flex file for x300 Dear! Is there a flex file for x300?after i flash my death x300 with infinity the phone alive,but the lcd is blank,and other x300 death can't boot with infinity.Please help and give me a good solution for those.I'm a new on Panasonic solution. Many thanks for your help IS THERE ALSO HAVE A CB2000 WITH NEW VERSION FOR SUPPORT X300? |
Flex files for X300 is called "MAP". Check support area and FlashFiles description. You will see what combination of MAIN/MAP/LangPack files you have to use. To be sure that your X300 problem is not software problem, make this: Flash your phone again with latest firmware, select all 3 parts for flashing: MAIN+MAP+LangPack. Also, be sure that "Erase FFS" box is Checked. After this, you can make "Unlock" to rebuild security area. After flash process complete, Power-On phone. For first Power-On try you have to press and hold phone Power button for several second. If after this operation your phone still can't work correctly, then I think you need to check phone hardware. As about your second phone, that can't boot. Check bottom phone connector. Maybe it's damaged/dirty. CB2000: there is NO CB2000 software for X300. |
thanks for your info i will try again and post result have a nice weekend to you and Infinity Team |
Yes.hardware Problem.water Damages Inside |
