Old 03-15-2016, 13:26   #1 (permalink)
Member: 2203712
Sonork: 100.1667064
Thanks Meter: 79
Flash error solution
TECNO F7
PHONE CONDITION: DEAD
WHEN TRYING TO FLASH, THIS IS THE ERROR THAT I GET.
TRIED 3 DIFFERNET FIRMWARES BUT SAME ERROR
SOLUTION NEEDED
Chinese Miracle II  [MTK module] v 1.43
Scatter Load Ok , BaseBand : MT6589 , Project : MTK6589 , Storage : eMMC
Files found : 10 , Set to Flash : 9
Ready to Flash!
Operation : Flash [ v1.43 ]
======= Flash
Wait for phone...
Phone found! [ 11 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6583
BB_CPU_NME : [MediaTek] MT6583|6589_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer   : 0x00FF
BLVersion : 0x0001
BootLdrSS : NORMAL with SPRELOADER
Processing DA stage
DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01
Sending and initialize DA ...
Running DA ver.3.2 on BBID : 0x86
NAND Flash : NOT INSTALLED
eMMC Flash : 204A0190594E49589CA116487790C02F
Initialize Memory ...
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , HYNIX
[eMMC] : FLASH_CID : 90014A2058494E594816A19C2FC09077
[eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00200000
[eMMC] : FLASH_LEN : 0x00000000E7000000
[eMMC] : FLASH_UCP : 3696 MiB [eMMC 4 GiB]
DEV RID    : A081A776982B338BED8D8394767305F9
INT RAM    : 0x00020000
EXT RAM    : 0x40000000
BOOT TYPE  : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6589 , Project : MTK6589 , Storage : eMMC
Setting : AFF verify :  Enabled
Setting : HW verify :  Enabled
BL : Check HW compatibility
BL : Check eMMC compatibility
BL : BatteryLevel : 3960 mV
BL : BatteryLevel Ok
BL : Flash Pre-Erase
Total blocks to Erase : 2
Erase : 0x0000000000600000-0x0000000000100000
Erase : 0x0000000002720000-0x000000007BE80000
Flash Pre-Erase Done, time used : 00:00:06
SecCfg Passed , 1799
BMT remark not need. Will skip
Sending Preloader ...
Use : preloader.bin
Preloader Sent , Init passed
PartCount : FFFFFFFF
PartErr : Not initialized , will update PMT now ...
Repartition Failed! Break! Something wrong with HW or BL (FirmWare)
Operation Failed
Elapsed: 00:00:34
Reconnect Power/Cable!
Old 03-15-2016, 14:18   #2 (permalink)
PASSIONATE_BOYS's Avatar
Member: 541591
Sonork: 100.1611509
Thanks Meter: 6,892
Hello,
Full erase (including preloader) and flash again.
Br.
Infinity Box Support Team.
Old 03-15-2016, 14:33   #3 (permalink)
Member: 2203712
Sonork: 100.1667064
Thanks Meter: 79
[QUOTE=PASSIONATE_BOYS;11695257]Hello,
Br.
please this is the error that i get after full erase, so now what is the way forward:
Operation : Flash Erase [ v1.43 ]
Wait for phone...
Phone found! [ 11 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6583
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Erase Flash now ...
Erase whole flash
Flash erase done
Done!
Elapsed: 00:00:14
Ready to Flash!
======= Flash
Wait for phone...
Phone found! [ 12 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6583
BromVer   : 0x0005
BLVersion : 0x00FE
PreLoader : NOT Active [ Erased ]
Processing DA stage
DRAM configured from ScatFW!
DRAM initialize passed!
DRAM size : 0x40000000
[DA_ERROR] : DA Load failed!
ErroCode : 0x2007
DA_START_LOAD_FAILED
Boot Error!
Operation Failed
Elapsed: 00:00:28
Old 03-15-2016, 15:27   #4 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 15,214
Charge battery and try flash again.
