Old 11-12-2009, 10:40   #1 (permalink)
Member: 1122148
Thanks Meter: 35
Fly SLT100 how to remoave master code
sir one fly slt100 has master code so how can i remove it
i m using kg800 cable but when i m try read the code whith that cable its giving errer like this so what clould the problem
COM12 [VCP1] selected
module v2.79
Action: user code
unlock method: smart fast
Model: Fly-SLT100
Checking data, wait...
9600 autodetect
error: boot phase #2/1 failed
Can not initialize test mode !
Possible reasons:
1. communication fault, repeat required operation
2. ffs/eeprom is serious damaged, use repair ffs/eeprom files or use other unlock/format method
error: operation failed !
Finished, time used: 7 sec
Remove/Install battery now !
if i m using wrong cable pls can u pinuts of this phone
Thank u
Old 11-12-2009, 14:51   #2 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
I think you must use correct cable instead of KG800 cable.
Here is an instruction how to get cable/pinout information:
1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update
2. run Infinity-Box Shell
3. select required model
4. see detailed information about cable/pinout (Rx/Tx/Gnd pins and other information)
Here is an example of information given by Infinity-Box Shell:
Here is information how to build your own cable:
http:///vbb/showthread.php?t=342807
Old 01-29-2010, 14:32   #3 (permalink)
makkah mobile's Avatar
Member: 226363
Sonork: 03--4899925
Thanks Meter: 569
http://forum.gsmhosting.com/vbb/show...ghlight=slt100
The Following User Says Thank You to makkah mobile For This Useful Post:
FLY SL500i - ask to enter master code Wgnr Phone Unlocking Codes & Maps 1 07-16-2014 12:37
plz help me unlock my fly slt100 ,phone says enter np code ARAB GSM Infinity-Box 8 09-15-2010 01:03
How to enter master code s5603 zablon NSPRO 3 11-09-2009 10:13
how to calculate master codes mwangikihiu Nokia Hardware & Hardware Repair 3 08-09-2009 15:50
Page generated in 0.16106 seconds with 9 queries
