01-22-2016, 08:08 | #1 (permalink) |
Freak Poster Join Date: Apr 2006 Location: Antalya Age: 52
Member: 255526 Status: Offline Sonork: 100.1611607 Thanks Meter: 27 | [Firmware Request] MT6572__ALPS__G9200__ALPS.KK1.MP6.V1__Android_4.4. 2 Wait for phone... Phone found! [ 23 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 11010030303447453001E2CCCB72C18F DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0011 , OEM : 0100 [eMMC] : FLASH_INF : [TOSHIBA] , 0EG40 [eMMC] : FLASH_CID : 11010030303447453001E2CCCB72C18F [eMMC] : FLASH_EXT : 0x00200000 , 0x00200000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000EC000000 [eMMC] : FLASH_UCP : 3776 MiB INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... Read Ok , collect info Brand : alps ProdName : rtech72_we_72_kk ProdModel : G9200 Device : rtech72_we_72_kk AndroidVer: 4.4.2 MTKxCPU : MT6572 MTKxPRJ : ALPS.KK1.MP6.V1 Saved to : C:\InfinityBox\CM2MTK\Flash\MT6572__ALPS__G9200__A LPS.KK1.MP6.V1__Android_4.4.2__10.04.2015.ispff Done! Elapsed: 00:15:10 Reconnect Power/Cable! Hardware : MT6572 Model : G9200 Build number : ALPS.KK1.MP6.V1 Build date UTC : 20150410-100916 Android v : 4.4.2 Baseband v: MOLY.WR8.W1315.MD.WG.MP.V36,2015/03/18 10:35 Kernel v : 3.4.67(rs@rs-ThinkStation-D30) (gcc version 4.7 (GCC) ) #1 SMP Fri Apr 10 16:50:32 CST 2015 Uboot build v : ----- should be root shell LCD Driver IC : 1-mtk_mt6572m_ILI9807_dsi_vdo_boe |
The Following User Says Thank You to yalcin_g For This Useful Post: |
01-22-2016, 12:30 | #2 (permalink) | |
No Life Poster Join Date: Nov 2015
Member: 2488031 Status: Offline Sonork: 100.1662695 Thanks Meter: 1,947 | Quote:
The Following User Says Thank You to Suny125 For This Useful Post: |
01-25-2016, 12:11 | #4 (permalink) |
No Life Poster Join Date: Dec 2015 Location: hossting
Member: 2501288 Status: Offline Thanks Meter: 328 | this rom will work with your phone just make backup nv + Factory firmware before flash ROM 1:1 Jiake G9200 | [Official] add the 08/06/2015 on Needrom |
02-25-2016, 10:16 | #5 (permalink) | |
Member: 255526 Status: Offline Sonork: 100.1611607 Thanks Meter: 27 | Quote:
PHONE DEAD ldc driver incompatible | |
02-25-2016, 16:06 | #6 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | New method to upload firmware files to support area - Flash Files Database - iosFileUploader New method to download firmware files from support area - Flash Files Torrent system |
06-25-2018, 06:45 | #8 (permalink) |
No Life Poster Join Date: Mar 2011 Location: Faisalabad
Member: 1527968 Status: Offline Sonork: 100.1651182 Thanks Meter: 483 | 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 242 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 8801034E4361726420296B433F6012D9 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x88 , OEM : 0103 [eMMC] : FLASH_INF : [FORESEE] , draC [eMMC] : FLASH_CID : 8801034E4361726420296B433F6012D9 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00020000 [eMMC] : FLASH_LEN : 0x00000001CE100000 [eMMC] : FLASH_UCP : 7393 MiB [eMMC 8 GiB] DEV RID : 0x05E7B28EFF4D4FD8E30C09CA59727617 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Content now ... Brand : alps ProdName : d610 ProdModel : d610 Device : d610 AndroidVer: 4.4.2 MTKxCPU : MT6572 MTKxPRJ : ALPS.KK1.MP6.V1 [Read Ok] : preloader_d610.bin [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : custom.img [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [ScatCFG] : MT6572 / V1.1.1 / d610 / EMMC Android Info saved MAUI Meta DB saved HWConfig Info saved FW Size : 881 MiB Scatter saved to : C:\Users\alimobile\Desktop\MT6572__alps__d610__d61 0__4.4.2__ALPS.KK1.MP6.V1\ All done! Done! Elapsed: 00:06:47 Reconnect Power/Cable! upload start on sport |
06-25-2018, 08:20 | #9 (permalink) |
No Life Poster Join Date: Feb 2017 Location: Quelimane Mz Age: 26
Member: 2680008 Status: Offline Thanks Meter: 1,639 | Dear Sirs, If you have good flash files and if you want to share it with other users please use IOS File Uploader Tool Please do not upload password protected or damaged files, all of them will be deleted after upload. Thank you ! Enviado do meu SM-J100H através do Tapatalk |
