03-11-2009, 06:03 | #1 (permalink) |
Freak Poster Join Date: Nov 2005
Member: 200548 Status: Offline Thanks Meter: 104 | fly sl600 master code unlock done COM3 [VCP0] selected Device: Fly-SL600-Vodafone Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: "sp-unlock" unlock method: standard Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6227:8A02:8A01]... CPU: MT6227 chip: 0031:EF1E:E6A4 boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: B0001D00000000:B0001D00000000 flash: Sharp Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud... 115200 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw1: SL300_UKVODA_PCB01_GPRS_MT6227_S01.SL300_05C_W06_0 8_MP_V87_F1.BIN ver. sw2: SL300.05C.W06.08.MP.V87.F1, 00000000 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading: eeprom[SL300_UKVODA_PCB01_GPRS_MT6227_S01.SL300_05C_W06_0 8_MP_V87_F1.BIN]... file saved: C:\Program Files\InfinityBox\MModule\eeprom[SL300_UKVODA_PCB01_GPRS_MT6227_S01.SL300_05C_W06_0 8_MP_V87_F1.BIN]_20090311-102901.B0E.bin flash: B0001D00000000:B0001D00000000 Backup required data Done Patch required data... detection procedure, wait... detection procedure completed Patch required data Done Special operation... detecting additional parameters... .................................... flash: B0001D00000000:B0001D00000000 flash: B0001D00000000:B0001D00000000 Write: area 0/1 ............................ additional parameters detected Ok Special operation Done Write... flash: B0001D00000000:B0001D00000000 Write: eeprom Write Done Finalization... Finalization Done Finished, time used: 476 sec Remove/Install battery now ! thanx infinity team |
The Following User Says Thank You to bittubansal For This Useful Post: |
03-11-2009, 21:53 | #2 (permalink) | |
Member: 130995 Status: Offline Thanks Meter: 35,229 | Quote:
Each test report with attached logs is very important for us so we can see how is Infinity-Box software works, what is phone hardware configuration (f.e. flash chip type) and what is possible problems (so we will be able to fix it) and successfully done work. | |
03-11-2009, 22:07 | #3 (permalink) | |
Super Moderator Join Date: Jul 2008 Location: Villa del rosario/Nsd Colombia
Member: 813309 Status: Offline Thanks Meter: 1,910 | Quote:
fly sl600 without flash unlock done | khurram86 | Infinity-Box | 5 | 05-29-2009 10:40 |
Fly sl600 master code | FZA | Infinity-Box | 5 | 02-05-2009 13:13 |
Fly SL500i Master code unlocked | karikari | Infinity-Box | 11 | 01-16-2009 17:14 |
Fly Sl600 Enter Master Code Unlock Successfully | maplegsm | Infinity-Box | 2 | 08-05-2008 13:31 |
Fly Sl600 Master Code | damabib | Infinity-Box | 3 | 03-10-2008 15:07 |
