Old 03-16-2010, 14:36   #1 (permalink)
Member: 159105
Thanks Meter: 57
flash error with any phone
sfr 342
==== [16/03/2010 13:11:03] ====
COM4 [VCP1] selected
module v3.18
Device: SFR-342
Checking data, wait...
Action: write flash
"smart write" active
skip: Firmware
skip: Customization/Language Pack
skip: Customization
write: Eeprom/ffs
SFR-342_ZTEMT25_08B_GEMINI_PCB01_GPRS_MT6225_S00.X960_ V2_Z0_C1_BFFA109__ffs_20100316-121744.B0E.bin
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A05:8A00]...
CPU: MT6225
chip: 0001:AD03:0005
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
====> Initialize ...
flash: 01227E22202200:18E59F00000000
flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb
otp offset: 00000000
Initialize Done
====> Set baud ...
115200
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
rom info structure: 2nd [enhanced] generation
TCL-ID is absent
startup code area #1 is Ok
startup code area #1 backup saved: E:\Program Files\InfinityBox\MModule\backup_security\id.29374 E81.[ZTEMT25_08B_GEMINI_PCB01_GPRS_MT6225_S00.X960_V2_Z 0_C1_BFFA109.BIN_3BB1F073].rpl
rom info detection finished
device-id: 29374E81
rom info ver: 05
sw version: ZTEMT25_08B_GEMINI_PCB01_GPRS_MT6225_S00.X960_V2_Z 0_C1_BFFA109.BIN
project-id: X960_V2_Z0_C1_BFFA109, 73F0B13B
code offset: 00000000
ffs offset/size [01]: 00E00000/00200000
TCL-ID is absent
ffs/eeprom address assigned: 00E00000
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
Backup required data Done
====> Patch required data ...
Patch required data Done
====> Special operation ...
Special operation Done
====> Write ...
file saved: E:\Program Files\InfinityBox\MModule\backup_security\SFR-342_ZTEMT25_08B_GEMINI_PCB01_GPRS_MT6225_S00.X960_ V2_Z0_C1_BFFA109__system_log_29374E81_3BB1F073_201 00316-131200.B0X.bin
Area: Eeprom/ffs
Write: Eeprom/ffs
error: error# 000000FF
error: flash write error: 00E00000:00002000
2E3B3B3BEB2E3B3B3BF62E3B3B3BB23B3B3B3B1A2E3B3B3BDC 2E3B3B3BDC2E3B3B3BFC2E3B3B3BE12E3B3B3BFD2E3B3B3B74 2E3B3B3B032E3B3B3B032E3B3B3B032E3B3B3B031A2E3B3B3B DC2E3B3B3B002E3B3B3B762E3B3B3BFC2E3B3B3BFC2E3B3B3B FC2E3B3B3BFC2E3B3B3B9D2E3B3B3BFC2E3B3B3BBF2E3B3B3B FC1A2E3B3B3BFC2E3B3B3B9D
error: write operation failed
Write Fail
file saved: E:\Program Files\InfinityBox\MModule\backup_security\SFR-342_ZTEMT25_08B_GEMINI_PCB01_GPRS_MT6225_S00.X960_ V2_Z0_C1_BFFA109__system_log_29374E81_3BB1F073_201 00316-131212.B0X.bin
Finished, time used: 1 min 4 sec
Remove/Install battery now !
==== E:\Program Files\InfinityBox\MModule\MModule.exe [16/03/2010 13:14:04] ====
Loading data, wait...
[Infinity Box] MModule v3.18
smart-card: connected
S/N: 1168:0116
Wait...
Device: SFR-342
Done
==== [18/02/2010 12:19:18] ====
COM157 [VCP1] selected
module v3.08
Device: Autodetect 6205-6227 NOR
Action: "sp-unlock"
unlock method: standard
ffs/eeprom backup enabled, it may takes several minutes !
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6227:8A02:8A01]...
CPU: MT6227
high speed boot Off
chip: 0031:628E:79CA
status: FF
high speed boot Off
Boot Done
flash: B0001D00000000:B0001D00000000
flash: Sharp Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
====> Set baud ...
