05-30-2015, 13:21 | #1 (permalink) |
Freak Poster Join Date: Nov 2010 Location: CHOLOMAN
Member: 1440339 Status: Offline Sonork: 100.1616914;CHOLOMAN Thanks Meter: 116 | ..::FIRST in UNIVERSE SMART 311 (MT6573) DONE::.. 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 18 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6573 BB_CPU_HW : CA10 BB_CPU_SW : CA01 BB_CPU_SB : CA01 BB_CPU_NM : [MediaTek] MT6573_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending DA Stat : v3.2 on BBID : 0x83 DA Sent. Configure setting now ... DA started successuflly NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0056 , [HYNIX] HY27UF082G2M [NAND] : FLASH_DIE : 00AD 00BC 0090 0055 0054 0000 0000 [NAND] : FLASH_LEN : 0x20000000 INT RAM : 0x00020000 EXT RAM : 0x00000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... USBDL : Init HSUSB Ok! Read Ok , collect info Brand : BIRDA ProdName : bird13_gb ProdModel : Android Device : bird13_gb AndroidVer: 2.3.6 MTKxCPU : MT6573 MTKxPRJ : 11K7_SMART_S14_WVGA_EN_V02_20121128_M Saved to : C:\InfinityBox\CM2MTK\Flash\MT6573__BIRDA__Android __11K7_SMART_S14_WVGA_EN_V02_20121128_M__Android_2 .3.6__20121128_022822.ispff Done! Elapsed: 00:08:40 Reconnect Power/Cable! FORMAT USER AREA: Operation : Format FileSystem [ v1.21 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 18 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6573 BB_CPU_HW : CA10 BB_CPU_SW : CA01 BB_CPU_SB : CA01 BB_CPU_NM : [MediaTek] MT6573_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending DA Stat : v3.2 on BBID : 0x83 DA Sent. Configure setting now ... DA started successuflly NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0056 , [HYNIX] HY27UF082G2M [NAND] : FLASH_DIE : 00AD 00BC 0090 0055 0054 0000 0000 [NAND] : FLASH_LEN : 0x20000000 INT RAM : 0x00020000 EXT RAM : 0x00000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Format : Cache and UserData (Full Factory Reset) Format CACHE block Format block Ok! Format UDA block Format block Ok! Done! Elapsed: 00:00:21 Reconnect Power/Cable! |
The Following User Says Thank You to .::JYOTIRMAY::. For This Useful Post: |
