07-06-2008, 23:20 | #1 (permalink) |
No Life Poster Join Date: Nov 2005 Location: MoNiToR
Member: 199405 Status: Offline Sonork: 100.1576571 Thanks Meter: 322 | flash write error? i dont think so Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: read/check detailed information enhanced security fix enabled Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:E441:4310 high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 04227E22212200:29EA0000000000 flash: Fujitsu AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: 04227E22212200:29EA0000000000 flash: Fujitsu AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 115200 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 04227E22212200:29EA0000000000 flash: Fujitsu AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: 04227E22212200:29EA0000000000 flash: Fujitsu AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area#1 is Ok security area#1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.05F59B85.[N618_PCB01_GPRS_MT6227_S01.1.BIN_51959CA1].rpl identification#1 detection finished device-id: 05F59B85 identification#1 protocol ver: 04 ver. sw1: N618_PCB01_GPRS_MT6227_S01.1.BIN ver. sw2: N618.1, 5E636AAE ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00E00000 flash: 04227E22212200:29EA0000000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF detecting ffs structure pass 1... ................ detect standard fat location pass #1... .................................................. ...... detect extended fat location pass #1... .................................................. ... detect standard fat offset pass #1... detect standard fat data... fat layout detection complete ffs element #1 detected ok detecting ffs structure pass 2... ................ detect standard fat location pass #1... .................................................. ...... detect extended fat location pass #1... .................................................. ... detect standard fat offset pass #1... detect standard fat data... fat layout detection complete ffs element #2 detected ok Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... file saved: C:\Program Files\InfinityBox\ChineseMiracle\system_log_05F59B 85_N618_PCB01_GPRS_MT6227_S01.1.BIN_51959CA1_20080 707-010859.B0X.bin Finished, time used: 184 sec Remove/Install battery now ! phone was have restart problem with sim after format with sp box without backup ,phone dead when i reflash it again with infinty show me this error where is my error plz? |
07-08-2008, 07:20 | #5 (permalink) |
No Life Poster Join Date: Nov 2005 Location: .:GSM WORLD:.
Member: 203158 Status: Offline Sonork: 100.1592032 Thanks Meter: 358 | Yes its the Hardware Fault ........ reball Flash IC will work if not .. then also rehot the main Chip CPU |
The Following User Says Thank You to .::BHATTI::. For This Useful Post: |
07-08-2008, 08:07 | #6 (permalink) |
No Life Poster Join Date: Mar 2008 Location: infinity-box
Member: 720034 Status: Offline Thanks Meter: 213 | Please read this advice: http://forum.gsmhosting.com/vbb/show...67&postcount=2 As you can see you can find many experience people in this forum and you can trust them, it's no need to wait product supporters very time, you can follow advices of other experienced and qualified persons ! |
07-11-2008, 20:36 | #7 (permalink) | |
Member: 199405 Status: Offline Sonork: 100.1576571 Thanks Meter: 322 | Quote:
its not hw problem im sure 100% from that | |
6230i cant flash after mcu flash Write Error ?? | AnToS | Twisterflasher | 16 | 07-13-2005 20:22 |
6610 flash write error | baraka42 | Twisterflasher | 4 | 04-12-2005 12:44 |
Maxon 7922 Flash Write Error at 101000 ??? While Flashing UNLOCKED Flash File | Aamir_Zia | Redbox | 8 | 12-09-2004 19:11 |
3310 flash writing error | Moosani | Nokia Hardware & Hardware Repair | 0 | 09-02-2003 10:55 |
