01-11-2010, 14:55 | #1 (permalink) |
Freak Poster Join Date: Jun 2005 Location: Romania Age: 38
Member: 151737 Status: Offline Sonork: 100.1595988 Thanks Meter: 91 | Fly-Ying F006 CPU 6235 supported or NOT module v3.05 Action: reset settings ("format ffs") Model: Autodetect 6228-6239 NAND Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6235:8A04:8A01]... CPU: MT6235 high speed boot On chip: 0000:0000:0003 status: FF rom: 4D453032 Connecting at 19200, wait... error: can not finalize test mode repeat operation and HOLD phone "Power" button long time ! error: operation failed ! Finished, time used: 1 min 24 sec Remove/Install battery now ! This CPU is not supported ? Read flash not work , Format FFS the same.....! What happend? Thx |
01-12-2010, 13:50 | #3 (permalink) |
Member: 151737 Status: Offline Sonork: 100.1595988 Thanks Meter: 91 | READ FULL FLASH COM20 [VCP0] selected module v3.05 Device: Autodetect 6228-6239 NAND Checking data, wait... Action: read firmware NAND interface: BROM_DLL_v3.932.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! CPU: 6235:8A04:8A01 bbchip secure ver: FF bbchip bl ver: FE NOR flash chip: S_DA_NOR_FLASH_NOT_FOUND NAND flash chip: S_DA_NAND_FLASH_NOT_FOUND internal RAM: S_DONE size: 00010000 external RAM: S_DA_DEVICE_NOT_FOUND boot style: S_DA_HANDSET_ROM_INFO_NOT_FOUND bootcode current/expected: 3.2, 3.2 done Set baudrate (115200)... done error: no any detected/known flash chip found: 0BC0:S_DA_DEVICE_NOT_FOUND error: last error: 0BC0:S_DA_DEVICE_NOT_FOUND Disconnect... done Finished, time used: 19 sec Remove/Install battery now ! READ FIRMWARE COM20 [VCP0] selected module v3.05 Device: Autodetect 6228-6239 NAND Checking data, wait... Action: read firmware NAND interface: BROM_DLL_v3.932.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! CPU: 6235:8A04:8A01 bbchip secure ver: FF bbchip bl ver: FE NOR flash chip: S_DA_NOR_FLASH_NOT_FOUND NAND flash chip: S_DA_NAND_FLASH_NOT_FOUND internal RAM: S_DONE size: 00010000 external RAM: S_DA_DEVICE_NOT_FOUND boot style: S_DA_HANDSET_ROM_INFO_NOT_FOUND bootcode current/expected: 3.2, 3.2 done Set baudrate (115200)... done error: no any detected/known flash chip found: 0BC0:S_DA_DEVICE_NOT_FOUND error: last error: 0BC0:S_DA_DEVICE_NOT_FOUND Disconnect... done Finished, time used: 22 sec Remove/Install battery now ! Can be a cable problem? |
01-12-2010, 13:51 | #4 (permalink) |
Member: 151737 Status: Offline Sonork: 100.1595988 Thanks Meter: 91 | FFS Complete mode COM20 [VCP0] selected module v3.05 Device: Autodetect 6228-6239 NAND Checking data, wait... Action: reset settings ("format ffs") NAND interface: BROM_DLL_v3.932.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! CPU: 6235:8A04:8A01 bbchip secure ver: FF bbchip bl ver: FE NOR flash chip: S_DA_NOR_FLASH_NOT_FOUND NAND flash chip: S_DA_NAND_FLASH_NOT_FOUND internal RAM: S_DONE size: 00010000 external RAM: S_DA_DEVICE_NOT_FOUND boot style: S_DA_HANDSET_ROM_INFO_NOT_FOUND bootcode current/expected: 3.2, 3.2 done Set baudrate (115200)... done error: no any detected/known flash chip found: 0BC0:S_DA_DEVICE_NOT_FOUND error: last error: 0BC0:S_DA_DEVICE_NOT_FOUND Disconnect... done Finished, time used: 22 sec Remove/Install battery now ! |
01-12-2010, 14:18 | #5 (permalink) |
No Life Poster Join Date: Aug 2006 Location: P@kIsTaN
