Old 08-06-2005, 17:08   #1 (permalink)
Member: 47384
Thanks Meter: 8
flex file for x300
Dear!
Is there a flex file for x300?after i flash my death x300 with infinity the phone alive,but the lcd is blank,and other x300 death can't boot with infinity.Please help and give me a good solution for those.I'm a new on Panasonic solution.
Many thanks for your help
IS THERE ALSO HAVE A CB2000 WITH NEW VERSION FOR SUPPORT X300?
Old 08-06-2005, 17:49   #2 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,201
Originally Posted by baomobile
Dear!
Hello,
Flex files for X300 is called "MAP". Check support area and FlashFiles description. You will see what combination of MAIN/MAP/LangPack files you have to use.
To be sure that your X300 problem is not software problem, make this:
Flash your phone again with latest firmware, select all 3 parts for flashing: MAIN+MAP+LangPack.
Also, be sure that "Erase FFS" box is Checked.
After this, you can make "Unlock" to rebuild security area.
After flash process complete, Power-On phone. For first Power-On try you have to press and hold phone Power button for several second.
If after this operation your phone still can't work correctly, then I think you need to check phone hardware.
As about your second phone, that can't boot. Check bottom phone connector. Maybe it's damaged/dirty.
CB2000: there is NO CB2000 software for X300.
Old 08-06-2005, 19:06   #3 (permalink)
Member: 47384
Thanks Meter: 8
thanks for your info
i will try again and post result
have a nice weekend to you and Infinity Team
Old 08-06-2005, 21:36   #4 (permalink)
Member: 47384
Thanks Meter: 8
Yes.hardware Problem.water Damages Inside
Flex file for emmi2d for xx-13-xx suryatech Motorola Old Legacy (EMMI) 1 08-21-2002 13:37
Need flex file for Pemaster for BA_07_77 Bogi Motorola Old Legacy (EMMI) 0 06-27-2002 00:26
Flex file for v3690 needed cobba Motorola Old Legacy (EMMI) 0 02-11-2002 23:52
I need flex files for T180 GSM Brothers Motorola Old Legacy (EMMI) 4 01-14-2002 07:50
need german flex file for V51(italian) John_Doe Motorola Old Legacy (EMMI) 0 11-15-2000 22:50
Page generated in 0.26779 seconds with 8 queries