Old 07-05-2016, 05:16   #5 (permalink)
Member: 2528595
Thanks Meter: 2
Wait for phone...
Phone found! [ 9 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6583
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
DA Select done, will use MTK_AllInOne_DA_v5.1620.10.01
[DA_ERROR] : SECURITYBOOT_BOOT_NOT_ACCEPTED
Boot Error!
Operation Failed
Elapsed: 00:00:05
Old 07-05-2016, 07:20   #6 (permalink)
Member: 541591
Sonork: 100.1611509
Thanks Meter: 6,892
Originally Posted by mmohsin842 View Post
Wait for phone...
Phone found! [ 9 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6583
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Boot Error!
Operation Failed
Elapsed: 00:00:05
Hello,
Need to unlock BL first.
Also would be good if you post details about phone model etc.
Br.
Old 07-05-2016, 07:30   #7 (permalink)
UMeR3's Avatar
Member: 2451476
Sonork: 100.1669164
Thanks Meter: 293
Originally Posted by papinto View Post
tecno f7
phone condition: Dead
when trying to flash, this is the error that i get.
Tried 3 differnet firmwares but same error
solution needed
chinese miracle ii  [mtk module] v 1.43
scatter load ok , baseband : Mt6589 , project : Mtk6589 , storage : Emmc
files found : 10 , set to flash : 9
ready to flash!
======= flash
1. Power off phone , remove battery , insert back
2. Insert usb cable. In some cases require hold bootkey
wait for phone...
Phone found! [ 11 ]
sync...
Inital boot ok!
Bb_cpu_pid : 6583
bb_cpu_nme : [mediatek] mt6583|6589_s00
bb_cpu_ext : 0xca01 , 0x8a00 , 0x0000
processing brom stage
settings for brom configured!
Seccfgval : 0x00000000
bromver   : 0x00ff
blversion : 0x0001
preloader : Active [ boot with pl ]
bootldrss : Normal with spreloader
processing da stage
da select done, will use mtk_allinone_da_v5.1552.01.01
sending and initialize da ...
Running da ver.3.2 on bbid : 0x86
nand flash : Not installed
emmc flash : 204a0190594e49589ca116487790c02f
initialize memory ...
Dram already initialized by preloader
emmc flashic initialized
[emmc] : Flash_ven : 0x90 , oem : 014a
[emmc] : Flash_inf : [hynix] , hynix
[emmc] : Flash_cid : 90014a2058494e594816a19c2fc09077
[emmc] : Flash_brt : 0x00200000 , 0x00200000 , 0x00200000
[emmc] : Flash_len : 0x00000000e7000000
[emmc] : Flash_ucp : 3696 mib [emmc 4 gib]
dev rid    : A081a776982b338bed8d8394767305f9
int ram    : 0x00020000
ext ram    : 0x40000000
boot type  : Emmc_flash_boot
soc verify : C1
boot ok!
Scatcfg : Baseband : Mt6589 , project : Mtk6589 , storage : Emmc
setting : Flash pre-erase (safe) : Enabled
setting : Aff verify :  Enabled
setting : Hw verify :  Enabled
bl : Check hw compatibility
bl : Bbid supported by bootloader!
Bl : Check emmc compatibility
bl : Emmc supported by bootloader!
Bl : Batterylevel : 3960 mv
bl : Batterylevel ok
bl : Flash pre-erase
total blocks to erase : 2
erase : 0x0000000000600000-0x0000000000100000
erase : 0x0000000002720000-0x000000007be80000
flash pre-erase done, time used : 00:00:06
seccfg passed , 1799
bmt remark not need. Will skip
sending preloader ...
Use : Preloader.bin
preloader sent , init passed
partcount : Ffffffff
parterr : Not initialized , will update pmt now ...
Repartition failed! Break! Something wrong with hw or bl (firmware)
operation failed
elapsed: 00:00:34
reconnect power/cable!
hw uncheck /repartition uncheck/uncheck erase
Page generated in 0.28280 seconds with 7 queries
