07-06-2009, 17:51 | #1 (permalink) |
No Life Poster Join Date: Dec 2005 Location: mt brazil
Member: 211017 Status: Offline Thanks Meter: 312 | Flash error COM3 [VCP0] selected module v2.84 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: write NOR flash "smart write" active write: Firmware skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ffs/eeprom backup enabled, it may takes several minutes ! Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:3003:0008 status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:968CC500000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:968CC500000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #02 in region #00... flash: EC257E25082501:968CC500000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #03 in region #00... flash: EC257E25082501:968CC500000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 460800 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: EC257E25082501:968CC500000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:968CC500000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 96E2C58C1A376EDCB871E3C68D1A356A3C68D0A0C182050D number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... . detection phase #2... .................................................. .................................................. .................................................. .................................................. .................................................. ...... warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . detect device identification#2 finished detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset assigned: 00E00000 flash: EC257E25082501:968CC500000000 checking area [00000000]: 00000000-00FFFFFF... ffs/eeprom found near: 00600000 Detected ffs/eeprom address is non-standard: 00600000 Posible reasons: 1. ffs/eeprom is Ok but address is non-standard 2. ffs/eeprom is damaged and can't be detected 3. ffs/eeprom is Ok but detected incorrectly (f.e. unknown ffs/eeprom structure) If you are not sure that detected address is correct: 1. press "NO" (and select standard address or terminate current operation) 2. make full flash backup for emergency case 3. repeat required operation Are you sure that detected ffs/eeprom address is correct ? autodetected ffs/eeprom address confirmed by user: 00600000 detecting ffs/eeprom size... ffs/eeprom size: 00A00000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00600000-00FFFFFF Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: _ffs... file saved: C:\Arquivos de programas\InfinityBox\ChineseMiracle\_ffs_20090706-123900.B0E.bin flash: EC257E25082501:968CC500000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... detect device identification#1... detection phase #1... . detection phase #2... .................................................. .................................................. .................................................. .................................................. .................................................. ...... warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . detect device identification#2 finished detecting security area (code #2)... security area (code #2) is absent Area: Firmware flash: EC257E25082501:968CC500000000 Write: Firmware error: error# 00000024 error: flash write error: 00802000:00002000 error: error# 00000024 error: flash write error: 00802000:00002000 error: error# 00000024 error: flash write error: 00802000:00002000 error: error# 00000024 error: flash write error: 00802000:00002000 error: error# 00000024 error: flash write error: 00802000:00002000 error: error# 00000024 error: flash write error: 00802000:00002000 error: error# 00000024 error: flash write error: 00802000:00002000 error: error# 00000024 error: flash write error: 00802000:00002000 detect device identification#2... detection phase #1... . detect device identification#2 finished Write Fail Finished, time used: 1056 sec Remove/Install battery now ! Original flash file of the A968 is: E880_JJF2F12TRI_MT6225S00.GM_01_0_20080711__fullfl ash_20090702-133054.B0M cell no power help-me, infinity team |
N96 Weird Flashing error | javakiller | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 14 | 10-10-2010 11:55 |
1650 flash error | nilesh_patel717 | Nokia Hardware & Hardware Repair | 3 | 03-29-2010 14:03 |
My-411x wont flash error Flash error (#9.1) | Mr.3. | SAGEM JTAG UNLOCKER | 3 | 01-15-2010 05:36 |
Flash colour/cid mismatch ,script error : Flash error (10.43.77) | mccm | Cruiser Suite | 18 | 05-22-2007 05:47 |
