07-30-2016, 05:17 | #1 (permalink) |
Freak Poster Join Date: Jan 2005 Location: boghé-mauritania Age: 48
Member: 106412 Status: Offline Thanks Meter: 15 | Flashing problem: Zte model:v880h/ blade g2 I TRY FLASHING BUT ALWAYS GET ERROR.PHONE DEAD BY TRYING TO FLASH IT WITH SP FLASH TOOL. Scatter Load Ok , BaseBand : MT6589 , Project : MTK6589 , Storage : eMMC Files found : 12 , Set to Flash : 11 Ready to Flash! Operation : Flash [ v1.53 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 85 ] Sync... Inital Boot Ok! BB_CPU_PID : 6583 BB_CPU_NME : [MediaTek] MT6583|6589_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.3.2 on BBID : 0x86 NAND Flash : NOT INSTALLED eMMC Flash : 484A019064314734070186042B50EB83 Initialize Memory ... DRAM configured from ScatFW! DRAM initialize passed! DRAM size : 0x20000000 DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A48344731640486010783EB502B [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00200000 [eMMC] : FLASH_LEN : 0x00000000E7000000 [eMMC] : FLASH_UCP : 3696 MiB [eMMC 4 GiB] DEV RID : 0x5A886C16041EF1EE7642AD45E76B5943 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6589 , Project : MTK6589 , Storage : eMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Enabled Switching to HSUSB HSUSB Init Ok BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC supported by BootLoader! BL : BatteryLevel : 3764 mV BL : BatteryLevel Ok BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000000600000-0x0000000000100000 Erase : 0x0000000002720000-0x0000000078C60000 Flash Pre-Erase Done, time used : 00:00:06 SecCfg Passed , 1799 BMT remark not need. Will skip Sending Preloader ... Use : preloader.bin Preloader Sent , Init passed SecCfg Passed , 1799 PartCount : FFFFFFFF PartErr : Not initialized , will update PMT now ... Repartition Failed! Something wrong with HW or BL? Try make "Flash Erase" first! Operation Failed Elapsed: 00:00:55 Reconnect Power/Cable! Operation : Flash Erase [ v1.53 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 85 ] Sync... Inital Boot Ok! BB_CPU_PID : 6583 BB_CPU_NME : [MediaTek] MT6583|6589_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.3.2 on BBID : 0x86 NAND Flash : NOT INSTALLED eMMC Flash : 484A019064314734070186042B50EB83 Initialize Memory ... DRAM configured from ScatFW! DRAM initialize passed! DRAM size : 0x20000000 DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A48344731640486010783EB502B [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00200000 [eMMC] : FLASH_LEN : 0x00000000E7000000 [eMMC] : FLASH_UCP : 3696 MiB [eMMC 4 GiB] DEV RID : 0x5A886C16041EF1EE7642AD45E76B5943 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Erase Flash now ... Erase whole flash Flash erase done Done! Elapsed: 00:00:19 Reconnect Power/Cable! Operation : Flash [ v1.53 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 85 ] Sync... Inital Boot Ok! BB_CPU_PID : 6583 BB_CPU_NME : [MediaTek] MT6583|6589_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.3.2 on BBID : 0x86 NAND Flash : NOT INSTALLED eMMC Flash : 484A019064314734070186042B50EB83 Initialize Memory ... DRAM configured from ScatFW! DRAM initialize passed! DRAM size : 0x20000000 DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A48344731640486010783EB502B [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00200000 [eMMC] : FLASH_LEN : 0x00000000E7000000 [eMMC] : FLASH_UCP : 3696 MiB [eMMC 4 GiB] DEV RID : 0x5A886C16041EF1EE7642AD45E76B5943 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6589 , Project : MTK6589 , Storage : eMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Enabled Switching to HSUSB HSUSB Init Ok BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC supported by BootLoader! BL : BatteryLevel : 3656 mV BL : BatteryLevel Ok BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000000600000-0x0000000000100000 Erase : 0x0000000002720000-0x0000000078C60000 Flash Pre-Erase Done, time used : 00:00:06 SecCfg Passed , 1799 BMT remark not need. Will skip Sending Preloader ... Use : preloader.bin Preloader Sent , Init passed SecCfg Passed , 1799 PartCount : FFFFFFFF PartErr : Not initialized , will update PMT now ... Repartition Failed! Something wrong with HW or BL? Try make "Flash Erase" first! Operation Failed Elapsed: 00:01:13 Reconnect Power/Cable! |