Member: 327384 Status: Offline Sonork: 100.1605419 Thanks Meter: 312 | hello here is logs complete format {6235 chip } COM3 [VCP0] selected module v3.04 Device: Autodetect 6228-6239 NAND Checking data, wait... Action: reset settings ("format ffs") NAND interface: BROM_DLL_v3.932.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! CPU: 6235:8A04:8A01 bbchip secure ver: FF bbchip bl ver: FE NOR flash chip: S_DA_NOR_FLASH_NOT_FOUND NAND flash chip: S_DONE flash id[0053]: 00AD:00A100000015 [HYNIX] H8BCS0PG0MBP flash size: 128Mb page/spare size: 0800/0040 pages/block: 0040 bits i/o: 08 address cycles: 04 internal RAM: S_DONE size: 00010000 external RAM: S_DA_DEVICE_NOT_FOUND boot style: S_NAND_FLASH_BOOT bootcode current/expected: 3.2, 3.2 done Set baudrate (921600)... done ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 05000000/03000000 firmware size: 80Mb ffs size: 48Mb detect sec ro... detect custom parameters... detect project-id... project-id: TL_T7135P3U314_F28L21A_00.53 detect NAND info... number of areas to read: 1 reading (HW_STORAGE_NAND)... nfi area detection... warning: core offset is not detected nfi area detection finished: failed TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 07 sw version: TELACOM35_08B_PMWY_PCB01_GPRS_MT6235B_S01.TL_T7135 P3U314_F28L21A_00_53.BIN project-id: TL_T7135P3U314_F28L21A_00.53, 00000000 code offset: 00000000 ffs offset/size [01]: 05000000/03000000 rom info structure: 2nd [standard] generation TCL-ID is absent ===> done ==================== New firmware detected (v.3.04, database date: 24.12.2009): TELACOM35_08B_PMWY_PCB01_GPRS_MT6235B_S01.TL_T7135 P3U314_F28L21A_00_53.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) ==================== area size: 80Mb number of areas to read: 1 reading (HW_STORAGE_NAND)... file saved: C:\Documents and Settings\mobily talecom\Desktop\TELACOM35_08B_PMWY_PCB01_GPRS_MT62 35B_S01.TL_T7135P3U314_F28L21A_00_53__fullflash_20 100107-174925.B4M.bin Format (HW_STORAGE_NAND)... .................................................. .................................................. Disconnect... done Finished, time used: 30 min 56 sec Remove/Install battery now ! |
The Following User Says Thank You to rameez_gsm For This Useful Post: |
01-12-2010, 15:57 | #6 (permalink) | |
Member: 151737 Status: Offline Sonork: 100.1595988 Thanks Meter: 91 | Quote:
Please Infinity Support give me an idea! Thx | |
01-13-2010, 09:58 | #8 (permalink) |
Member: 151737 Status: Offline Sonork: 100.1595988 Thanks Meter: 91 | Phone model is Fly-Ying F006 TV WiFi. Phone work good before connect to USB Cable. When conect - Usb device not recognized... and after was dead. Should be Hardware problem? |
01-13-2010, 12:06 | #9 (permalink) | |
1. What is with phone NOW (can you power-on phone well) ? 2. Is it dead phone that can not power-on (yes/no) ? I need to know what is with phone now but not yesterday. | |
01-13-2010, 12:07 | #10 (permalink) | |
Thank you ! | |
01-13-2010, 14:56 | #12 (permalink) | |
It's a phone hardware problem - software even can not detect flash chip type. I suggest you to check phone hardware first. | |
03-18-2010, 19:16 | #13 (permalink) | |
Insane Poster Join Date: Jul 2004
Member: 74284 Status: Offline Thanks Meter: 9 | Quote:
BR | |
is CPU MT6129 supported or not? | summer_20xx | Infinity-Box | 1 | 09-30-2009 13:17 |
MTK new CPU 6235 supported only CPF! | phones-china | Service Products News & Updates | 0 | 05-27-2009 15:45 |
cpu type SPREADTRUM supported or not | genci titi 2002 | Infinity-Box | 2 | 12-17-2008 13:38 |
support or not support... don't enter again | dikey | Dongle Problems (USB-Smart) | 4 | 07-17-2006 09:22 |
ufs3 support or not the support, that's the problem | KaToT | UFS2 + UFS3-Tornadoflasher | 0 | 10-20-2004 22:34 |
