700000
checking area[00000000]: 00000000-007FFFFF...
Can't detect eeprom/ffs area
Do you want to use standard ffs address: 00700000 ?
If you are not sure that standard address is correct:
1. press "NO" and terminate current operation
2. make flash backup for emergency case
3. repeat required operation
standard ffs address selected by user
detecting eeprom/ffs size...
eeprom/ffs size: 00100000
ffs chip: 00
eeprom/ffs area: 00000000:00700000-007FFFFF
detecting ffs structure pass 1...
detect standard fat location pass #1...
detect standard fat offset pass #1...
detect standard fat data...
fat layout detection complete
ffs element #1 detected ok
detecting ffs structure pass 2...
ffs element #2 detected ok
Check firmware integrity Done
Check firmware content...
Check firmware content Done
Backup required data...
Finished, time used: 71 sec
Remove/Install battery now !
hello dear
what is this problem and this sloution
thanx
Old 09-08-2008, 18:51   #2 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
please read out full backup and send to [email protected]
also, what problem with phone?
1202 mic track damage ameho0102 Nokia Hardware & Hardware Repair 15 08-21-2011 12:13
what is the solution of damage Potato BOX ???? ..::MOBILES::.. MXKEY Nokia Flasher and Unlocker (by Alim Hape) 1 03-29-2010 17:03
dongle firmware damage surajrasaq Infinity-Box 1 03-04-2008 18:35
E317 firmware from support it's damaged and flash error killer84p NSPRO 0 03-09-2007 11:11
Page generated in 0.18964 seconds with 9 queries
