01-15-2010, 02:36 | #1 (permalink) |
No Life Poster Join Date: Jun 2006
Member: 303402 Status: Offline Thanks Meter: 346 | need update LanguagePackEdit for supporting mt6235 i want to change edit language into indonesia n97 copy here the log language pack editor Code: Editor version: [1.28] Detected crypted Chinese Miracle file... Crypted fullflash loaded Loading fullflash file... OK -------------------------------------------------------------------------------------------------------------- MTK Rom Info Version: 07 ROM version: W35_08B_PCB01_GPRS_MT6235B_S01.MAUI_08B_W09_16_MP_V12.BIN MCU version: MAUI.08B.W09.16.MP.V12 Build time: 2009/12/01 12:52 Hardware: W35_08B_HW -------------------------------------------------------------------------------------------------------------- Detected NAND firmware... -------- NAND Flash info -------- Page size in bytes: 0x0200 Block size in pages: 0x0020 Flash size in blocks: 0x1000 ------------------------------------ Detected spare bytes, clear fullflash from it... Error! Please, contact support! Code: COM9 [VCP10] selected module v3.06 Device: Autodetect 6228-6239 NAND Checking data, wait... Action: read firmware NAND interface: BROM_DLL_v3.932.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! CPU: 6235:8A04:8A01 bbchip secure ver: FF bbchip bl ver: FE NOR flash chip: S_DA_NOR_FLASH_NOT_FOUND NAND flash chip: S_DONE flash id[0017]: 00AD:007600AD0076 [HYNIX] HY27XS08121M flash size: 64Mb page/spare size: 0200/0010 pages/block: 0020 bits i/o: 08 address cycles: 04 internal RAM: S_DONE size: 00010000 external RAM: S_DA_DEVICE_NOT_FOUND boot style: S_NAND_FLASH_BOOT bootcode current/expected: 3.2, 3.2 done Set baudrate (921600)... done ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 02000000/02000000 firmware size: 32Mb ffs size: 32Mb detect sec ro... detect custom parameters... detect project-id... project-id: MAUI.08B.W09.16.MP.V12 detect NAND info... number of areas to read: 1 reading (HW_STORAGE_NAND)... nfi area detection... bootloader version: W35_08B_BOOTLOADER_V005_MT6235B_MAUI_08B_W09_16_MP_V12.bin nfi area detection finished: Ok TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 07 sw version: W35_08B_PCB01_GPRS_MT6235B_S01.MAUI_08B_W09_16_MP_V12.BIN project-id: MAUI.08B.W09.16.MP.V12, 00000000 code offset: 00000000 ffs offset/size [01]: 02000000/02000000 rom info structure: 2nd [standard] generation TCL-ID is absent ===> done ==================== New firmware detected (v.3.06, database date: 13.01.2010): W35_08B_PCB01_GPRS_MT6235B_S01.MAUI_08B_W09_16_MP_V12.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) ==================== area size: 32Mb number of areas to read: 1 reading (HW_STORAGE_NAND)... please...give a update to support file mt6235..i want to change into indonesia.. thanks advance aswancamel |
The Following 2 Users Say Thank You to aswancamel For This Useful Post: |
01-15-2010, 17:05 | #3 (permalink) |
Product Supporter Join Date: Nov 2001 Location: Donetsk, DPR Age: 42
Member: 7436 Status: Offline Thanks Meter: 400 | I hard working now on support this CPU and making other function, after all be done, release be on support. |
The Following User Says Thank You to s.Mobi For This Useful Post: |
01-24-2010, 21:07 | #4 (permalink) |
Member: 303402 Status: Offline Thanks Meter: 346 | New n97 mini III, with mtk 6225 new detected mt6225 pinout, in handsfree i have not sent to support here the picture Code: COM9 [VCP2] selected module v3.07 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: read flash ====> Boot ... Press and HOLD Power button now ! baud autodetection active 19200 autodetect Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot Off chip: 0001:1A03:0004 status: FF high speed boot Off boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01227E223C2200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb detecting chip #01 in region #00... flash: 01227E223C2200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb number of flash chip/regions detected: 02/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 01227E223C2200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb detecting chip #01 in region #00... flash: 01227E223C2200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 02000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is absent rom info detection finished ==================== New firmware detected (v.3.07, database date: 16.01.2010): 6225_GEMINI_PCB01_GPRS_MT6225_S00.V8_2SIM_V091028A.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info ver: 04 sw version: 6225_GEMINI_PCB01_GPRS_MT6225_S00.V8_2SIM_V091028A.BIN project-id: V8_2SIM_V091028A, 00000000 code offset: 00000000 ffs offset/size [01]: 01C00000/00400000 rom info structure: 2nd [standard] generation TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 01C00000 standard ffs/eeprom offset confirmed: 01C00000 detecting ffs/eeprom size... ffs/eeprom size: 00400000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:01C00000-01FFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished detecting firmware version... firmware version: 6225_GEMINI_PCB01_GPRS_MT6225_S00.V8_2SIM_V091028A.BIN detecting firmware build... ................................................................................................................................ ................................................................................................................................ done detecting product-id... ................................................................................................................................ done detecting languages... .............................................................................. language parameters detected detected languages: En Ru Fr Es Ml Id Th Vn Cn Tr Farsi Pt Cn Ar Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: 6225_GEMINI_PCB01_GPRS_MT6225_S00.V8_2SIM_V091028A__fullflash... http://www.4shared.com/file/20613848...S_MT6225_.html br aswancamel |
03-16-2010, 19:57 | #10 (permalink) |
No Life Poster Join Date: Feb 2003 Location: TelServisHalo,Loznica, Serbia Age: 53
Member: 21365 Status: Offline Thanks Meter: 92 | Well... ...I hope soon will be updated Editor version: [1.28] Detected crypted Chinese Miracle file... Crypted fullflash loaded Loading fullflash file... OK -------------------------------------------------------------------------------------------------------------- MTK Rom Info Version: 07 ROM version: RATECH35_08B_PCB01_GPRS_MT6235B_S01.M97_HT_FM_KEY2 _091209.BIN MCU version: M97_HT_FM_KEY2_091209 Build time: 2009/12/09 20:45 Hardware: RATECH35_08B_HW -------------------------------------------------------------------------------------------------------------- Detected NAND firmware... -------- NAND Flash info -------- Page size in bytes: 0x0800 Block size in pages: 0x0040 Flash size in blocks: 0x0400 ------------------------------------ Detected spare bytes, clear fullflash from it... Error! Please, contact support! |
please update list for support bb5 phone | tynch000 | Cyclonebox | 0 | 01-02-2010 16:33 |
Need dismantle documents for supported phones | eblaster101 | BB5BOX | 1 | 11-26-2007 20:19 |
NEC 411 / 411i needed , please read for support ! | julvir | Redbox | 4 | 05-06-2006 15:02 |
I need updated flash for 5100 | Kim | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 05-31-2005 01:01 |
need name/pass for support area!!! | sale | UST Pro II | 2 | 12-24-2004 08:32 |
