Old 06-16-2010, 15:02   #1 (permalink)
Member: 1122479
Thanks Meter: 22
Firmware reading problem
COM40 [VCP0] selected
module v3.15
Device: Autodetect 6228-6239 NAND
Checking data, wait...
Action: read flash NAND
interface: BROM_DLL_v3.1012.00
Connect...
Connecting...
Booting...
Release Power button now !
bootcode current/expected: 3.2/3.2
CPU: 6235:8A04:8A01
status: FF
bbchip bl ver: FE
NOR flash chip: not installed
NAND flash id[0006]: 00EC:00A100000015 [SAMSUNG] K9F1G08Q0M
chip size: 128Mb
page/spare size: 0800/0040
pages per block: 0040
bits i/o: 08
address cycles: 04
internal RAM size: 00010000
external RAM: S_DA_RAM_ERROR
done
Set baudrate (921600)...
done
ram test...
testing...
ram test passed
===> detect existing firmware structure...
detect ffs...
ffs offset/size: 02620000/059E0000
firmware size: 38Mb
ffs size: 89Mb
detect sec ro...
detect custom parameters...
detect project-id...
project-id: M800_YJS_IP_MLA_18V_T03S0322
detect NAND info...
number of areas/bytes to read: 1:001A0000
reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)...
nfi area detection...
bootloader version: RATECH35_08B_BOOTLOADER_V005_MT6235B_M800_YJS_IP_M LA_18V_T03S032
nfi area detection finished: Ok
TCL-ID detection...
TCL-ID detection done
startup code area #1 detection...
startup code area #1 detection done
rom info ver: 07
sw version: RATECH35_08B_PCB01_GPRS_MT6235B_S01.M800_YJS_IP_ML A_18V_T03S0322.BIN
project-id: M800_YJS_IP_MLA_18V_T03S0322, 00000000
code offset: 00000000
ffs offset/size [01]: 02620000/059E0000
rom info structure: 2nd [standard] generation
TCL-ID is absent
===> done
New firmware detected (v.3.15, database date: 06.06.2010):
This firmware is missing in support area. If this phone is good and working:
- download latest software from support area and try again, probably this firmware already supported in latest software
- make "Read full flash" operation
- send flash backup files to support: [email protected] or upload files to RapidShare: 1-CLICK Web hosting - Easy Filehosting or 4shared.com - free file sharing and storage
- include in your e-mail full text from phone back label (phone name etc.)
area size: 128Mb
number of areas/bytes to read: 1:08000000
error: can not read memory: 0FAA:S_FT_READBACK_FAIL
error: last error: 0FAA:S_FT_READBACK_FAIL
Disconnect...
done
Finished, time used: 7 min 27 sec
Remove/Install battery now !\
is this cpu supported? by chinese miracle and also language translator?
Old 06-17-2010, 18:49   #2 (permalink)
Member: 1043909
Thanks Meter: 60,926
Hello,
This hardware configuration is supported (at least by ChineseMiracle). Language Editor - it will be need to test it when we will get flash backup.
Please, double check that you have at least 256 Mb free space at your HDD and that phone battery is enough charged and try to read flash again.
Old 06-21-2010, 11:16   #3 (permalink)
Member: 1122479
Thanks Meter: 22
ok i read it well with full charged battery
this is link to full flash
The Following User Says Thank You to seba6250 For This Useful Post:
Old 06-21-2010, 16:38   #4 (permalink)
Member: 1043909
Hello,
Thank you very much !
We will check, prepare and upload files in support area as soon as possible.
How to upload a new firmware... Brand Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-08-2012 18:29
Eeprom reading KLImax Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 09-22-2011 15:55
HELP: Problem with 5110 Xabi Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 07-16-1999 00:44
Page generated in 0.18660 seconds with 9 queries
