01-22-2016, 21:03 | #1 (permalink) |
No Life Poster Join Date: Jul 2013 Location: in my company
Member: 1984825 Status: Offline Thanks Meter: 222 | Flash done i9060 mtk6575 with great cm2 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 32 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6575 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : E201 BB_CPU_NM : [MediaTek] MT6575|MT6577_S00 Processing BROM stage i2c Init : 00000000 SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x02 WD Disable stat : 0x0000 BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 DA Stat : v3.2 on BBID : 0x84 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , HYNIX [eMMC] : FLASH_CID : 90014A2058494E594816A19538C48019 [eMMC] : FLASH_EXT : 0x00200000 , 0x00200000 , 0x00200000 [eMMC] : FLASH_LEN : 0x00000000E7000000 [eMMC] : FLASH_UCP : 3696 MiB INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! IMEI [00] : 358688000000158 IMEI [01] : 358688000000158 IMEI [02] : 358688000000158 IMEI [03] : 358688000000158 Set IMEI [00] : 355396058205793 Set IMEI [01] : 355370058205798 Prepare finished. Security check required! Wait for phone... Phone found! [ 32 ] Sync... PostCheck Ok! Repair done! Done! Elapsed: 00:00:42 Reconnect Power/Cable! |
The Following User Says Thank You to tikourine For This Useful Post: |
