Old 07-08-2010, 10:43   #1 (permalink)
Member: 16789
Thanks Meter: 3
Flash files from support area - wrong.
After flash Airphone (originall software SCUD35_09A_PCB01_GPRS_MT6235B_S01.3502_V02_19 ) with full flashes from support,phone is dead.I try write two files SCUD35_09A_PCB01_GPRS_MT6235B_S01.3502_V02_15_128m _En_Ru_Es_Ml_Id_Th_Vn_Cn_Tr_Pt_Cn.B4M.bin
and
SCUD35_09A_PCB01_GPRS_MT6235B_S01.3502_V2_1_128m_E n_Ru_Es_Ml_Id_Th_Vn_Cn_Tr_Pt_Cn.B4M.bin.
Phone backup full flash -writing ok but phone dead also.After write full flash from another model
NEOTEL35_08B_GEMINI_PCB01_GPRS_MT6235B_S01.F35W_CL D_IV_TY1G_WIFI_V001__iPhone_128m_En_Ru_Gr_Nl_Fr_Es _Hu_It_Da_Pl_De_Ml_Id_Th_Vn_Cn_Tr_Farsi_Pt_Cn_Ar.B 4M.bin phone power on is ok,but many functions not worked.Please help me.
Old 07-09-2010, 17:56   #2 (permalink)
Member: 148515
Thanks Meter: 13,904
hello!
make "erase whole flash " operation.
and then write back Original backup
check battery voltage too, it should be more than 3,7 volts
Old 07-10-2010, 08:45   #3 (permalink)
Member: 16789
Thanks Meter: 3
Hello!I erase whole flash and write back original backup file.
COM4 selected
module  v3.15
Device: Autodetect 6228-6239 NAND
Checking data, wait...
Action: write flash NAND
write: Firmware
SCUD35_09A_PCB01_GPRS_MT6235B_S01.3502_V02_19__fullflash_20100616-143711.B4M.bin
skip: Customization/Language Pack
skip: Customization
skip: Eeprom/ffs
nfi area detection...
converting data...
done 0x07C1F800 bytes
bootloader version: SCUD35_09A_BOOTLOADER_V005_MT6235B_3502_V02_19.bin
warning: ffs size mismatch: 05C1F800/06000000
nfi area detection finished: Ok
interface: BROM_DLL_v3.1012.00
Connect...
Connecting...
Booting...
Release Power button now !
bootcode current/expected: 3.2/3.2
CPU: 6235:8A04:8A01
status: FF
bbchip bl ver: FE
NOR flash chip: not installed
NAND flash id[0014]: 0098:00D100900015 [TOSHIBA] TC58NVG0S3AFT
chip size: 128Mb
page/spare size: 0800/0040
pages per block: 0040
bits i/o: 08
address cycles: 04
internal RAM size: 00010000
external RAM: S_DA_RAM_ERROR
done
Set baudrate (921600)...
done
ram test...
testing...
ram test passed
===>  detect existing firmware structure...
detect ffs...
detect sec ro...
detect custom parameters...
detect project-id...
detect NAND info...
number of areas/bytes to read: 1:001A0000
reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)...
warning: header is empty: probably flash chip completely erased
warning: can not detect header
nfi area detection finished: failed
warning: ffs can not be detected
TCL-ID detection...
TCL-ID detection done
startup code area #1 detection...
startup code area #1 detection done
code offset: 00000000
===>  done
New firmware detected (v.3.15, database date: 06.06.2010):
This firmware is missing in support area. If this phone is good and working:
- download latest software from support area and try again, probably this firmware already supported in latest software
- make "Read full flash" operation
- send flash backup files to support: [email protected] or upload files to RapidShare: 1-CLICK Web hosting - Easy Filehosting or 4shared.com - free file sharing and storage
- include in your e-mail full text from phone back label (phone name etc.)
converting data...
startup code area #1 check...
rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\id.00006235.[SCUD35_09A_PCB01_GPRS_MT6235B_S01.3502_V02_19.BIN_5C5B3AE2].rpl
rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\id.00006235._SCUD35_09A_PCB01_GPRS_MT6235B_S01.3502_V02_19.BIN_5C5B3AE2_.rpl
rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\id.00006235.[SCUD35_09A_PCB01_GPRS_MT6235B_S01.3502_V02_19.BIN_5C5B3AE2].rpl
rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\id.00006235._SCUD35_09A_PCB01_GPRS_MT6235B_S01.3502_V02_19.BIN_5C5B3AE2_.rpl
warning: unknown rom info structure: SCUD35_09A_PCB01_GPRS_MT6235B_S01.3502_V02_19.BIN_5C5B3AE2
Unknown firmware detected (v.3.15, database date: 06.06.2010), user action required:
1. download latest software from support area and try again
2. if no still luck follow the next procedure:
- find good working phone with the same firmware:
- be little bit patient and wait update
error: startup code area #1 can't be fixed
You can flash phone now but can not finalize it,
in most cases phone CAN NOT power-on.
