Old 02-04-2009, 12:48   #1 (permalink)
FZA
Member: 210174
Thanks Meter: 7
Fly sl600 master code
Trying to unlock this phone but having problems.It connects but gives me error.I have two but both giving me same problem.Please help
19200 autodetect
error: boot phase #2/1 failed
Can't initialize test mode !
Possible reasons:
1. communication fault, repeat required operation
2. eeprom/ffs serious damaged, use repair eeprom/ffs files or use other unlock/format method
error: operation failed !
Finished, time used: 51 sec
Remove/Install battery now !
thanx
Old 02-04-2009, 12:58   #2 (permalink)
rana_'s Avatar
Member: 597570
Sonork: 100.1590733
Thanks Meter: 159
follow step...1. make "format ffs"
2. restore original imei
3. spunlock-read code
Old 02-04-2009, 13:40   #3 (permalink)
FZA
Member: 210174
Thanks Meter: 7
I tried But get same message for format ffs
Old 02-04-2009, 16:57   #4 (permalink)
Member: 148515
Thanks Meter: 15,047
hello!
you using wrong pinout or assembled cable wrong
Old 02-05-2009, 13:07   #5 (permalink)
FZA
Member: 210174
Thanks Meter: 7
I am using fly mx200 cable.Could you please give me the settings for this phone meaning boot baud rate,RTS/DTS line on/off
Old 02-05-2009, 13:13   #6 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,298
Hello,
Just use software default settings.
What to do now:
Try to read full flash from phone.
If phone can not be connected it's for sure cable problem and you need to double check pinout/cable.
MX200 cable is Ok for MX600, but you can try to swap RX <-> TX wires.
FLY-SL600 enter master code paklink Infinity-Box 2 06-03-2010 13:31
fly sl600 master code unlock done bittubansal Infinity-Box 2 03-11-2009 23:07
Fly SL500i Master code unlocked karikari Infinity-Box 11 01-16-2009 17:14
Fly Sl600 Enter Master Code Unlock Successfully maplegsm Infinity-Box 2 08-05-2008 14:31
Fly Sl600 Master Code damabib Infinity-Box 3 03-10-2008 16:07
Page generated in 0.24019 seconds with 8 queries
