09-01-2008, 09:10 | #1 (permalink) |
Freak Poster Join Date: May 2006 Location: Indonesia
Member: 271133 Status: Offline Thanks Meter: 37 | HELP can't read code mito 200 COM4 [VCP0] selected Action: read codes unlock method: read codes Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing[6225:8A03:8A00]... CPU: MT6225 high speed boot enabled chip: 0001:E803:0005 Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E03 Date: 2006.06.14 Version: 1.0 Version: E890_EVSMT3B.01.1 Version: EVEN6225_GEMINI_HW detecting structure #2... 5 11 done 67 byte(s) read imei: 35516282025023 connection Ok detecting structure #1... 1 2 5 8 9 10 12 13 14 15 16 17 20 23 24 25 27 28warning: wrong packet cs 29error: detection failed (19 tries), read flash and send to support error: can't read required data error: operation failed ! Finished, time used: 15 sec Remove/Install battery now ! |
09-02-2008, 03:19 | #3 (permalink) |
Member: 271133 Status: Offline Thanks Meter: 37 | thank.s infinity nom phone is ok COM4 [VCP1] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: "format ffs" Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6225:8A03:8A00]... CPU: MT6225 high speed boot enabled chip: 0001:E803:0005 boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 115200 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw1: E307_JQINOV_MT6225S00.GM_01_0_20080723.BIN ver. sw2: E307_JQINOV.GM.01.0, 00000000 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00E00000 flash: EC257E25082501:18E59F00000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... flash: EC257E25082501:18E59F00000000 Backup required data Done Patch required data... Patch required data Done Special operation... Special operation Done Write... Write Done Finalization... formatting... flash: EC257E25082501:18E59F00000000 Finalization Done Finished, time used: 29 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
blackberry storm 9500 can't read code ,need help!! [SOLVED] | xiongfuchen | PolarBox 3 | 2 | 02-15-2010 18:07 |
J230i can't read codes | patric | Cruiser Suite | 13 | 04-10-2007 15:43 |
can't read codes from My-X5-2 | piracik | SAGEM JTAG UNLOCKER | 5 | 01-16-2007 19:36 |
philips 855 can't read codes???? | midou01 | Redbox | 6 | 06-29-2006 11:37 |
i can't read code t600 by total tool pls help??? | proxy_gsm | Sony Ericsson | 0 | 01-15-2004 10:23 |
