Old 10-08-2008, 20:41   #1 (permalink)
karikari's Avatar
Member: 390204
Sonork: 100.1592805
Thanks Meter: 138
Fly SL500i Master code unlocked
COM2 [VCP0] selected
Device: Fly-SL500i
Checking data, wait...
eeprom backup enabled, it may takes several minutes !
Action: "sp-unlock"
unlock method: standard
Boot...
19200 fixed
Connecting, wait...
Initializing[6219:8B02:8B01]...
CPU: MT6219
CPU: MT6226MA detected
chip: 0031:3FC1CC6
boot step size: 0400
Release Power button now !
Boot Done
Initialize...
flash: B0001D00000000:B0001D00000000
flash: Sharp Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb
Initialize Done
Set baud...
115200
Set baud Done
Initialize bootcode...
Initialize bootcode Done
Check firmware integrity...
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [standard] generation
identification#1 protocol ver: 04
ver. sw1: SL900A_UKFLY_PCB01_GPRS_MT6226M_S01.SL900A_05C_W06 _08_MP_V72_F2.BIN
ver. sw2: SL900A.05C.W06.08.MP.V72.F2, 00000000
ffs offset/size: 00E00000/00200000
detect device identification#2...
warning: optional information is not found,
if phone works well just ignore this warning
detect device identification#2 finished
Check firmware integrity Done
Check firmware content...
Check firmware content Done
Backup required data...
reading: eeprom[SL900A_UKFLY_PCB01_GPRS_MT6226M_S01.SL900A_05C_W06 _08_MP_V72_F2.BIN]...
file saved: C:\Program Files\InfinityBox\MModule\eeprom[SL900A_UKFLY_PCB01_GPRS_MT6226M_S01.SL900A_05C_W06 _08_MP_V72_F2.BIN]_20081008-183254.B0E.bin
Backup required data Done
Patch required data...
detection procedure, wait...
detection procedure completed
Patch required data Done
Special operation...
detecting additional parameters...
Write: area 0/1
additional parameters detected Ok
Special operation Done
Write...
Write: eeprom
Write Done
Finalization...
Finalization Done
Finished, time used: 506 sec
Remove/Install battery now !
Thanks to infinity team........
The Following User Says Thank You to karikari For This Useful Post:
Old 10-08-2008, 22:03   #2 (permalink)
Masud-GSM's Avatar
Member: 396988
Sonork: 100.1613227
Thanks Meter: 180
Thankx for nice info...........................
Masud
Old 10-08-2008, 22:20   #3 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,296
@karikari
Thank you very much for test report !
Each test report with attached logs is very important for us so we can see how is Infinity-Box
software works and what is possible problems and successfully done work.
Old 10-11-2008, 17:10   #4 (permalink)
Imran Bhatti's Avatar
Member: 266874
Sonork: 100.1581444
Thanks Meter: 94
COM3 [VCP1] selected
Device: Fly-SL500i
Action: "sp-unlock"
Boot...
19200 fixed
Connecting, wait...
CPU: MT6219
chip: 0031:63B6:B875
Boot Done
Initialize...
flash: 89881500010001:89881500000000
flash: Intel Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb
Initialize Done
Set baud...
115200
Set baud Done
ver. sw1: SL900A_UKFLY_PCB01_GPRS_MT6226M_S01.SL900A_05C_W06 _08_MP_V72.BIN
ver. sw2: SL900A.05C.W06.08.MP.V72, 00000000
reading: eeprom[SL900A_UKFLY_PCB01_GPRS_MT6226M_S01.SL900A_05C_W06 _08_MP_V72.BIN]...
file saved: C:\Program Files\InfinityBox\MModule\eeprom[SL900A_UKFLY_PCB01_GPRS_MT6226M_S01.SL900A_05C_W06 _08_MP_V72.BIN]_20081011-080809.B0E.bin
Write: area 0/1
error: error# 000000FF
error: flash write error: 00860000:00002000
error: no any expected answer
error: can't write required area
error: additional parameters detection failed
Write...
error: no any expected answer: wrong answer after chip id request
error: no any expected answer: wrong answer after chip cfi request
Write Fail
Finished, time used: 353 sec
Old 10-11-2008, 17:15   #5 (permalink)
kasrawiz's Avatar
Member: 340564
Sonork: 1591034
Thanks Meter: 524
Good info bro thanks
Old 10-11-2008, 18:05   #6 (permalink)
Member: 266874
Sonork: 100.1581444
Thanks Meter: 94
After writting eprom success/
Device: Fly-SL500i
Action: "sp-unlock"
Boot...
