Old 04-15-2019, 07:55   #1 (permalink)
Akhtar Ali Jatt's Avatar
Member: 953334
Sonork: 100.1614005
Thanks Meter: 15,424
Exclamation Need VgoTel i252 firmware
Old 04-15-2019, 12:50   #2 (permalink)
Member: 1043909
Thanks Meter: 60,926
Hi,
What is the estimated required firmware version ?
Old 04-30-2019, 09:22   #3 (permalink)
Member: 953334
Sonork: 100.1614005
Smile
Originally Posted by YellowBoss View Post
Hi,
Problem Solved Boss Thanks For Reply
Operation : Flash [ v1.58 ]
======= Flash
Files set for flashing :
[ MCU ] : FISE61D_11C_PCB01_gprs_MT6261_S00.MAUI_11C_W13_52_ MP_V2_F9.bin
2. Insert USB cable. In some cases require hold BootKey ( '*' )
Wait for phone...
Phone found! [ 26 ]
Sync...
Sync Ok, read regs...
Inital regs read done
Boot Info :
BB_CPU_ID : 6261
BB_CPU_HW : CB01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
BB_CPU_NM : [MediaTek] MT6261_S0000
BB_CPU_SN : F5AC86D33003370429AAB7BCC863C78B
BROM Protocol Version : 05
Setting...
Setting done , result code 0x000E
BROM stage done
Seek and prepare DownloadAgent
DownloadAgent matching HW Found!
DA verify and select done
Sending DA to target ...
DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E
SOC_VERIFY : 0xC1
BOOT_STYLE : SF_FLASH_BOOT
NOR Flash IC initialized
[0] : FLASH_VEN : 0x0113 , [Winbond] SF_W25Q32JV
[0] : FLASH_DIE : 00EF 0070 0016 0000
[0] : FLASH_LEN : 0x00400000
SDS_INFO : 0x003FE000 , 0x00002000
INT_RAM : 0x0000D000
EXT_RAM : 0x00400000
File_Info : FISE61D_11C_PCB01_gprs_MT6261_S00.MAUI_11C_W13_52_ MP_V2_F9.bin
FileVersion : MAUI.11C.W13.52.MP.V2.F9
Flash now
Erase region , wait ...
Write data , wait ...
Write : FISE61D_11C_PCB01_gprs_MT6261_S00.MAUI_11C_W13_52_ MP_V2_F9.bin
Done!
Elapsed: 00:01:04
Reconnect Power/Cable!
The Following User Says Thank You to Akhtar Ali Jatt For This Useful Post:
Old 05-02-2019, 07:22   #4 (permalink)
Member: 1043909
Dear Sirs,
If you have good flash files and if you want to share it with other users please use IOS File Uploader Tool
Please do not upload password protected or damaged files, all of them will be deleted after upload.
Thank you !
Old 07-21-2019, 07:54   #5 (permalink)
Member: 2234695
Where is link dear plz
Old 07-22-2019, 14:19   #6 (permalink)
Member: 1043909
Dear Sirs,
Thank you !
Page generated in 0.16794 seconds with 9 queries
