Old 10-11-2006, 15:44   #1 (permalink)
irfanamin2's Avatar
Member: 82423
Thanks Meter: 1,203
C168 Problem
I have C168 porblem is when i insert sim i get this errore "Unauthorized Phone" any solution.
Br.
Old 10-11-2006, 16:05   #2 (permalink)
irfanamin2's Avatar
Member: 82423
Thanks Meter: 1,203
I try :
Hello,
Try to make this:
1. "Reset"
2. Make "repair" box checked and make "Prepare" operation.
But now phone is restart condition. any solution....
Old 10-11-2006, 17:45   #3 (permalink)
Member: 130995
Thanks Meter: 35,227
what do you mean "restart" ?
explain the problem more detailed.
Old 10-11-2006, 18:29   #4 (permalink)
Niaz Hussain's Avatar
Member: 117640
Sonork: 100.1580505
Thanks Meter: 62
same problem here
after reset phone automaticaly again and again restart .
and i chack with full flash same condition what i update formware ?
Old 10-11-2006, 19:23   #5 (permalink)
Member: 130995
Originally Posted by Niaz Hussain View Post
same problem here
what is this phone history ?
what was the reason that you tried to make reset ?
Old 10-13-2006, 19:52   #6 (permalink)
irfanamin2's Avatar
Member: 82423
Thanks Meter: 1,203
When i flash phone my phone go "Unauthorized Phone" then I try :
Hello,
Try to make this:
1. "Reset"
when I press power phone completely on but I do any thing phone restart 6-10 second continue this prosses . any solution....
Old 10-13-2006, 21:36   #7 (permalink)
Member: 130995
Could you, please, explain what happen with phone ?
After what operation phone become restart ?
did you tried to power on phone w/sim ?
did you tried to power on phone w/o sim ?
did you tried to make 112 call w/sim and w/o sim ?
I need so detailed info as possible.
I think you know that good problem/process description = 99% of good answer.
Old 11-22-2006, 10:04   #8 (permalink)
irfanamin2's Avatar
Member: 82423
Thanks Meter: 1,203
Restart with sim cared
Old 11-22-2006, 14:38   #9 (permalink)
Member: 130995
thank you very much for extra-mega-super-detailed problem description.
Old 11-22-2006, 15:06   #10 (permalink)
i_seeque's Avatar
Member: 15238
Thanks Meter: 128
let me explain.
phone status:
>>before any operation with infinity - "unauthorized phone" with SIM
>>after - prepare and repair unauthorized with infinity - without sim phone shows insert sim AND with simcard.. it prompts to set date and time BUT before we finish that steps phone starts rebooting. Again it comes to date /time settings OR searching.
>> and in any case upon[bfore and after software] *#06# - imie no. ________ blank.
Though in process window software shows the IMEI backed eeprom up etc. etc. But here pl note that - THE imei shown in process window does not match the phone's original IMEI !!!
Old 11-23-2006, 07:11   #11 (permalink)
tuhingr's Avatar
Member: 152752
Sonork: 100.1581661
Thanks Meter: 182
I have problem that.
Moto 168
when use with sim then sometime ok and sometimes hang.
i tried to reset, still same!
can i full flash it? with same ver.?
Old 11-23-2006, 14:37   #12 (permalink)
cgsm's Avatar
Member: 88402
Thanks Meter: 489
Same Problem Here also
I received mot c168 with the complaint 'UNAUTHORISED PHONE'
I tick the box 'Repair "unauthorised Phone"' and i give ' Prepare '
after this process i remove the cable and battery insert the battery without sim card its not rebooting
when i put the sim card its rebooting continuesouly within 5 seconds.
without simcard when i press *#06# it shows nothing IMEI is blank.
Any soultion to solve this problem sir
Old 11-23-2006, 16:14   #13 (permalink)
Member: 130995
Power On phone w/o SIM.
Start Moto02 and make "Reset".
Waiting for results.
Old 03-08-2007, 16:56   #14 (permalink)
rajiv007's Avatar
Member: 78767
Sonork: 100.95137
Thanks Meter: 566
no not working your trick
same restart with simcard and imei blank, No service
what to do now
Old 03-08-2007, 18:09   #15 (permalink)
Member: 130995
@rajiv007
more threads about c168 can be found in this forum 1 minute.
try to use diffierent flash files sets
try to use repair eeprom files
acount id problem.help uregent plz [SOLVED] dani2080 PolarBox 3 2 03-29-2010 12:46
c168 problem jmustufa Infinity-Box 2 02-23-2009 17:44
c168 problem abhishek aga ET-BoX 0 05-08-2008 12:02
c168 problem Mang mel Infinity-Box 6 09-06-2007 17:51
C168 problem help me pls. thuanloivtnt Infinity-Box 3 10-10-2006 02:52
Page generated in 0.31239 seconds with 10 queries
