04-26-2018, 11:15 | #1 (permalink) |
Freak Poster Join Date: Mar 2014 Location: NIGERIA
Member: 2156069 Status: Offline Sonork: Merujeffrey Thanks Meter: 69 | Firmware read-ok, write-error cm2mt2 Operation : Read Firmware [ v2.00 r1 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : PreLoader USB VCOM Port (COM281) MODE : PRELOADER PORT PORT : 281 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6755 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : PRELOADER PORT AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6755 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00040000 [ 256.00 KB ] DRAM: 0xC0000000 [ 3.00 GB ] EMMC: 150100525831424D4207A5B7AC038345 EMMC: VEN : SAMSUNG | OEM : 01 | DEV : RX1BMB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6750 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 368E2C303A6914F3B27D662482106519 DA : USB : HIGH-SPEED Boot done! Board Platform : mt6750 Build Time : 1474279665 Display ID : amigo3.5.0 Patch Level : MRA58K Product Info : gnbj6750_66_m Ver. CodeName : REL Ver. Release : 6.0 Sec. Patch : 2016-09-05 Product Board : GN5003 Product Brand : GIONEE Product Device : GiONEE_BBL7337A Product Manfct : GIONEE Product Model : GN5003 Product Name : GN5003 MT6750__GIONEE__GN5003__6.0__amigo3.5.0__MRA58K__g nbj6750_66_m Read : preloader.bin Read : recovery.img Read : proinfo.img Read : md1rom.img Read : md1dsp.img Read : md1arm7.img Read : md3rom.img Read : nvram.bin Read : lk.bin Read : boot.img Read : logo.bin Read : tz.img Read : secro.img Read : system.img ExtSparse : Compression ratio : 22% Read : cache.img Read : userdata.img Android Info saved : _Android_info.txt Scatter : MT6750_Android_scatter.txt Saved to : C:\Users\hp\Downloads\WORK\LAGOS\PLAYSTO\priv-app\gionee\GN5003\MT6750__GIONEE__GN5003__6.0__ami go3.5.0__MRA58K__gnbj6750_66_m\ Done! Elapsed: 00:10:09 Created by Infinity-Box (c) 2018 Chinese Miracle II : MediaTek Service Module Device Info file : _Android_info.txt Board Platform : mt6750 Build Time : 1474279665 Display ID : amigo3.5.0 Patch Level : MRA58K Product Info : gnbj6750_66_m Ver. CodeName : REL Ver. Release : 6.0 Sec. Patch : 2016-09-05 Product Board : GN5003 Product Brand : GIONEE Product Device : GiONEE_BBL7337A Product Manfct : GIONEE Product Model : GN5003 Product Name : GN5003 Operation : Write Flash [ v2.00 r1 ] Repartition : Enabled Flash Verify : Disabled Pre-Erase : Enabled Verify HW/SW : Enabled XData Backup : Disabled Files :17 [FL] : Set : preloader_gnbj6750_66_m.bin [FL] : Set : preloader_gnbj6750_66_m.bin [FL] : Set : recovery.img [FL] : Set : md1rom.img [FL] : Set : md1dsp.img [FL] : Set : md1arm7.img [FL] : Set : md3rom.img [FL] : Set : lk.bin [FL] : Set : lk.bin [FL] : Set : boot.img [FL] : Set : logo.bin [FL] : Set : tz.img [FL] : Set : tz.img [FL] : Set : secro.img [FL] : Set : system.img [FL] : Set : cache.img [FL] : Set : userdata.img [FL] : Total size : 0xD9D0E6E4 [ 3.40 GB ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : PreLoader USB VCOM Port (COM281) MODE : PRELOADER PORT PORT : 281 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6755 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : PRELOADER PORT AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6755 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00040000 [ 256.00 KB ] DRAM: 0xC0000000 [ 3.00 GB ] EMMC: 150100525831424D4207E22EE0D383DB EMMC: VEN : SAMSUNG | OEM : 01 | DEV : RX1BMB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6750 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : B1F22D3B7073D558BEB6367710FFE7D3 DA : USB : HIGH-SPEED Boot done! [FL] : RePartition [FL] : RePartition Ok! [FL] : Flashing now ... Write : PRELOADER Write : PRELOADER_BACKUP Write : RECOVERY Write : MD1IMG Write : MD1DSP Write : MD1ARM7 Write : MD3IMG Write : LK Write : LK2 Write : BOOT Write : LOGO Write : TEE1 Write : TEE2 Write : SECRO Write : SYSTEM ERR : 0xC0010002 ERR : ABORT ERR : 0x44200000|0xCE2DA7B0 Error : Flashing failed! Seems as some of MANDATORY section of FW is damaged! If device alive and work - send report! Reconnect Power/Cable! |
04-26-2018, 11:34 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Hello. Try repeat flashing again. 1. Try untick all images for flashing, except system, cache, userdata. or 2. Try untick system too and check just those 2 image flashing. |
02-12-2019, 15:31 | #6 (permalink) |
Freak Poster Join Date: Aug 2015
