08-05-2009, 04:47 | #1 (permalink) |
Junior Member Join Date: Jan 2008 Location: Dhaka, Bangladesh Age: 37
Member: 670596 Status: Offline Thanks Meter: 4 | firmware is missing database date: unknown TM901_PCB01_GPRS_MT6226_S01.090617_42B_V0756.BIN New firmware detected (v.2.84, database date: unknown): TM901_PCB01_GPRS_MT6226_S01.090617_42B_V0756.BIN This firmware is missing in support area. If this phone is good and working: COM3 [VCP0] selected module v2.84 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: "format ffs" ffs/eeprom backup enabled, it may takes several minutes ! Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:2BC1:EBB6 status: FF high speed boot Off boot packet size: 0002 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 98004900000001:29EA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #01 in region #00... flash: 98004900000001:29EA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #02 in region #00... flash: 98004900000001:29EA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #03 in region #00... flash: 98004900000001:29EA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 460800 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 98004900000001:29EA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #01 in region #00... flash: 98004900000001:29EA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area (code #1) is Ok security area (code #1) backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.79FB6359.[TM901_PCB01_GPRS_MT6226_S01.090617_42B_V0756.BIN_6 C1E079C].rpl ==================== New firmware detected (v.2.84, database date: unknown): TM901_PCB01_GPRS_MT6226_S01.090617_42B_V0756.BIN This firmware is missing in support area. If this phone is good and working: - make "Read full flash" operation - send "system_log_..." file to support: [email protected] - send flash backup files to support: [email protected] - include in your e-mail full text from phone back label (phone name etc.) ==================== identification#1 detection finished device-id: 79FB6359 identification#1 protocol ver: 04 ver. sw 1: TM901_PCB01_GPRS_MT6226_S01.090617_42B_V0756.BIN ver. sw 2: 090617_42B_V0756, 63F8E193 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . detect device identification#2 finished detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 flash: 98004900000001:29EA0000000000 checking area [00000000]: 00000000-00FFFFFF... Can't detect ffs/eeprom area Do you want to use standard ffs/eeprom address: 00E00000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard ffs/eeprom address selected by user detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: TM901_PCB01_GPRS_MT6226_S01.090617_42B_V0756__ffs. .. file saved: C:\Program Files\InfinityBox\ChineseMiracle\TM901_PCB01_GPRS_ MT6226_S01.090617_42B_V0756__ffs_20090804-182106.B0E.bin flash: 98004900000001:29EA0000000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... Write Done Finalization ... formatting... flash: 98004900000001:29EA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\T M901_PCB01_GPRS_MT6226_S01.090617_42B_V0756__syste m_log_79FB6359_6C1E079C_20090804-182130.B0X.bin Finished, time used: 318 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
08-05-2009, 06:34 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, If required file can not be found in support area (please use "search" function in support area first) it will be good if somebody can read full flash from the same good working phone and send full flash backup to [email protected] so we will be able to prepare and upload good working files in support area for all users. Here is an instruction how to make "search" in support area: http://forum.gsmhosting.com/vbb/showthread.php?t=499453 Please, DO NOT send to us backup files from damaged phones. We CAN NOT repair damaged files ! |
08-05-2009, 22:14 | #3 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! make backup of your existing version and try following file: flashfiles/ChineseMiracle/_MT6205-MT6227/CM_Tianyu-S655_TM901_PCB01_GPRS_MT6226_S01.006243_273_V0828_ 16m_En_Cn.B0M.bin |
nokia N95 New firmware detected (v.3.02, database date: 03.12.2009): | algeriano_19 | Infinity-Box | 1 | 12-12-2009 20:54 |
New firmware detected (v.3.02, database date: unknown): | drjaved_akhter | Infinity-Box | 1 | 12-07-2009 15:44 |
New firmware detected (v.2.86, database date: 26.07.2009): | biochemistali | Infinity-Box | 1 | 07-30-2009 21:52 |
ZTC ZT678 SECOND CPU firmware is missing in support area | aswancamel | Infinity-Box | 1 | 06-27-2009 18:52 |
New firmware detected (v.2.81, database date: 13.04.2009): | GSM_BB5 | Infinity-Box | 1 | 05-07-2009 20:43 |
