05-22-2008, 06:12 | #1 (permalink) |
Freak Poster Join Date: May 2008 Location: MX-KEY is the BEST NOKIA TOOL
Member: 775560 Status: Offline Thanks Meter: 58 | flashing dead motorola c168 whit infinity ! Device: Motorola C168 "advanced chip detection" active Action: flash write "smart write" active Write: Firmware Write: Flex Write: Language Pack Skip: FFS/File system Write: Images Write: Melody Skip: Eeprom Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! loading... Boot Done Check connection... Check connection Done Set baud... Set baud Done Check flash... flash: 208810FFFFFFFF:20881000000000 flash: 208810FFFFFFFF:20881000000000 flash: ST M58WR064FT, M36D0R6040T0 T 8Mb version sw: !0000 version sw: ! Check flash Done Check parameters... reading Motorola C168_eeprom_calibration-1... file saved: backup_Motorola C168_eeprom_calibration-1_20080520-132638.69E.bin Check parameters Done Check data... warning: Probably wrong model selected, Do you want to continue ? model selection declined by user Check data Fail Finished, time used: 17 sec Remove/Install battery now ! what wrong about that ? cause i already use with the right file flash like in infinity file flash decription fo c168 ! |
The Following User Says Thank You to juwanapati For This Useful Post: |
05-22-2008, 09:34 | #3 (permalink) | |
Also read log and see: software unable to read software veersion (wrong data in flash chip) so software give you a WARNING that PROBABLY wrong model selected. If your phone is dead software detected that your phone is DEAD. | |
05-23-2008, 05:19 | #4 (permalink) |
Member: 775560 Status: Offline Thanks Meter: 58 | first the phone already dead when come to me, the owner say just dead after recieve a call nothing more ! than a try to flash it but the warning show up like i post ! so this log when i push to flashing even the warning stil exist , but nothing help , the phone stil dead ! and soft version in flash cip still ooooo even flashing complet like this log COM3 [VCP5] selected Device: Motorola C168 "advanced chip detection" active Action: flash write "smart write" active "format ffs" active Write: Firmware Write: Flex Write: Language Pack Skip: FFS/File system Write: Images Write: Melody Skip: Eeprom Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! loading... Boot Done Check connection... Check connection Done Set baud... Set baud Done Check flash... flash: 208810FFFFFFFF:20881000000000 flash: 208810FFFFFFFF:20881000000000 flash: ST M58WR064FT, M36D0R6040T0 T 8Mb version sw: !0000 version sw: ! Check flash Done Check parameters... reading Motorola C168_eeprom_calibration-1... file saved: backup_Motorola C168_eeprom_calibration-1_20080520-132936.69E.bin Check parameters Done Check data... warning: Probably wrong model selected, Do you want to continue ? model selection confirmed by user Check data Done Writing... Area: Firmware flash: 208810FFFFFFFF:20881000000000 flash: 208810FFFFFFFF:20881000000000 Write: Firmware Area: Flex flash: 208810FFFFFFFF:20881000000000 flash: 208810FFFFFFFF:20881000000000 Write: Flex Area: Language Pack flash: 208810FFFFFFFF:20881000000000 flash: 208810FFFFFFFF:20881000000000 Write: Language Pack Area: Images flash: 208810FFFFFFFF:20881000000000 flash: 208810FFFFFFFF:20881000000000 Write: Images Area: Melody flash: 208810FFFFFFFF:20881000000000 flash: 208810FFFFFFFF:20881000000000 Write: Melody flash: 208810FFFFFFFF:20881000000000 flash: 208810FFFFFFFF:20881000000000 Erase: ffs ffs format complete Writing Done Finished, time used: 258 sec Remove/Install battery now ! |
05-23-2008, 09:14 | #7 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @juwanapati Flash phone with main + lp + flex + images + melody Here is an instruction how to select flas files: C:\Program Files\InfinityBox\Documentation\Infinity-Box_FlashFilesDescription.htm |
09-14-2009, 11:17 | #8 (permalink) |
Insane Poster Join Date: Jul 2003
Member: 33536 Status: Offline Thanks Meter: 10 | My 168 is dead. when i ma trying to flash it with infinity its giving error. here is the logs: COM3 [VCP0] selected module v1.37 Device: Motorola-C168 "advanced chip detection" active Action: flash write "smart write" active write: Firmware C168_Main_9-1490-000.69M.bin write: Flex/Customization C168_Flex_1490-013.69F.bin write: Language Pack C168_LP_1490-008_En_Fr_Arabic_Farsi_Urdu.69P.bin skip: FFS/File system write: Images C168_Images_1490-004.69G.bin write: Melody C168_Melody_1490-004.69G.bin skip: Eeprom Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! loading... Boot done Check connection ... Check connection done Set baud ... 115200 Set baud done Check hardware ... flash: 90009000900090:90909000000000 flash: 90009000900090:90909000000000 flash: not detected software version: 50"0t0 software version: C-;- Check hardware fail error: operation failed Finished, time used: 7 sec Remove/Install battery now ! |
09-15-2009, 00:03 | #9 (permalink) | |
It looks like phone hardware is damaged. It may be f.e. water damage or bad soldered or damaged flash chip. Did you tried to check phone hardware ? | |
flashing dead motorola c168 with infinity ! | juwanapati | Infinity-Box | 9 | 05-26-2008 10:45 |
how to flash dead motorola u6 | faizan15 | Motorola P2k | 4 | 03-17-2008 18:22 |
CAN USB-Smart flash dead motorola p2k ??????? | laythjg09 | Motorola P2K (USB-Smart) | 2 | 06-05-2006 18:27 |
flashing dead motorola phone | TELE-MEDIA | Motorola Old Legacy (EMMI) | 4 | 09-19-2004 18:24 |
Flashing dead motorolas ? | reo | Motorola Old Legacy (EMMI) | 0 | 05-23-2002 16:25 |
