flash problem in kg110 dear bro i have lg kg 110 problem is flash, wCOM4 [VCP0] selected Device: LG-KG110 Checking data, wait... advanced flash detection active Action: flash write Write: Firmware (code) Skip: File system Skip: Alchemy data Skip: Eeprom "smart write" enabled Boot... Phone must be POWERED-OFF ! Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 01227E22212200:FEEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb id: 00005258 Boot Done Set baud... 115200 Set baud Done Check flash... error: wrong answer: A4 error: wrong answer: C5 .error: wrong answer: C5 .error: wrong answer: C5 .error: wrong answer: C5 .error: wrong answer: C5 .error: wrong answer: C5 .error: wrong answer: C5 .error: wrong answer: C5 .error: wrong answer: C5 .error: wrong answer: C5 .error: wrong answer: C5 .error: wrong answer: C5 .error: wrong answer: C5 .error: wrong answer: A4 .error: wrong answer: C5 .error: wrong answer: C5 .error: wrong answer: C5 .error: wrong answer: C5 .error: wrong answer: C5 .error: wrong answer: C5 .error: wrong answer: C5 .error: wrong answer: C5 .error: wrong answer: C5 .error: wrong answer: C5 .error: wrong answer: C5 .error: wrong answer: C5 .error: wrong answer: C5 .error: wrong answer: C5 .error: wrong answer: C5 .error: wrong answer: C5 .error: wrong answer: C5 .error: wrong answer: C5 . Check flash Done Check space... Check space Done Check parameters... Check parameters Done Erase... Erase Done Write... Write: Firmware (code) error: wrong answer: A4 error: wrong answer: C5 : wrong answer after chip id request error: wrong answer: A4 error: wrong answer: A4 error: wrong answer: C5 hen i flashed it give me display |
cheak your cable and battery then retry it |
lg kg 110 flashproblem i had change the cable. but problem is same. plz sir give me other solution. thanks |
cheak your battery charging if not done try to heat the pcb and flash it |
