08-08-2009, 16:34 | #7 (permalink) |
Freak Poster Join Date: Jan 2007 Location: Trujillo - Perú
Member: 432025 Status: Offline Thanks Meter: 122 | Hi i try many tocs model and i think there are two models the first model dont have any problems and work perfectly but the second model ist the problem dont unlock and if you do a ffs format it will died This is a back up the first model please work whit it and create a good flash http://www.4shared.com/file/12375067.../Tocs_M52.html |
08-08-2009, 17:18 | #8 (permalink) |
Member: 432025 Status: Offline Thanks Meter: 122 | This is the logs when i try to unlock this model COM1 [VCP0] selected module v2.82 Device: Tocs-M52 Checking data, wait... advanced flash detection enabled Action: "sp-unlock" unlock method: standard fast Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 chip: 0001:2F03:0000 status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation ==================== New firmware detected (v.2.82, database date: 20.07.2009): M526_SAA_PCB01_GPRS_MT6225_S00.KBFM526FM_SAA_SP_EN _3_04_417.BIN This firmware is missing in support area. If this phone is good and working: - make "Read full flash" operation - send flash backup files to support: [email protected] - include in your e-mail full text from phone back label (phone name etc.) ==================== identification#1 detection finished identification#1 protocol ver: 04 ver. sw 1: M526_SAA_PCB01_GPRS_MT6225_S00.KBFM526FM_SAA_SP_EN _3_04_417.BIN ver. sw 2: KBFM526FM_SAA_SP_EN_3.04.417, 00000000 ffs offset/size: 00D00000/00300000 ffs address assigned: 00D00000 detect device identification#2... detection phase #1... . detect device identification#2 finished sim-lock status: unknown Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... flash: 2088C4FFFFFFFF:2088C400000000 Backup required data Done Patch required data ... .... error: required unlock parameters not found, check model selection .... error: required unlock parameters not found, check model selection Patch required data Fail Finished, time used: 19 sec Remove/Install battery now ! |
08-09-2009, 19:26 | #9 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Code: ==================== New firmware detected (v.2.82, database date: 20.07.2009): M526_SAA_PCB01_GPRS_MT6225_S00.KBFM526FM_SAA_SP_EN _3_04_417.BIN This firmware is missing in support area. If this phone is good and working: - make "Read full flash" operation - send flash backup files to support: [email protected] - include in your e-mail full text from phone back label (phone name etc.) ==================== |
08-10-2009, 03:49 | #10 (permalink) |
Crazy Poster Join Date: Aug 2007
Member: 571831 Status: Offline Thanks Meter: 17 | COM5 [VCP0] selected module v2.82 Action: user code unlock method: smart fast Model: Tocs-M52 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A03:8A00]... CPU: MT6225 chip: 0001:2803:0002 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E03 Date: 2006.06.14 Version: 1.0 Version: KBFM526FM_SAA_SP_EN_3.05.526 Version: Konka25_06B_HW 44 byte(s) read imei: 35044805758697 connection Ok 157 byte(s) read reading data... reading data #2... reading data #4... reading data #5... WARNING ! Unknown lock structure ! Read flash and send to support: [email protected] error: operation failed ! Finished, time used: 9 sec Remove/Install battery now ! |
08-10-2009, 03:54 | #11 (permalink) |
Member: 571831 Status: Offline Thanks Meter: 17 | COM5 [VCP0] selected module v2.82 Device: Tocs-M52 Checking data, wait... advanced flash detection enabled Action: read/check detailed information Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 chip: 0001:2803:0002 status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation ==================== New firmware detected (v.2.82, database date: 19.07.2009): M526_SAA_PCB01_GPRS_MT6225_S00.KBFM526FM_SAA_SP_EN _3_05_526.BIN This firmware is missing in support area. If this phone is good and working: - make "Read full flash" operation - send flash backup files to support: [email protected] - include in your e-mail full text from phone back label (phone name etc.) ==================== identification#1 detection finished identification#1 protocol ver: 04 ver. sw 1: M526_SAA_PCB01_GPRS_MT6225_S00.KBFM526FM_SAA_SP_EN _3_05_526.BIN ver. sw 2: KBFM526FM_SAA_SP_EN_3.05.526, 00000000 ffs offset/size: 00D00000/00300000 ffs address assigned: 00D00000 detect device identification#2... detection phase #1... . detect device identification#2 finished sim-lock status: unknown Check firmware integrity Done Check firmware content ... detecting firmware build... ...................................... firmware build: 200805271121 detecting product-id... .................................................. .............. done detecting languages... ............................... language parameters detected detected languages: En Es Check firmware content Done Backup required data ... Finished, time used: 56 sec Remove/Install battery now ! |
08-10-2009, 11:14 | #12 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Code: ==================== New firmware detected (v.2.82, database date: 19.07.2009): M526_SAA_PCB01_GPRS_MT6225_S00.KBFM526FM_SAA_SP_EN _3_05_526.BIN This firmware is missing in support area. If this phone is good and working: - make "Read full flash" operation - send flash backup files to support: [email protected] - include in your e-mail full text from phone back label (phone name etc.) ==================== |
08-11-2009, 01:36 | #13 (permalink) | |
Member: 432025 Status: Offline Thanks Meter: 122 | Quote:
and upload to support | |
The Following User Says Thank You to WallfireX For This Useful Post: |
08-19-2009, 18:11 | #14 (permalink) |
Member: 432025 Status: Offline Thanks Meter: 122 | Solution ok Thx Infinity team work 100% with new module and new flash in the support, my cell work again |
The Following 4 Users Say Thank You to WallfireX For This Useful Post: |
Unlock Huawei T330a and tocs m52 | cellcarcol | Infinity-Box | 0 | 07-16-2009 23:29 |
Please Help, just need few flashing/unlocking answers - P520 | lomna | Samsung Flashers, Software, Firmware. | 3 | 02-03-2009 23:42 |
SAGEM M51/M52/x1/x2/x3/x5 FREE UNLOCK CODES !!! | .:hack3r2k:. | FuriouS II | 132 | 11-04-2005 14:10 |
TOC for Sticky: SLIKv56: Flash patches. | StevieRay | x4x, x5x Flashpatching | 17 | 10-15-2005 08:26 |