Do you want to continue anyway ?
number of cores: 3
loading files...
number of areas: 3
done
write...
write bootloader...
write core...
Disconnect...
done
Finished, time used: 10 min 24 sec
Remove/Install battery now !
Phone dead.Also i try option page+spare. Phone work only with NEOTEL35_08B_GEMINI_PCB01_GPRS_MT6235B_S01.F35W_CL D_IV_TY1G_WIFI_V001__iPhone_128m
Old 07-10-2010, 10:00   #4 (permalink)
Member: 148515
hello!
try this flash file, it is not exactly like your original, but hope it will work
Old 07-11-2010, 17:12   #5 (permalink)
Member: 16789
Thanks Meter: 3
I don know what....But your file from rapidshare no downloadable.Download only first 2 Mb.Please check this and help my.May be another download path?
Old 07-12-2010, 07:16   #6 (permalink)
Member: 16789
Thanks Meter: 3
Hello.I try different download agents.Always download only first 2Mb and stop it.Please check this.
Old 07-13-2010, 09:47   #7 (permalink)
Member: 16789
Thanks Meter: 3
Ok.I download this file from rapidshare,make "erase whole flash " operation and write it.
module v3.15
write: Firmware
SCUD35_09A_PCB01_GPRS_MT6235B_S01.3502_V02_09__fir mware_20100529-131924.B4M.bin
skip: Customization
skip: Eeprom/ffs
bootloader version: SCUD35_09A_BOOTLOADER_V005_MT6235B_3502_V02_09.bin
Connect...
Connecting...
Booting...
CPU: 6235:8A04:8A01
status: FF
bbchip bl ver: FE
chip size: 128Mb
bits i/o: 08
address cycles: 04
done
done
ram test...
testing...
ram test passed
detect ffs...
ffs offset/size: 02000000/06000000
firmware size: 32Mb
ffs size: 96Mb
detect sec ro...
project-id: 3502_V02.19
detect NAND info...
TCL-ID detection...
number of areas/bytes to read: 1:00020000
error: unexpected answer:
startup code area #1 is invalid
rom info ver: 07
sw version: SCUD35_09A_PCB01_GPRS_MT6235B_S01.3502_V02_19.BIN
project-id: 3502_V02.19, E23A5B5C
ffs offset/size [01]: 02000000/06000000
rom info structure: 2nd [enhanced] generation
TCL-ID is absent
===> done
rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\id.00006235.[SCUD35_09A_PCB01_GPRS_MT6235B_S01.3502_V02_09.BIN_ DCCA4ABE].rpl
rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\id.00006235._SCUD 35_09A_PCB01_GPRS_MT6235B_S01.3502_V02_09.BIN_DCCA 4ABE_.rpl
rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.00006235.[SCUD35_09A_PCB01_GPRS_MT6235B_S01.3502_V02_09.BIN_ DCCA4ABE].rpl
rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.00006235._SCUD35_09A_PCB01_GPRS_MT6235B_S01.3502 _V02_09.BIN_DCCA4ABE_.rpl
warning: unknown rom info structure: SCUD35_09A_PCB01_GPRS_MT6235B_S01.3502_V02_09.BIN_ DCCA4ABE
number of cores: 3
loading files...
number of areas: 3
done
write...
write bootloader...
write core...
Disconnect...
done
Finished, time used: 9 min 17 sec
Phone CAN NOT power-on.How to solved this problem?
Old 07-13-2010, 11:04   #8 (permalink)
Member: 148515
hello!
please wait for next CM update.
we will add this firmware support
The Following 2 Users Say Thank You to InfinityHelp For This Useful Post:
Old 07-17-2010, 07:51   #9 (permalink)
Member: 16789
Thanks Meter: 3
Hello infinity support team!I reflash phone with new version 3.16 and phone problem solved!
startup code area #1 calculation...
startup code area #1 fixed
Good work!Big thank!
The Following User Says Thank You to resident For This Useful Post:
Old 07-22-2010, 10:35   #10 (permalink)
Member: 1348845
Thanks Meter: 19
Hello Infinity support team!
I have the new type Iphone clone phone. It name's is N5. The phone is not work, becouse the previous owner spoil the flash process. I downloaded the phone's flash file from support area:
3188_PCB01_GPRS_MT6235B_S01.ZZT_G3188TP03_5_1T31D0 204_MB01_128m_En_Ru_Gr_Fr_Es_It_De_Ml_Id_Th_Vn_Tr_ Farsi_Pt_Bg_Cz_Sk_Ar.B4M.bin
but this flash file is not work. I think the error is the same as than airphone.
