Old 10-10-2008, 19:44   #1 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,071
"Flight mode" solution
Dear Friends,
As I can see during last days we have big discussion about "Flight mode" problem.
Many threads was started but in fact it was not many real answer for many questions.
Let's post here REAL TESTED solutions for this problem.
Please, post here phone model name and the method that you have used to fix the problem.
Thank you for understanding.
The Following 16 Users Say Thank You to InfinitySupport For This Useful Post:
Old 10-10-2008, 19:49   #2 (permalink)
unlock trigger's Avatar
Member: 818352
Thanks Meter: 266
Tested on sigmatel S2,S3,S4,S9,S90
With out sim *#3646633#
You wil get eng menu
Option 5 misc
Option 6 assert testing
Now menu will open
U Can select dual mode
The Following 47 Users Say Thank You to unlock trigger For This Useful Post:
Old 10-10-2008, 19:56   #3 (permalink)
Member: 205157
Sonork: 100.1574537
Thanks Meter: 81
even i tested works only for this models
The Following User Says Thank You to cellncare For This Useful Post:
Old 10-10-2008, 21:45   #4 (permalink)
Member: 732994
Thanks Meter: 80
Format and will get OK
Safe Mode done on 2 models
The Following 3 Users Say Thank You to MrDevil For This Useful Post:
Old 10-10-2008, 22:05   #5 (permalink)
ali_imran's Avatar
Member: 481609
Sonork: 100.1659889
Thanks Meter: 360
many more sigmatell after fprmating is problem solved like s1 s2 s3 s4 s9
but code some time can't work
The Following 3 Users Say Thank You to ali_imran For This Useful Post:
Old 10-10-2008, 22:40   #6 (permalink)
Member: 732994
Thanks Meter: 80
Never had a single problem with safe format ,using Spiderman for pinfinding and
Infinity for working on phone.
I think is the perfect combination
The Following 5 Users Say Thank You to MrDevil For This Useful Post:
Old 10-11-2008, 09:14   #7 (permalink)
maplegsm's Avatar
Member: 391664
Sonork: Python
Thanks Meter: 1,061
Originally Posted by InfinitySupport View Post
Dear Friends,
keep it infinity team and thanX for making good sticky thread
MapleGsm(umer)
Old 10-11-2008, 09:16   #8 (permalink)
Sahil2007's Avatar
Member: 598395
Thanks Meter: 663
Old 10-11-2008, 09:27   #9 (permalink)
frnd_4_gsm's Avatar
Member: 279604
Sonork: 100.1582858
Thanks Meter: 198
I use format opption in sigmatel s4 its work for flight mode and menu not opening problem
The Following User Says Thank You to frnd_4_gsm For This Useful Post:
Old 10-11-2008, 22:19   #10 (permalink)
Member: 130995
Hello,
As I can see from many user's replies and many private discussions the most universal and stable method to fix this problem is: make "format ffs" in "safe" or in "complete" mode with Infinity-Box and restore original imei after operation.
The Following 2 Users Say Thank You to InfinitySupport For This Useful Post:
Old 10-11-2008, 22:22   #11 (permalink)
Member: 130995
but code some time can\'t work
Hello,
If you have any flash backup from good working S9, please, send backup file and pinout to [email protected]
The Following User Says Thank You to InfinitySupport For This Useful Post:
Old 10-11-2008, 23:00   #12 (permalink)
summer_20xx's Avatar
Member: 167622
Sonork: 100.1608761
Thanks Meter: 40
Hello,
yes , the perfect methode is to format ffs.
btw the same solution work also with alcatel C701 and c707 ... etc
Old 10-11-2008, 23:13   #13 (permalink)
Member: 732994
Thanks Meter: 80
Yes ,This crap phones doesnt hold too much inside
Infinity best software for china phones
And i have all boxes
Old 10-12-2008, 19:02   #14 (permalink)
zeerik's Avatar
Member: 282066
Sonork: 100.1590696
Thanks Meter: 542
Hello,
but this method is not working ....1110i was in flight mode i format ffs.....now set gives "bad software"error ...try to repair bad software but process failed .....then flash it back file now set again on flight mode
Old 10-12-2008, 22:15   #15 (permalink)
Member: 732994
Thanks Meter: 80
Did u made Full format or Safe mode Repair?
1110i "flight mode" error zeerik Infinity-Box 16 08-18-2009 20:39
sharp 550sh "flight mode" barani Sharp 2 06-03-2009 18:20
anyone have perfect solution of "bootloder mode" msantar Motorola P2k 2 02-17-2009 21:56
Sharp 903sh in "Flight Mode" how to de-activate? ReyTech Cruiser Suite 3 08-16-2007 15:33
Phoenix Black Box no "LOCAL MODE" solution karwos Phoenix Black Box 4 11-15-2005 19:07
Page generated in 0.42779 seconds with 8 queries