19200 fixed
Connecting, wait...
CPU: MT6219
Boot Done
Initialize...
Initialize Done
Set baud...
115200
Set baud Done
file saved: C:\Program Files\InfinityBox\MModule\eeprom[SL900A_UKFLY_PCB01_GPRS_MT6226M_S01.SL900A_05C_W06 _08_MP_V72.BIN]_20081011-085852.B0E.bin
Write: area 0/1
Write...
Write: eeprom
Write Done
Finalization...
Finalization Done
Finished, time used: 473 sec
Old 10-11-2008, 18:06   #7 (permalink)
Member: 266874
Sonork: 100.1581444
Thanks Meter: 94
Device: Fly-SL500i
Action: "sp-unlock"
Boot...
19200 fixed
Connecting, wait...
CPU: MT6219
Boot Done
Initialize...
Initialize Done
Set baud...
115200
Set baud Done
Write: area 0/1
Write...
Write: eeprom
Write Done
Finalization...
Finalization Done
Old 10-11-2008, 18:07   #8 (permalink)
Member: 266874
Sonork: 100.1581444
Thanks Meter: 94
Device: Fly-SL500i
Action: "sp-unlock"
Boot...
19200 fixed
Connecting, wait...
CPU: MT6219
Boot Done
Initialize...
Initialize Done
Set baud...
115200
Set baud Done
Write: area 0/1
Write...
Write: eeprom
Write Done
Finalization...
Finalization Done
Old 01-15-2009, 12:48   #9 (permalink)
raja16sep's Avatar
Member: 765990
Sonork: 100.1582347
Thanks Meter: 207
which cabel do you have used. i am using L15A cabel. and this cabel is not in pinfinder list.please help for fly SL500i.
Old 01-16-2009, 00:03   #10 (permalink)
Member: 130995
Hello,
1. you can use 2x7 cable with PinFinder in "automatic MT62xx" mode to find pinout for this model
2. Here is an instruction how to get cable/pinout information:
1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update
2. run Infinity-Box Shell
3. select required model
4. see detailed information about cable/pinout (Rx/Tx/Gnd pins and other information)
Here is information how to build your own cable:
F.A.Q., Contacts, Supported models, Cables/pinouts
The Following User Says Thank You to InfinitySupport For This Useful Post:
Old 01-16-2009, 08:38   #11 (permalink)
raja16sep's Avatar
Member: 765990
Sonork: 100.1582347
Thanks Meter: 207
with pinfinder i can not find pins. i have fixed has shown in diagram. then i have unlocked. problem is this why my pin finder donot finds rx and tx as other people. i have done all precautions. i have add capidter of 1800mf in side also. voltage is also 5v over there. but pinfinder donot find rx and tx only find and find.... run and at end says no pin finds.
Some time saya in start no pinfinder is intallized.reattach and will find.i have to reattach many times then it work. When finding rx and tx also same problem have to repeat many times(attach and reattach).
My friend has also same tool his tool work very good.what more should i do. ALL PRECATIONS I HAVE DONE IN INFINITY BOX AS IN INSTRUCTION AND IN PINFINDER ALSO,BUT NO GOOD OUT PUT. BESURE THAT MY INFINITY BOX WORK ON COM SIDE.
Old 01-16-2009, 17:14   #12 (permalink)
Member: 130995
Hello,
What phone you have tested for automatic pinout detection ?
What CPU type you have selected in PinFinder for automatic detection ?
fly sl500i dead in unlocking sebha Infinity-Box 1 08-02-2009 14:57
fly sl600 master code unlock done bittubansal Infinity-Box 2 03-11-2009 23:07
Fly Sl600 Enter Master Code Unlock Successfully maplegsm Infinity-Box 2 08-05-2008 14:31
Fly Sl600 Master Code damabib Infinity-Box 3 03-10-2008 16:07
FLY SL500i np code phoneteam Various 2 01-21-2008 06:30
Page generated in 0.44094 seconds with 8 queries