The chinesemiracle 3.17 wrote same than airphone. The airphone in the previous posts.
Please help me!
Old 07-22-2010, 20:54   #11 (permalink)
Member: 148515
Please help me!
hello!
please post flashing log
Old 07-22-2010, 22:02   #12 (permalink)
Member: 1348845
Thanks Meter: 19
Hello!
This is the flashing log:
COM4 [VCP0] selected
module v3.17
write: Firmware
skip: Customization
skip: Eeprom/ffs
bootloader version: 3188_BOOTLOADER_V005_MT6235B_ZZT_G3188TP03_5_1T31D 0204_MB01.bin
interface: BROM_DLL_v3.1016.00
Connect...
Connecting...
Booting...
CPU: 6235:8A04:8A01
status: FF
bbchip bl ver: FE
NAND flash id[0018]: 00AD:007900A50000 [HYNIX] HY27XA081G1M
chip size: 128Mb
page/spare size: 0200/0010
pages per block: 0020
bits i/o: 08
address cycles: 04
external RAM: absent
done
Set baudrate (115200)...
done
ram test...
testing...
ram test passed
detect ffs...
ffs offset/size: 04000000/04000000
firmware size: 64Mb
ffs size: 64Mb
detect sec ro...
project-id: F35W_CLD_IV_TY1G_WIFI_V001
detect NAND info...
number of areas/bytes to read: 1:00034000
bootloader version: _BOOTLOADER_F35W_CLD_IV_TY1G_WIFI_V001.bin
warning: id-page1 area is invalid
TCL-ID detection...
rom info ver: 07
sw version: NEOTEL35_08B_GEMINI_PCB01_GPRS_MT6235B_S01.F35W_CL D_IV_TY1G_WIFI_V001.BIN
project-id: F35W_CLD_IV_TY1G_WIFI_V001, 00000000
ffs offset/size [01]: 04000000/04000000
rom info structure: 2nd [standard] generation
TCL-ID is absent
===> done
rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\id.00006235.[3188_PCB01_GPRS_MT6235B_S01.ZZT_G3188TP03_5_1T31D0 204_MB01.BIN_93260ECE].rpl
rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\id.00006235._3188 _PCB01_GPRS_MT6235B_S01.ZZT_G3188TP03_5_1T31D0204_ MB01.BIN_93260ECE_.rpl
rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.00006235.[3188_PCB01_GPRS_MT6235B_S01.ZZT_G3188TP03_5_1T31D0 204_MB01.BIN_93260ECE].rpl
rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.00006235._3188_PCB01_GPRS_MT6235B_S01.ZZT_G3188T P03_5_1T31D0204_MB01.BIN_93260ECE_.rpl
warning: unknown rom info structure: 3188_PCB01_GPRS_MT6235B_S01.ZZT_G3188TP03_5_1T31D0 204_MB01.BIN_93260ECE
Unknown firmware detected (v.3.17, database date: 16.07.2010), user action required:
number of cores: 3
loading files...
number of areas: 3
done
write...
write bootloader...
write core...
Disconnect...
done
Finished, time used: 45 min 29 sec
Old 07-25-2010, 12:37   #13 (permalink)
Member: 148515
Hello!
hello!
lets try with latest CM which will be released tonight
Old 07-26-2010, 20:58   #14 (permalink)
Member: 1348845
Thanks Meter: 19
hello!
Unfortunately, it also is the same situation.
I think this firmware is not good 3188_PCB01_GPRS_MT6235B_S01.ZZT_G3188TP03_5_1T31D0 204_MB01_128m_En_Ru_Gr_Fr_Es_It_De_Ml_Id_Th_Vn_Tr_ Farsi_Pt_Bg_Cz_Sk_Ar.B4M.bin
By coincidence, have you this phone to another firmware?
Old 08-13-2010, 19:32   #15 (permalink)
Member: 1348845
Thanks Meter: 19
hello!
I bought simillar phone, but the CM don't know right read the full flash. The readed ful flash is simmilar wrong than 3188_PCB01_GPRS_MT6235B_S01.ZZT_G3188TP03_5_1T31D0 204_MB01_128m_En_Ru_Gr_Fr_Es_It_De_Ml_Id_Th_Vn_Tr_ Farsi_Pt_Bg_Cz_Sk_Ar.B4M.bin.
The CM is not supported by this phone.
5110 flash new software , need help steve Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 01-03-2015 04:41
Copy from one 6110 to another Leif Nielsen Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 06-10-1999 22:36
Page generated in 0.47135 seconds with 9 queries