115200
Set baud Done
device parameters detection in progress...
it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
rom info structure: 2nd [standard] generation
TCL-ID is absent
New firmware detected (v.3.08, database date: 08.02.2010):
EF80_LEVIS_GREEK_PCB01_GPRS_MT6227_S01.EF80.06A.W0 6.36.MP.V36.F2.BIN
This firmware is missing in support area. If this phone is good and working:
- download latest software from support area and try again, probably this firmware already supported in latest software
- make "Read full flash" operation
- send flash backup files to support: [email protected] or upload files to RapidShare: 1-CLICK Web hosting - Easy Filehosting or 4shared.com - free file sharing and storage
- include in your e-mail full text from phone back label (phone name etc.)
rom info ver: 04
sw version: EF80_LEVIS_GREEK_PCB01_GPRS_MT6227_S01.EF80.06A.W0 6.36.MP.V36.F2.BIN
project-id: EF80.06A.W06.36.MP.V36.F2, 00000000
TCL-ID is absent
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 00E00000
standard ffs/eeprom offset confirmed: 00E00000
detecting ffs/eeprom size...
ffs/eeprom size: 00200000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00E00000-00FFFFFF
detecting startup code area #2...
startup code area #2 is absent
detecting ffs/eeprom structure pass 1...
detect standard ffs/eeprom location pass #1...
detect extended ffs/eeprom location pass #1...
detect standard ffs/eeprom offset pass #1...
ffs/eeprom record offset detected
detect standard ffs/eeprom data...
ffs/eeprom record size detected
ffs/eeprom layout detection complete
ffs/eeprom detected ok: element #1
reading: EF80_LEVIS_GREEK_PCB01_GPRS_MT6227_S01.EF80.06A.W0 6.36.MP.V36.F2__ffs...
file saved: D:\EF80_LEVIS_GREEK_PCB01_GPRS_MT6227_S01.EF80.06A .W06.36.MP.V36.F2__ffs_20100218-122511.B0E.bin
detection procedure, wait...
detection procedure completed
====> Write ...
Write: ffs
error: flash write error: 00E40000:00002000
2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC 2E3B3B3BFC2E3B3B3B642E3B3B3BFA1A2E3B3B3BFC2E3B3B3B EE2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC2E3B3B3BFF2E3B3B3B FC2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC2E3B3B3B FC2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC2E3B3B3B FC2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC2E3B3B3B FC2E3B3B3BFD2E3B3B3BFC2E3B3B3BFC2E3B3B3B772E3B3B3B FC2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC2E3B3B3B FC2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC2E3B3B3B FC2E3B3B3B462E3B3B3BEC2E3B3B3B151A2E3B3B3B462E3B3B 3BFC2E3B3B
operation aborted
Write Fail
Finished, time used: 6 min 24 sec
Old 03-16-2010, 18:31   #2 (permalink)
tajinder's Avatar
Member: 181825
Thanks Meter: 182
try to flash on other pc
Old 03-16-2010, 22:37   #3 (permalink)
Member: 1043909
Thanks Meter: 49,146
@elgato
As I can see it was one error month ago [18/02/2010 12:19:18] and next was today.
If you have this kind of errors once a month with different phones you must use completely charged battery and check your cable.
Also I strongly suggest you next time to make correct name for your thread and never lie.
Old 03-18-2010, 20:17   #4 (permalink)
Member: 159105
Thanks Meter: 57
iuse spderman for detecting pinout is not power probleme sam probleme with cable com and battery full charged
ps im not liar
Old 03-18-2010, 22:28   #5 (permalink)
Member: 1043909
Yes, I see now that you are not liar, but it it quite strange when people post 2 logs (with 1 month time difference) and start to talk about "problems with all phones".
be smarter, do not post logs as is, just edit date/time inside log and in this case you will be sure that nobody can understand when you have made your tries.
I suggest you double check your cable, probably you must use better cable and better connectors and I am sure that it will be no problems in future if you will use other cable and completely charged battery and when you will be sure that phone hardware is completely well but is not damaged.
problem flashing with usb with any phone ! please help johnlee007 Universalbox 17 01-09-2010 15:03
errors connecting any phones!!! ionelka FuriousGold 1 10-12-2007 14:13
erro in DB doesnt conect with any phone mr_rocco DreamBox 2 03-23-2006 17:17
Flashing error 103, any idea? hoang LG 35 10-17-2005 10:57
Page generated in 0.34014 seconds with 8 queries
