05-11-2005, 09:00 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello ! Please, use default settings (optimal settings set by software by default at start). If you have problems with INITIAL connection, then try to use other Modes. If your phone can connect to soft, but software freez/show errors after booting, then use "Slow mode" option. ------------------------- RJ45 FEMALE pinout. Connector pins up. From left to right LEFT RJ45 (USB) 1 = +5V USB power 2 = Tx 3 = Rx 4 = RTS 5 = CTS 7 = GND 8 = GND ------------------------- Bird connector: KEYBOARD TOP 1 ... 18 15: Rx 16: Tx 17: Gnd ------------------------- B.R. InfinitySupport |
05-25-2005, 09:28 | #4 (permalink) | |
Could you, pls, describe the problem exactyl ? What is wrong ? Also, pls, include in your bug report text from Log window, so we can check what is wrong. B.R. InfinitySupport | |
05-26-2005, 14:45 | #5 (permalink) |
No Life Poster Join Date: Mar 2004 Location: pccomp Age: 42
Member: 59173 Status: Offline Sonork: 100.1585568 Thanks Meter: 225 | Loading, wait... S/N: 00D0:0103 Ready Err: no data to write Loading: S688_v128_en_ru_FW_wo_FFS.0FX.bin Loaded Press Power button... Connect... Connect Ok Boot... Boot Ok Read info... CHIP ID: 89DD Err: FLASH CHIP NOT SUPPORTED Read info fail Finished |
05-26-2005, 15:52 | #6 (permalink) | |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello ! Please, try to use "Slow mode" option and let us know about results. This error can be not only due to new hardware, but also other reason: bad communication. Please, try to use "Slow mode" and give us results. B.R. InfinitySupport Quote:
05-31-2005, 13:13 | #11 (permalink) |
No Life Poster Join Date: Mar 2002 Location: gsmcity Age: 45
Member: 10505 Status: Offline Sonork: 100.40828 Thanks Meter: 364 | The same is here. Press Power button... Connect... Connect Ok Boot... Boot Ok Read info... CHIP ID: 8967 Err: FLASH CHIP NOT SUPPORTED I have tried all modes (1-3) and slow and fast modes. Read info fail Finished BR levsha |
05-31-2005, 13:27 | #12 (permalink) | |
Please, check latest update. Bird software was improved. If you will have problems with latest release, please, read flash from your phone and send to us. Also, please, include Log file in your mail. B.R. InfinitySupport | |
06-01-2005, 19:33 | #14 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello ! Thanks for offer ! If you still have problems with unsupported flash with our latest Bird soft release then just read flash and send to us, pls, readed flash and software log file. If your problem solved, then no need to make any other research. B.R. InfinitySupport |
06-02-2005, 18:16 | #15 (permalink) |
Member: 10505 Status: Offline Sonork: 100.40828 Thanks Meter: 364 | First of all I want to say thanks for great support, Infinity Team! Today I succesfully reflashed S688 with CHIP ID: 8967. Now the phone can make calls. Before flashing main+FFS it reloaded in time of the call. PS: thanks once more for newest update 1.09. BR levsha |
06 Jun 2008: "MModule" v2.23 Fly-LX610, Fly-M130, Fly-Levis-LV1, Micromax-X1u, ...... | zinoubinabil | Infinity-Box | 23 | 06-22-2008 19:10 |
06 Jun 2008: "MModule" v2.23 Fly-LX610, Fly-M130, Fly-Levis-LV1, Micromax-X1u, ...... | zinoubinabil | Service Products News & Updates | 1 | 06-06-2008 11:14 |
Fly S688 deed afte flash | Mistreated | Infinity-Box | 1 | 11-22-2005 16:49 |
