09-21-2008, 07:23 | #1 (permalink) |
Freak Poster Join Date: Jan 2007 Location: GODS OWN COUNTRY Age: 38
Member: 432618 Status: Offline Sonork: 100.1575009 Thanks Meter: 55 | flashing error but formatting and info all r ok but when i flashing with this cable i encoutered an error wat was the problem with this? anyone using like this ? pls help anyone plssssss Last edited by VIJEESHNK; 09-21-2008 at 07:28. |
09-21-2008, 08:42 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Did you tried to use latest ChineseMiracle software ? Did you tried to use another cable ? Do you see the samwe error with other cable or not ? It's important to undersstand problem reason due to it may be cable problem or phone hardware fault or something else. |
09-21-2008, 08:48 | #3 (permalink) | |
Member: 432618 Status: Offline Sonork: 100.1575009 Thanks Meter: 55 | Quote:
sir im using v2.6 cm i get all phone with same error in flashing only i can read info and can done formatting also but only flashing time this error also i can flash with other cabls i made by manual wats tje prob? pls | |
09-22-2008, 05:29 | #7 (permalink) | |
No Life Poster Join Date: Aug 2006 Location: I N D I A
Member: 336212 Status: Offline Sonork: 100.1585000 Thanks Meter: 4,912 | Quote:
just use Good flex than try to heat main ic than try Flash some time work perfect Last edited by .::AZEEM::.; 09-22-2008 at 05:35. | |
09-23-2008, 09:41 | #10 (permalink) | |
I will explain my problem i have a sigmatel S3 with handsfree mode complaint 1st im formatted the set with spiderman box using spiderman cable still no luck i formatted the same set in infinty with spiderman cable still no luck i tried to flash in infinty with spiderman cable then the attached error coming set has no other complaint only handsfree mode then i tried to flash other set in infinty with spiderman cable then same error but formatting ok all other set with same complaint flashing ok in spiderman then tell me wat was the problem??????????? | |
09-23-2008, 21:29 | #11 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! hard to comment without seeing phone on hands. same way it could be hardware fault and sending will be usless. mtk tool and probably other tools do not verify written data. this is why they can show success flashing. also, please answer: do you use infinity box as interface for your cables? or some other box? |
09-27-2008, 22:33 | #13 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! i would advice to try infinity box as interface. some boxes uses cheep USB to COM port converters they are often a reason for such kind of errors |
N96 Weird Flashing error | javakiller | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 14 | 10-10-2010 11:55 |
1650 flash error | nilesh_patel717 | Nokia Hardware & Hardware Repair | 3 | 03-29-2010 14:03 |
My-411x wont flash error Flash error (#9.1) | Mr.3. | SAGEM JTAG UNLOCKER | 3 | 01-15-2010 05:36 |
Flash colour/cid mismatch ,script error : Flash error (10.43.77) | mccm | Cruiser Suite | 18 | 05-22-2007 05:47 |
