04-03-2008, 11:38 | #1 (permalink) |
No Life Poster Join Date: May 2006 Location: in gsm world
Member: 269885 Status: Offline Thanks Meter: 50 | flash problem of lg ke970 help needed KE970P40-07-V10e-***-XX_APR-05-2007_firmware_En_Ee_Kz_Lv_Lt_Ru_Ua.B1M and wid fs file ver KE970P40-07-V10e-***-XX_APR-05-2007_file_system.B1S but the problem still presist then i repair eeprom wid KE970_repair_eeprom_complete_0A[1].B1E but wid no result.kindly infinity team give me the solution how to recover it.i search the forum and found some tricks, apply on fone but the fone at its initial stage. some body help me plzzzzzzzzzzzz |
04-04-2008, 07:01 | #3 (permalink) |
Freak Poster Join Date: Aug 2007 Location: Monterrey, Mexico.
Member: 558475 Status: Offline Thanks Meter: 26 | Flashealo the following firmware and will be working well KE970P40-AFR-V10i-***-XX_JUL-30-2007_file_system.B1S.bin KE970P40-AFR-V10i-***-XX_JUL-30-2007_firmware.B1M.bin |
11-22-2008, 17:03 | #7 (permalink) |
Banned Join Date: Jul 2004 Location: www.mobileshardware.com Age: 45
Member: 75611 Status: Offline Thanks Meter: 77 | InfinitySupport must give the solution related to software. i read at two places and both places it advised to check via different firmwares if not then open the phone. my phone was alright before flash. only there was problem of no network coverage. means my phone was not going to check up for signals. i flashed it with infinity and now in this state. means hangup on startup. so it must be software problme. now infinitysupport should come up with a software solution rather to advising for opening phone and doing the hardware jobs. |
11-22-2008, 23:56 | #8 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Did you tried to ask yourself what was the problem with phone before flash ? In most cases "no network" is a hardware problem. Don't you think so ? Also, did you ever heard about bad soldered flash chip and other hardware problems ? Anyway, I respect your words (even if I don't agree with your words, just read my advice and you will see why) so it's interesting to know: did you tried to use different flash files and eeprom files from support area ? Did you asked your customer what is this phone history ? Why poeple always want "solution" but never try to think what is the reason of the problem ? |
11-23-2008, 03:48 | #9 (permalink) |
Member: 75611 Status: Offline Thanks Meter: 77 | thanks for reply. i've done enough workaround but my problem is not solving. i hope that somene will provide some shortcut solution. actually i don't want reball my phone' flash or etc. Anyway thanks for reply and support |
11-23-2008, 13:40 | #10 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Thank you for your ignorance for for zero answers to our questions ! Please, think now, how we can helps users if users simply ignored all questions and advices ? I talk now not only about your LG phone but about situation in total. Any comments ? Any respect to support persons and forum members ? |
11-25-2008, 12:29 | #11 (permalink) | |
Member: 269885 Status: Offline Thanks Meter: 50 | Quote:
i apriciate the hardwork of infinity team for their costomer and to all members kindly folow their instruction for solving ur problem and post ur results even u got no successful result. | |
Some problem regarding LG KE970 | Gsm-W | Infinity-Box | 5 | 08-02-2008 11:55 |
2 Pieces of LG KE970 successfully unlocked ! | Spax | FuriousGold | 4 | 04-09-2008 17:07 |
always problem in lg KE970 | MDK23 | Infinity-Box | 1 | 01-14-2008 19:32 |
i need arabic flash file for LG KE970 | tsarkh | VygisToolbox | 6 | 09-12-2007 12:01 |
@ INFINITY NEED Flash file of LG KG200 | Faisal_Computer | Infinity-Box | 5 | 07-05-2007 05:51 |
