12-26-2006, 13:32 | #1 (permalink) |
No Life Poster Join Date: May 2003 Location: Ru Age: 48
Member: 29155 Status: Offline Thanks Meter: 15 | Fly 2040 AMD can't flash with infinity tryed all speeds and flash metods - results are the same COM9 selected Device: Fly 2040 Checking data, wait... Action: Flash write "SmartWrite" enabled Write: Firmware Skip: Customization Skip: Language Pack Skip: Eeprom Boot... Press and HOLD Power button now ! Connecting, wait... Initializing[6227:8A02]... Release Power button now ! Boot Done Initialize... detecting chip[00] in region[00]... flash: 01227E22212200 flash: 29EA0000000000 flash: Amd T 8Mb detecting chip[01] in region[00]... flash: 01227E22212200 flash: 9A075A00000000 flash: Amd T 8Mb total number of flash chip detected: 02 Initialize Done Set baud... 460800 Set baud Done Check space... flash: 01227E22212200 flash: 29EA0000000000 Check space Done Write... Area: Firmware flash: 01227E22212200 flash: 29EA0000000000 Write: Firmware Err: error# 000000FF Err: flash write error: 00002000:00002000 Write Fail Finished, time used: 36 sec Remove/Install battery now ! After that phone is dead I flashed it with FlashTool_v2.7.1016 - ok Repair imei with infinity - phone is completly working Tested on 2 pcs of 2040 - the same errors (M-module v 1.24) Please fix this bug BR |
01-16-2007, 13:12 | #6 (permalink) | |
01-17-2007, 11:06 | #7 (permalink) | |
Freak Poster Join Date: Oct 2003 Location: Bucharest - Romania
Member: 41354 Status: Offline Thanks Meter: 11 | Quote:
01-17-2007, 15:31 | #8 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | When I say "as ordinary" this means only "as ordinary", nothing else. Did you tried to check this file from "pinouts": Fly-MX200(i)_MX300_SL500(i)_2040(i)_SL600.jpg |
01-17-2007, 17:35 | #9 (permalink) | |
That's the only pinout?(for this model) or there is another one like 2060? I mean a "force-mode" to communicate with phone by another method (in case that the phone has problem with that connector ). Regards and sory again | |
01-17-2007, 17:48 | #10 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hi, probably it's possible to connect Rx/Tx wires directly to PCB but I don't have correct information right now about any test-point locations far from phone connector. You can simply open phone, check where is pins from phone connector soldered to PCB and connect box rx/tx/gnd there. 2060 and 2040 is very different models, no any relation. |
01-19-2007, 10:19 | #11 (permalink) |
Member: 41354 Status: Offline Thanks Meter: 11 | Ok, thanks a lot for the answer, I think ( in fact i am shure ) the phone connector is dammaged (water damagged long time ago )that's why i asked for another solution. Regards |
LG KP170 can't unlock with infinity | Unicom | Infinity-Box | 2 | 08-22-2009 05:48 |
Moto W370 can't unlock with Infinity Box | Unicom | Infinity-Box | 2 | 02-19-2009 11:54 |
Moto W377 can't unlock with infinity | Unicom | Infinity-Box | 12 | 02-10-2009 22:03 |
kp 135 can't boot with infinity | agadir5241 | Infinity-Box | 2 | 12-23-2008 21:32 |
Vodafone(ZTE)225 Can't unlock with Infinity | Unicom | Infinity-Box | 7 | 10-15-2008 14:24 |
