05-25-2019, 11:25 | #1 (permalink) |
No Life Poster Join Date: Sep 2007 Location: Madrid, Spain
Member: 591052 Status: Offline Sonork: 100.1592747 Thanks Meter: 95 | Flashing problme with Alcatel 5045x Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 37 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : NOT INSTALLED Initialize Memory ... [DA_ERROR] : DRAM Configure failed! ErroCode : 0xC40B0000 EMICFG_RET_FAILED CodeDefine : DA_DEVICE_NOT_FOUND Boot Error! Operation Failed Elapsed: 00:00:49 Reconnect Power/Cable! |
05-25-2019, 11:28 | #2 (permalink) |
Member: 591052 Status: Offline Sonork: 100.1592747 Thanks Meter: 95 | Infinity-Box Chinese Miracle MediaTek Service Module [ MTK ] v2.06 Load IDBase v123080 Ok! Preloader [HW DEV] Info : EMI : DEV : MT6752 EMI : SRC : preloader_jhz6735m_35u_m.bin EMI : CNT : 0008 EMI : [00] : eMCP : eMMC+LP/DDR3 , ID : FE014E50314A39354B : VEN : MICRON | DEV : P1J95K : RAM : [ 1.00 GB ] EMI : [01] : eMCP : eMMC+LP/DDR3 , ID : 110100303038473730 : VEN : TOSHIBA | DEV : 008G70 : RAM : [ 1.00 GB ] EMI : [02] : eMCP : eMMC+LP/DDR3 , ID : 150100464E31324D42 : VEN : SAMSUNG | DEV : FN12MB : RAM : [ 1.00 GB ] EMI : [03] : eMCP : eMMC+LP/DDR3 , ID : 150100514E31534D42 : VEN : SAMSUNG | DEV : QN1SMB : RAM : [ 1.00 GB ] EMI : [04] : eMCP : eMMC+LP/DDR3 , ID : 1F0100534850383038 : VEN : UNKNOWN | DEV : SHP808 : RAM : [ 1.00 GB ] EMI : [05] : eMCP : eMMC+LP/DDR3 , ID : 150100513331364142 : VEN : SAMSUNG | DEV : Q316AB : RAM : [ 1.50 GB ] EMI : [06] : eMCP : eMMC+LP/DDR3 , ID : 90014A484147346132 : VEN : HYNIX | DEV : HAG4a2 : RAM : [ 1.50 GB ] EMI : [07] : eMCP : eMMC+LP/DDR3 , ID : 90014A483847316505 : VEN : HYNIX | DEV : H8G1e : RAM : [ 1.00 GB ] Operation : Write Flash [ v2.06 ] Repartition : Enabled Flash Verify : Disabled Reg.Pre-Erase : Enabled Verify HW/SW : Enabled SData Backup : Disabled Safe UserData : Disabled Files :13 [FL] : Set : preloader_jhz6735m_35u_m.bin [FL] : Set : mobile_info.img [FL] : Set : simlock [FL] : Set : lk.bin [FL] : Set : boot.img [FL] : Set : recovery.img [FL] : Set : logo.bin [FL] : Set : secro.img [FL] : Set : tee1.bin [FL] : Set : tee2.bin [FL] : Set : system.img [FL] : Set : cache.img [FL] : Set : userdata.img [FL] : Total size : 0x938F925D [ 2.31 GB ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM37) MODE : BOOTROM PORT : 37 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : BOOTROM MODE : 0_base : BASE_v1712 | Manual : Disabled Fail to disable Dog! AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6735 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : BROM : DL MODE ERROR eMMC : 00000000000000000000000000000000 DAInf: 4 : 2 : 155 DA : EXT_RAM NOT initialized! eMMC : BROM : DL MODE ERROR eMMC : 00000000000000000000000000000000 NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 EMI : DEV : MT6752 EMI : SRC : preloader_jhz6735m_35u_m.bin EMI : CNT : 0008 EMI : [00] : eMCP : eMMC+LP/DDR3 , ID : FE014E50314A39354B : VEN : MICRON | DEV : P1J95K : RAM : [ 1.00 GB ] EMI : [01] : eMCP : eMMC+LP/DDR3 , ID : 110100303038473730 : VEN : TOSHIBA | DEV : 008G70 : RAM : [ 1.00 GB ] EMI : [02] : eMCP : eMMC+LP/DDR3 , ID : 150100464E31324D42 : VEN : SAMSUNG | DEV : FN12MB : RAM : [ 1.00 GB ] EMI : [03] : eMCP : eMMC+LP/DDR3 , ID : 150100514E31534D42 : VEN : SAMSUNG | DEV : QN1SMB : RAM : [ 1.00 GB ] EMI : [04] : eMCP : eMMC+LP/DDR3 , ID : 1F0100534850383038 : VEN : UNKNOWN | DEV : SHP808 : RAM : [ 1.00 GB ] EMI : [05] : eMCP : eMMC+LP/DDR3 , ID : 150100513331364142 : VEN : SAMSUNG | DEV : Q316AB : RAM : [ 1.50 GB ] EMI : [06] : eMCP : eMMC+LP/DDR3 , ID : 90014A484147346132 : VEN : HYNIX | DEV : HAG4a2 : RAM : [ 1.50 GB ] EMI : [07] : eMCP : eMMC+LP/DDR3 , ID : 90014A483847316505 : VEN : HYNIX | DEV : H8G1e : RAM : [ 1.00 GB ] EMI : Init EMI from PRELOADER INIT : 0xBC : PRELOADER_INFO [ 0x00000000 : [ 0 B ] ] DA : Failed to configure DA! ERROR : 00000000 : OK Error : Fail to init protocol! Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! |