Member: 2439409 Status: Offline Thanks Meter: 104 | Operation : Write Flash [ v2.02 ] Repartition : Enabled Flash Verify : Disabled Reg.Pre-Erase : Disabled Verify HW/SW : Enabled SData Backup : Disabled Safe UserData : Disabled Files :14 [FL] : Set : preloader_oppo6750_16391.bin [FL] : Set : recovery.img [FL] : Set : md1arm7.img [FL] : Set : md3rom.img [FL] : Set : lk.bin [FL] : Set : lk.bin [FL] : Set : boot.img [FL] : Set : logo.bin [FL] : Set : trustzone.bin [FL] : Set : trustzone.bin [FL] : Set : secro.img [FL] : Set : system.img [FL] : Set : cache.img [FL] : Set : userdata.img [FL] : Total size : 0xF83A0891 [ 3.88 GB ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM158) MODE : PRELOADER PORT PORT : 158 Error : Failed to open port! Error : Fail to init protocol! Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! Operation : Write Flash [ v2.02 ] Repartition : Enabled Flash Verify : Disabled Reg.Pre-Erase : Disabled Verify HW/SW : Enabled SData Backup : Disabled Safe UserData : Disabled Files :3 [FL] : Set : system.img [FL] : Set : cache.img [FL] : Set : userdata.img [FL] : Total size : 0xF6437328 [ 3.85 GB ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM158) MODE : PRELOADER PORT PORT : 158 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6755 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : PRELOADER PORT MODE : Oppo : F3 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6755 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00040000 [ 256.00 KB ] DRAM: 0xC0000000 [ 3.00 GB ] EMMC: 150100524836344D4205038BCEE834AD EMMC: VEN : SAMSUNG | OEM : 01 | DEV : RH64MB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0xE8F800000 [ 58.24 GB ] CHIP : MT6750 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 99E80A5D1E811B5E527A47FB2361823 DA : USB : HIGH-SPEED Boot done! [FL] : HW verification passed! SEC_DL : False (RAPHAEL) SEC_ID : 0x494E46494E495459424F584245535432 [FL] : RePartition [FL] : RePartition Ok! [FL] : Flashing now ... Write : SYSTEM Write : CACHE Write : USERDATA SEC_DL : False (RAPHAEL) SEC_ID : 0x494E46494E495459424F584245535432 [FL] : RePartition [FL] : RePartition Ok! [FL] : Flashing finished! Done! Elapsed: 00:02:28 Reconnect Power/Cable! |
02-12-2019, 15:32 | #7 (permalink) |
Member: 2439409 Status: Offline Thanks Meter: 104 | Operation : Write Flash [ v2.02 ] Repartition : Enabled Flash Verify : Disabled Reg.Pre-Erase : Disabled Verify HW/SW : Enabled SData Backup : Disabled Safe UserData : Disabled Files :16 [FL] : Set : preloader_oppo6750_16391.bin [FL] : Set : recovery.img [FL] : Set : md1rom.img [FL] : Set : md1dsp.img [FL] : Set : md1arm7.img [FL] : Set : md3rom.img [FL] : Set : lk.bin [FL] : Set : lk.bin [FL] : Set : boot.img [FL] : Set : logo.bin [FL] : Set : trustzone.bin [FL] : Set : trustzone.bin [FL] : Set : secro.img [FL] : Set : system.img [FL] : Set : cache.img [FL] : Set : userdata.img [FL] : Total size : 0xF96A0221 [ 3.90 GB ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM158) MODE : PRELOADER PORT PORT : 158 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6755 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : PRELOADER PORT MODE : Oppo : F3 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6755 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00040000 [ 256.00 KB ] DRAM: 0xC0000000 [ 3.00 GB ] EMMC: 150100524836344D4205038BCEE834AD EMMC: VEN : SAMSUNG | OEM : 01 | DEV : RH64MB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0xE8F800000 [ 58.24 GB ] CHIP : MT6750 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 99E80A5D1E811B5E527A47FB2361823 DA : USB : HIGH-SPEED Boot done! [FL] : HW verification passed! SEC_DL : False (RAPHAEL) SEC_ID : 0x494E46494E495459424F584245535432 [FL] : RePartition [FL] : RePartition Ok! [FL] : Flashing now ... Write : PRELOADER Update bootloader backup copy ... Update bootloader backup copy Ok! Write : RECOVERY Write : MD1IMG Error : Flashing failed! Seems as some of MANDATORY section of FW is damaged! If device alive and work - send report! Reconnect Power/Cable! |
02-12-2019, 18:33 | #8 (permalink) | |
No Life Poster Join Date: Dec 2004 Location: Uganda Age: 45
Member: 96478 Status: Offline Sonork: 100.1674604 Thanks Meter: 1,420 | Quote:
New Updates was made for Use Not for Fun ! http://forum.gsmhosting.com/vbb/13526354-post1.html | |
The Following 2 Users Say Thank You to Kirumira For This Useful Post: |
02-12-2019, 22:15 | #9 (permalink) | |
result ? | |
