07-18-2008, 18:08 | #1 (permalink) |
Junior Member Join Date: Jul 2008
Member: 816811 Status: Offline Thanks Meter: 0 | Following standard procedures to find pinout didn't work I have a 1x12 pin. it is my pinout research on the phone: 1 Obvious GND (look into the PCB and verified) 2,3,6,7 discarded: antenna/audio (used by earphone) 4,5 small voltage (-0.2, 0.2) at power off, around +2.7v at power on (both pins) 8 D- USB 9 D+ USB 10 Power charger (used by cable charger) 11 +3.2v going to 0v when the power button is pressed (even when the phone is turned on) 12 Battery (+4.02v) I discard the pins 8,9 (USB D- D+), 1(GND), 10,11,12 (power related), and 2,3,6,7 (antenna/audio) I connect the infinity box to pins 4,5 (and inverted) and the box didn't see anything I connect the phone with the USB cable and I can read the basic parameters of the phone (AT commands) I test on two identical phones (just to discard problems with one phone) I will appreciate any help or suggestion. Thank you in advance |
07-18-2008, 23:20 | #6 (permalink) | ||
Member: 816811 Status: Offline Thanks Meter: 0 | Quote:
Thank you for help. | ||
07-20-2008, 08:02 | #8 (permalink) |
Member: 816811 Status: Offline Thanks Meter: 0 | Yesterday night was impossible work on infinity-box and phone. I’m really impressed about infinity customer care. When I finish, I will write a customer review and make my small donation. I hope finish soon (I need it) After read and write the firmware, I need the language pack also, This is my report for tonight; I expend several hours to make a test pinout header connector. (Why I don’t buy the pin finder?, next time I will buy this accessory box) I install all cables, the infinity box, the phone and my 15 years old oscilloscope to accelerate the pinout time combinatory consumption problem. I use the custom infinity-box RJ45 cable to connect to my special header connector. First surprise: NOTE FOR RESELLERS: The RJ45 code GF-AT106 included with infinity-box package is wrong. The connector has 5 wires labeled as following: Red :Tx Blue:Rx White and Black; GND two cables joined with one label Green: GND I take the white and black cable and soldered both to the GND pin of my header. When connect the Infinity-box, the computer shows a message like: Too many power requests at USB port and shutdown the infinity-box. Reason: Black cable is +5v and white cable is GND, => short circuit!!!. Well, one problem less. Next step: I connected the oscilloscope to the Tx terminal to check for data. Using the default port (COM4 in my case when I select SCAN with auto detect) doesn’t work. No signal on Tx cable. I used an external COM port and check for signal using the Chinesse miracle software. Result; no problem, signal on external port. I found another port (COM29 VCP0 ???.) on the list of ports in Chiness miracle. I switch to this port and the oscilloscope start dancing with signals. Suggestion: Don’t use the scan port. Well, one problem less. Next step: Finally I start with my common sense combination (the remaining two pins after discard the other pins), just to start with my first hypotesis about pins, and voila!, finally a different message on Chinesse miracle screen. Here is a copy of the message: COM29 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: read/check detailed information Boot... Press and HOLD Power button now ! baud autodetection active 19200 autodetect Connecting, wait... Initializing[6225:8A03:8A00]... CPU: MT6225 high speed boot disabled chip: 0001:4F03:0001 high speed disabled boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 208818FFFFFFFF:20881800000000 flash: 208818FFFFFFFF:20881800000000 number of flash chip/regions detected: 00/01 Unknown or damaged flash chip, operation aborted. Fault reasons: 1. damaged flash chip: replace or resolder/reball flash chip 2. damaged hardware: check hardware, water inside etc. 3. unknown hardware: set "Advanced chip detection method" box [un-checked] and try again 4. wrong model selection, try 'NAND' selection Initialize Fail Finished, time used: 22 sec Remove/Install battery now ! My comments: Fault Reasons: 1,2.- damage flash chip/hardware?. Phone is in perfect work condition 3. unknown hardware: I run the procedure with “Advanced chip detection method” checked and unchecked, with the same result. 4. wrong model selection (where I select the model?) I’m try reading the flash, the NAND, similar problems Memory chip is a M36P0R806. Do you have the datasheet for this memory IC? I have a similar one but is not the same number. Can you help me? I will appreciate a lot. Thank you in advance. |
What is the procedure to find the pinout of d6000? | edermix | SpiderMan | 11 | 11-13-2009 07:35 |
what CPU to select to find Pinouts | Formingus | Infinity-Box | 6 | 02-06-2009 09:37 |
Easy WAY TO FIND PINOUT BY YOURSELF.... | unlock-king | Chinese Models & Cloned Phones | 0 | 03-22-2008 11:14 |
New way to find pinout solution - Hope it will help other members | GuruKids | Infinity-Box | 7 | 01-06-2008 09:41 |
help to find pinout to k750 | aclgsm1 | Sony Ericsson | 3 | 09-24-2005 08:42 |
