Old 09-24-2008, 13:57   #1 (permalink)
Member: 815644
Thanks Meter: 56
flash problem in kg110
dear bro
i have lg kg 110 problem is flash, wCOM4 [VCP0] selected
Device: LG-KG110
Checking data, wait...
advanced flash detection active
Action: flash write
Write: Firmware (code)
Skip: File system
Skip: Alchemy data
Skip: Eeprom
"smart write" enabled
Boot...
Phone must be POWERED-OFF !
Press and HOLD Power button !
Connecting, wait...
Release Power button !
flash: 01227E22212200:FEEA0000000000
flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb
Boot Done
Set baud...
115200
Set baud Done
Check flash...
error: wrong answer: A4
error: wrong answer: C5
.error: wrong answer: C5
.error: wrong answer: A4
Check flash Done
Check space...
Check space Done
Check parameters...
Check parameters Done
Erase...
Erase Done
Write...
error: wrong answer: C5 : wrong answer after chip id request
hen i flashed it give me display
Old 09-24-2008, 14:02   #2 (permalink)
laxman kumar's Avatar
Member: 733702
Sonork: 100.1579452
Thanks Meter: 579
cheak your cable and battery then retry it
Old 09-24-2008, 14:53   #3 (permalink)
Member: 815644
Thanks Meter: 56
lg kg 110 flashproblem
i had change the cable.
but problem is same.
plz sir give me other solution.
thanks
Old 09-24-2008, 15:18   #4 (permalink)
Member: 733702
Sonork: 100.1579452
Thanks Meter: 579
cheak your battery charging if not done try to heat the pcb and flash it
mt box create a flashing problem in off phones Shakeel Communication MT-BOX 13 02-29-2008 05:52
Flashing Problem in 8910i gogon UFS2 + UFS3-Tornadoflasher 2 04-25-2006 17:03
J70 flash problem in the end fm-gsm Sony 0 12-15-2002 18:06
Page generated in 0.25511 seconds with 8 queries
