05-26-2008, 07:45 | #1 (permalink) |
No Life Poster Join Date: Nov 2004 Age: 44
Member: 93610 Status: Offline Thanks Meter: 45 | Fly Sx200 Unlock Error i tried to unlock sx200, its giving following error. Please try to help me to get work phone. Do you want to continue ? operation aborted COM8 selected Device: Fly-SX200 Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: unlock unlock method: standard fast Unlock procedure can be faster if you skip eeprom area backup procedure. Do you want to disable eeprom backup ? eeprom backup disabled Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6225:8A03:8A00]... CPU: MT6225 chip: 0001:1B03:0004 boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 89881500010001:89881500000000 flash: Intel Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud... 115200 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw1: MASS2_FLYUKVG_PCB01_GPRS_MT6225_S00.MAUI_07A_W07_3 6_MP_V23.BIN ver. sw2: MAUI.07A.W07.36.MP.V23, 00000000 ffs offset/size: 00C00000/00400000 detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... flash: 89881500010001:89881500000000 Backup required data Done Patch required data... ........................................... lock area found ........................................... lock area found Patch required data Done Special operation... detecting additional parameters... ......................... flash: 89881500010001:89881500000000 flash: 89881500010001:89881500000000 Write: area 0/1 ................. flash: 89881500010001:89881500000000 flash: 000001000E000F:00000100000000 flash: 000001000E000F:00000100000000 error: can't write required area error: additional parameters detection failed Special operation Done Write... flash: 000001000E000F:00000100000000 flash: 000001000E000F:00000100000000 error: can't detect chip at required chip base flash: 000001000E000F:00000100000000 flash: 000001000E000F:00000100000000 error: can't detect chip at required chip base Write Fail Finished, time used: 90 sec Remove/Install battery now ! Thank You, Nasmi |
Fly sx200 unlock problem | Littlemaster | Infinity-Box | 12 | 12-11-2012 11:56 |
FLY SX200 succesfuly unlock (master code) | mohamedrimas | Infinity-Box | 16 | 06-21-2011 10:52 |
Fly SX200 dead while Unlock | Nasmi | Infinity-Box | 1 | 01-23-2009 17:00 |
Fly SX200 will not unlock on M-Module 2.24 | drancill | Infinity-Box | 4 | 06-29-2008 12:52 |
Fly Sx200 Cannot Be unlocked | Amir-SkillZ | Infinity-Box | 3 | 05-25-2008 08:57 |
