03-10-2008, 18:08 | #1 (permalink) |
No Life Poster Join Date: Nov 2005 Location: Port Harcourt Nigeria Age: 51
Member: 197720 Status: Offline Thanks Meter: 24 | fly sl399e unlock problem |
03-10-2008, 20:30 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, I can't beleive that nothing helps. Please, explain step-by-step what you have tried to do, what flash files you have used, post logs. Please, don't write "I have done exactly as written in manual" because it can't be so. |
03-14-2008, 22:29 | #5 (permalink) |
Freak Poster Join Date: Mar 2005 Age: 46
Member: 122869 Status: Offline Thanks Meter: 11 | I have also problem with one SL399e from virgin mobile.Unlocked with all posible metods from softw. but nothing.Flashed with the file from support still same.Maked safe and complete resset same.Any other advice????? I have full beckup if needed I can send it??? Here is the log of last atempt to unlock: COM10 [VCP0] selected Action: unlock unlock method: smart fast Model: Fly SL399E Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing[6219:8B02:8B01]... CPU: MT6219 chip: 0031:EBC1:62B6 CPU: MT6226MA detected Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226M,E02 Date: 2005.04.12 Version: 1.0 Version: SL390M.06A.W06.36.MP.V36.F2 Version: EZIO27_06A_HW 42 byte(s) read imei: 13579024681122 connection Ok 145 byte(s) read reading data... building new data... writing data... done Finished, time used: 10 sec Remove/Install battery now WBR |
03-14-2008, 22:35 | #6 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, What code phone ask you when you insert wrong sim card ? Are you sure that you have flashed phone with firmware according to manual ? What firmware you have used for flashing ? |
11-17-2008, 06:42 | #12 (permalink) |
No Life Poster Join Date: Apr 2007 Location: BIRMINGHAM UNITED KINGDOM Age: 34
Member: 488632 Status: Offline Thanks Meter: 391 | FLY SL399E WIV INFINITY BOX SUCCESSFULLY BY YASERMALIK Fly-SX305_SL390M_MERID_RU_PCB01_gprs_MT6226M_S01.SL390 M.06A.W06.36.MP.V36.F2_E6.02R_En_Ru_Ua DOWNLOAD THIS FLASHING FROM SUPPORT IN FLY SX305 FOLDER AND FLASH FONE AFTER FLASHING FORMAT NO NEED TO UNLOCK FONE HERE IS LOG COM4 [VCP0] selected module v2.41 Device: Fly-SL399E Checking data, wait... advanced flash detection enabled Action: write NOR flash "smart write" active write: Firmware skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6219:8B02:8B01]... CPU: MT6219 detected CPU: MT6226MA chip: 0031:EBC1:6EB6 boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: B0001D00000000:B0001D00000000 flash: Sharp Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw 1: SL390M_MERID_RU_PCB01_GPRS_MT6226M_S01.SL390M.06 A.W06.36.MP.V36.F2.BIN ver. sw 2: SL390M.06A.W06.36.MP.V36.F2, 00000000 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished sim-lock status: unknown Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... Area: Firmware flash: B0001D00000000:B0001D00000000 Write: Firmware detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished Write Done Finalization ... Finalization Done Finished, time used: 2176 sec Remove/Install battery now ! COM4 [VCP0] selected module v2.41 Action: reset settings Model: Fly-SL399E Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6219:8B02:8B01]... CPU: MT6219 chip: 0031:EBC1:6EB6 detected CPU: MT6226MA Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226M,E02 Date: 2005.04.12 Version: 1.0 Version: SL390M.06A.W06.36.MP.V36.F2 Version: EZIO27_06A_HW 42 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok building list... done items to clear: 156 warning: wrong packet cs 156 of 156 items cleared building list... done 0 items remains Finished, time used: 42 sec Remove/Install battery now ! THANX INFINITY TEAM KEEP IT UP BR YASERMALIK TAHIRMALIK ZAHIDMALIK DOC-UNLOCK DADYAL XPERT UNLOCK UK |
The Following 2 Users Say Thank You to yasermalik For This Useful Post: |
11-17-2008, 10:30 | #13 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems and successfully done work. |
12-26-2009, 05:28 | #14 (permalink) | |
Cheater -Don't Deal with him- Join Date: Nov 2007
Member: 635691 Status: Offline Sonork: 100.1592330 Thanks Meter: 137 | 100% Unlocked Fly SL399e with Infynity Unlock done after flash phone with "Fly-SX305_SL390M_MERID_RU_PCB01_gprs_MT6226M_S01.SL390 M.06A.W06.36.MP.V36.F2_E6.02R_En_Ru_Ua.B0M" thanks Infinity Team Quote:
The Following 2 Users Say Thank You to mimounts For This Useful Post: |
12-26-2009, 06:15 | #15 (permalink) |
Member: 635691 Status: Offline Sonork: 100.1592330 Thanks Meter: 137 | schema Cable: Fly-SX210; Fly SL399E; Fly E105; Fly E300; Hummer-HT1; Levis-LV1 LX500; LX600; LX610; MC100; SLT100; SX100; SX200; SX210; SX220; SX305.... |
Fly SL399E UNLOCKING PROBLEM | ..::: Naveed :::.. | Infinity-Box | 9 | 09-06-2009 08:02 |
fly sl399e unlock | newerno | Infinity-Box | 1 | 11-23-2008 14:21 |
Fly SL399E Unlock problem | mobilewiz | Infinity-Box | 2 | 08-20-2008 14:16 |
please Fly-SL399E UNLOCK.... HELP | karikari | Infinity-Box | 1 | 08-15-2008 13:38 |
Fly SL399E unlock | Anees-ur-rehman | Infinity-Box | 4 | 12-08-2007 12:54 |
