05-13-2015, 20:36 | #1 (permalink) |
No Life Poster Join Date: May 2007 Location: "Alfa-Gsm"
Member: 507536 Status: Offline Thanks Meter: 75 | Flashing backup made by CMK2MTK Code: Chinese Miracle II [MTK module] v 1.20 Load File FileVersion : MT6592 Load File Ok Operation : Flash [ v1.20 ] ======= Flash Files set for flashing : [ MCU ] : MT6592__ALPS__706v92_jbla_fhd__e2706v92_jbla_fhd__ALPS.KK1.MP1.V2.11__Android_4.4.2__20141103_081700.ispff 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 100 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6592 BB_CPU_HW : CA00 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6592_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004B3758564D420187EBDEECC15F DA Stat : v4.2 on BBID : 0x8A DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BMVX7 [eMMC] : FLASH_CID : 1501004B3758564D420187EBDEECC15F [eMMC] : FLASH_LEN : 0x00000001D2000000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ISPFF ID : 6592 , TARGET ID : 6592 Flash pre-erase enabled Erase Flash now ... Flash pre-erase failed :( Write Flash now ... [ MCU ] : MT6592__ALPS__706v92_jbla_fhd__e2706v92_jbla_fhd__ALPS.KK1.MP1.V2.11__Android_4.4.2__20141103_081700.ispff Init Ok , Sending blocks ... Write failed :( Flash Error! Check Cable, Battery , try again Operation Failed Elapsed: 00:00:34 Reconnect Power/Cable! |
05-13-2015, 20:44 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Hello. MT6592 version will follow in 1-2 hours. Finishing test now. Also, don't forget upload backup for that : http://forum.gsmhosting.com/vbb/f296...oblem-1948275/ |
05-13-2015, 23:21 | #3 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Use this version for flash your MT6592 phone : http://forum.gsmhosting.com/vbb/f296...-21-a-1948365/ |
05-14-2015, 14:38 | #4 (permalink) | |
Member: 507536 Status: Offline Thanks Meter: 75 | Test Report Successful Quote:
Code: Chinese Miracle II [MTK module] v 1.21 Load File FileVersion : MT6592 Load File Ok Operation : Flash [ v1.21 ] ======= Flash Files set for flashing : [ MCU ] : MT6592__ALPS__706v92_jbla_fhd__e2706v92_jbla_fhd__ALPS.KK1.MP1.V2.11__Android_4.4.2__20141103_081700.ispff 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 100 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6592 BB_CPU_HW : CA00 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6592_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004B3758564D420187EBDEECC15F DA Stat : v4.2 on BBID : 0x8A DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BMVX7 [eMMC] : FLASH_CID : 1501004B3758564D420187EBDEECC15F [eMMC] : FLASH_LEN : 0x00000001D2000000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Brand : alps ProdName : e2706v92_jbla_fhd ProdModel : 706v92_jbla_fhd Device : 706v92_jbla_fhd AndroidVer: 4.4.2 MTKxCPU : MT6592 MTKxPRJ : ALPS.KK1.MP1.V2.11 ISPFF ID : 6592 , TARGET ID : 6592 Flash pre-erase disabled Write Flash now ... [ MCU ] : MT6592__ALPS__706v92_jbla_fhd__e2706v92_jbla_fhd__ALPS.KK1.MP1.V2.11__Android_4.4.2__20141103_081700.ispff Init Ok , Sending blocks ... Write done , 7456 blocks sent Done! Elapsed: 00:23:42 Reconnect Power/Cable! | |
The Following User Says Thank You to John(LMT) For This Useful Post: |
