03-08-2008, 16:34 | #1 (permalink) |
No Life Poster Join Date: Apr 2004 Location: srilanka
Member: 61595 Status: Offline Sonork: 100.1610188 Thanks Meter: 97 | flash file for cm Hardware version: MT6226, E02 Hardware version: M500Z_05C_HW Software version: E551_C4QF8.01.0_26S0 Software date: 2005.04.12 Barcode: MT012345678901234567 please tel wich flash file i want to download from infinity support my problum is after fss format both sims are not working same time Last edited by naje; 03-08-2008 at 16:40. |
03-09-2008, 07:46 | #3 (permalink) | |
Member: 61595 Status: Offline Sonork: 100.1610188 Thanks Meter: 97 | Quote:
Action: reset settings Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 Initializing[6226:8A02:8A01]... CPU: MT6226 chip: 0031552:F861 Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226,E02 Date: 2005.04.12 Version: 1.0 Version: E551_C4QF8.01.0_26S01 Version: M500Z_05C_HW detecting structure #2... done 60 byte(s) read imei: 13579024681122 connection Ok building list... done items to clear: 166 144 of 166 items cleared building list... done 3 items remains Finished, time used: 133 sec Remove/Install battery now ! | |
03-11-2008, 12:23 | #5 (permalink) |
Member: 61595 Status: Offline Sonork: 100.1610188 Thanks Meter: 97 | general infomation Action: read information Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... Hardware version: MT6226, E02 Hardware version: M500Z_05C_HW Software version: E551_C4QF8.01.0_26S0 Software date: 2005.04.12 Barcode: MT012345678901234567 imei: 135790246811220 Finished, time used: 61 sec Power off phone now ! |
03-11-2008, 12:29 | #6 (permalink) |
Member: 61595 Status: Offline Sonork: 100.1610188 Thanks Meter: 97 | detailed infomation COM3 [VCP2] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: read/check detailed information Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... Initializing[6226:8A02:8A01]... CPU: MT6226 chip: 0031552:F861 high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 921600 Set baud Done Identification... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area#1 is Ok security area#1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.8DC48A86.[E551_C4QF8_E551_GPRS_MT6226_S01.01_0.BIN_6ABFFCDD].rpl identification#1 detection finished device-id: 8DC48A86 identification#1 protocol ver: 04 ver. sw1: E551_C4QF8_E551_GPRS_MT6226_S01.01_0.BIN ver. sw2: E551_C4QF8.01.0, 22034095 ffs offset/size: 00800000/001FF000 detect device identification#2... detection phase #1... . warning: optional information not found detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00800000 flash: EC257E25082501:29EA0000000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 Detected eeprom/ffs address is non-standard: 00E00000 Posible reasons: 1. eeprom is Ok but address is non-standard 2. eeprom damaged and can't be detected 3. eeprom is Ok but detected incorrectly (f.e. unknown eeprom structure) If you are not sure that detected address is correct: 1. press "NO" (and select standard address or terminate current operation) 2. make flash backup for emergency case 3. repeat required operation Are you sure that detected eeprom address is correct ? autodetected eeprom/ffs address[00E00000] confirmed by user detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF detecting ffs structure pass 1... ................... detect standard fat location pass #1... .................................................. ...... detect extended fat location pass #1... .................................................. .. detect standard fat offset pass #1... detect standard fat data... fat layout detection complete ffs element #1 detected ok detecting ffs structure pass 2... ................... detect standard fat location pass #1... .................................................. ...... detect extended fat location pass #1... .................................................. .. detect standard fat offset pass #1... detect standard fat data... fat layout detection complete ffs element #2 detected ok file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_system_log _8DC48A86_E551_C4QF8_E551_GPRS_MT6226_S01.01_0.BIN _6ABFFCDD_20080311-172724.B0X.bin Finished, time used: 222 sec Remove/Install battery now ! |
03-11-2008, 16:13 | #7 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, You need to use flash file with version similar to this: ver. sw1: E551_C4QF8_E551_GPRS_MT6226_S01.01_0.BIN ver. sw2: E551_C4QF8.01.0, 22034095 |
03-12-2008, 15:25 | #10 (permalink) | |
1. CM_Cect-V909_Nckia-6300c-2sim_E551_A_E551_GPRS_MT6226_S01.01_1_16m_En_Cn_Cn .B0M 2. CM_DaullSim-CPU1E551_C7ARVBT_E551_GPRS_MT6226_S01.01_1__16m_En _Ru_Fr_Vn.B0M which file suitable for filash? | |
Guide Me For Study Motorola Flash File To Choose Corect Flash File For Reflash Set | shahi | Motorola P2k | 2 | 03-10-2008 14:23 |
Guide Me For Study Motorola Flash File To Choose Corect Flash File For Reflash Set | shahi | Motorola Hardware Repair | 0 | 11-16-2007 07:54 |
how can ı use patch files martech flash files for change imei | MONSTER49 | Martech CLIP / Box / Key | 5 | 02-07-2007 20:33 |
Need flash file for dejan 1.05 or full flash for 6250 with polish language | Rafal | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 08-10-2002 20:13 |
c2r flash file for c25..or xbi file | CellM@n | x1x to x45/x50 | 0 | 11-12-2001 18:27 |
