Old 02-05-2006, 04:44   #1 (permalink)
alex12345's Avatar
Member: 152573
Thanks Meter: 58
a100 problem
i got 2 pcs panasonic a100 when press on got panasonic logo and after tat with white screen.. can someone tell me is tis lcd problem or software problem coz i flash with infinity already but same problem.
regards
alex
Old 02-05-2006, 11:19   #2 (permalink)
alex12345's Avatar
Member: 152573
Thanks Meter: 58
hi, mr infinity support and infinity box can reply my question coz quite urgent
regards
alex
Old 02-05-2006, 11:21   #3 (permalink)
Member: 128745
Thanks Meter: 16,936
Hi .
did you flash all 3 parts ? Firmware + language pack + map ?
Rgds
Infinity-Box Team
Old 02-05-2006, 11:54   #4 (permalink)
alex12345's Avatar
Member: 152573
Thanks Meter: 58
yup. i flash 3 part.. even try to flash eprom same problem..
sir, i just wanna know tis is software problem or lcd problem 1st
regards
alex
Old 02-05-2006, 13:12   #5 (permalink)
Member: 130995
Thanks Meter: 35,227
Hi,
Flash main + lp + Map, "erase FFS" checked
if no luck: try to repair eeprom (with different repair files)
if no luck: check hardware
Old 02-09-2006, 11:26   #6 (permalink)
alex12345's Avatar
Member: 152573
Thanks Meter: 58
COM5 selected
Device: Panasonic A100,A101,A102
Checking data, wait...
Action: Flash write
Write: Firmware
Write: MAP/Customization
Write: Language Pack
Skip: EEPROM
Boot...
Press and HOLD Power button !
Connecting, wait...
Release Power button !
Flash: 01227E220A2201
Flash: 80E59F00000000
method: 03
Boot Done
Set baud...
115200
Set baud Done
Check Flash...
Check Flash Done
Check space...
Check space Done
Check parameters...
Check parameters Done
Erasing...
Err: erase[02]
Erasing Done
Writing...
Write: Firmware
method: 03
method: 03
method: 03
method: 03
Writing Done
Finished
Remove/Install battery now !
Time used: 659 sec
hi sir, still same problem.. izzit possible erase error made the phone become display panasonic logo for few seconds and after tat white screen? i flash with all epprom alreayd but still same problme..
regards
alex
Old 02-09-2006, 12:35   #7 (permalink)
Member: 130995
Hi,
Try to use latest "Q-Module v2.03" from support area.
Flash again Main+LP+Map.
Old 02-10-2006, 04:07   #8 (permalink)
alex12345's Avatar
Member: 152573
Thanks Meter: 58
Originally Posted by InfinitySupport
Hi,
hi sir, the log file i post is from q-module v2.03
regards
alex
Old 02-10-2006, 08:20   #9 (permalink)
Member: 130995
Try to make "Reset settings". waiting for results and log file after reset.
Old 02-11-2006, 08:47   #10 (permalink)
alex12345's Avatar
Member: 152573
Thanks Meter: 58
COM5 selected
Action: Reset
Boot...
Connecting, wait...
method: 03
Boot Done
Set baud...
460800
Set baud Done
Check Flash...
Check Flash Done
Check space...
Check space Done
Check parameters...
Erasing...
Err: erase[02]
Erasing Done
Writing...
Writing Done
Finished
Time used: 44 sec
tis is log files for reset setting, same problem
regards
alex
Old 02-11-2006, 08:49   #11 (permalink)
alex12345's Avatar
Member: 152573
Thanks Meter: 58
COM5 selected
Action: Unlock
Boot...
Connecting, wait...
method: 03
Boot Done
Set baud...
460800
Set baud Done
Check Flash...
Check Flash Done
Check space...
Check space Done
Check parameters...
Erasing...
Erasing Done
Writing...
method: 03
Writing Done
Finished
Time used: 22 sec
log files for unlock..
sir, i try all epprom repair and change lcd alreyad but still same problem..
hope can help me solve the problem
regards
alex
Old 02-11-2006, 12:16   #12 (permalink)
Member: 130995
Hi,
It looks like it was small bug in QModule and as a result - it was not possible to reset A100 to defaults. Pls, download QModule v1.05 from support area.
Old 02-11-2006, 12:45   #13 (permalink)
alex12345's Avatar
Member: 152573
Thanks Meter: 58
problem solve with 1.29a
thanks for help .. good support but please fix the bugs big thanks
regards
alex
Old 02-11-2006, 13:24   #14 (permalink)
Member: 130995
fixed in QModule v1.05
Old 04-27-2006, 09:12   #15 (permalink)
Member: 30601
Before going crazy with boxes try this MASTER RESET: *01763*737381#
I had 2 Phones A102 with white screen after logo, inserted the code, turn off and on the phone, and now both work perfectly!!
All about a920 a925 a100 problem..please help us:( Lampu Motorola P2k 1 06-21-2005 17:51
Panasonic A100 problems mrmarcellos Panasonic 17 03-15-2005 11:26
A100 problem MadPhone UfoTools 2 02-05-2005 04:23
A100 problem jak2812 Panasonic 1 09-20-2004 22:31
A100 problem, never meet before Headmade VLSI, Conexant, Skyworks and Old Models 3 10-15-2003 16:02
Page generated in 0.31684 seconds with 9 queries
