[Firmware Request] I9060i MT6577 More info inside ! info about my request Quote:
Chinese Miracle II [MTK module] v 1.42
Start at : [04/03/16 / 19:21:25]
Operation : Check / Read Info [ v1.42 ]
Wait for phone...
Phone found! [ 168 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6575
BB_CPU_NME : [MediaTek] MT6575|MT6577_S00
BB_CPU_EXT : 0xCB00 , 0x8B00 , 0xE201
Processing BROM stage
i2c Init : 00008810
SpeedSet : 0000
VChrgSet : 0x28 , BatStat : 0x82
WD Disable stat : 0x0000
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x0005
BLVersion : 0x00FE
PreLoader : NOT Active [ Erased ]
BootLdrSS : NORMAL with SPRELOADER
Processing DA stage
DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01
Sending and initialize DA ...
Running DA ver.3.2 on BBID : 0x84
Initialize Memory ...
eMMC FlashIC initialized
[eMMC] : FLASH_INF : [SAMSUNG] , M00SJ
[eMMC] : FLASH_CID : 150100534A5330304D00E6B86A204FE7
[eMMC] : FLASH_BRT : 0x00100000 , 0x00100000 , 0x00020000
[eMMC] : FLASH_LEN : 0x00000000E9000000
[eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB]
DEV RID : BBFDD1FC5DC1DE60A24F5801DDD87D33
INT RAM : 0x00020000
EXT RAM : 0x00000000
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
[AP] : Initial info read Ok!
ProdName : GT-I9060I
ProdModel : GT-I9060I
Device : Samsung GT-I9060I
AndroidVer: 4.4.4
MTKxCPU : MT6577
MTKxPRJ : I8552ZCAME1
i tried with this firmware but look like not compatible Quote:
Scatter Load Ok , BaseBand : MT6577 , Project : MTK6577 , Storage : eMMC
Files found : 12 , Set to Flash : 11
Created by Infinity-Box (c) Chinese Miracle II (c) 2016
Device Model : Samsung GT-I9060I
Device CPU : MT6577
Device IntName : GT-I9060I
Device Version : 4.4.4
Device Compile : 10/12/15 06:36:45
Device Project : I8552ZCAME1
Device ExtInfo : GT-I9060I
Ready to Flash!
| Quote:
Device CPU : MT6577
Ready to Flash!
Start at : [04/03/16 / 19:29:27]
Operation : Flash [ v1.42 ]
======= Flash
Wait for phone...
Phone found! [ 132 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6575
i2c Init : 00008810
SpeedSet : 0000
BromVer : 0x0005
BLVersion : 0x00FE
Processing DA stage
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6577 , Project : MTK6577 , Storage : eMMC
Setting : AFF verify : Disabled
Setting : HW verify : Enabled
Switching to HSUSB
HSUSB Init Ok
DRAM not initialized , will try init now
DRAM init passed , 0x20000000
BL : Check HW compatibility
BL : Check eMMC compatibility
BL : Old Dedvice , skip BatteryLevel check
BL : Flash Pre-Erase
Total blocks to Erase : 2
Erase : 0x0000000000600000-0x000000000000C000
Erase : 0x000000000232C000-0x00000000817C0000
Flash Pre-Erase Done, time used : 00:00:06
SecCfg Passed , 1799
BMT remark not need. Will skip
Sending Preloader ...
Use : preloader_hexing77_jb.bin Preloader Init Failed! Looks like HW error or incompatible image
ErrCode :
Operation Failed
Elapsed: 00:00:19
Reconnect Power/Cable!
| pleas any compatible Firmware
Regards |
